rocket 643 Posted January 16, 2020 Flex, pazi kada se i meni to desilo i pisao sam ovde o tome, samo meni se desilo na prvom semaforu 200m od kuće. Zvuk kao da šerpe lupaju sa desne strane 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 16, 2020 Ja gori auto nisam ni video, ovoliko problema ne bih imao da sam uzeo zatvorenih ociju nesto drugo. Rocket, e pa tako neko cangrljanje. Sta ti je bio problem na kraju? Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
rocket 643 Posted January 16, 2020 Nemam pojma. Prestalo kao i tebi i vozim jer ne mogu više da trpim teror ovog auta. Kažu da italijanski automobili imaju dušu, pa ako je ima onda je živ, a ako je živ valjda je zaraslo to što je valjda bilo polomljeno 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 16, 2020 S klasu da sam uzeo verovatno bih manje ulozio. Ali dobro, bice valjda nekad nekog normalnog automobila. Sent from my SM-J530F using Tapatalk 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
danijel55 700 Posted January 16, 2020 Na -19 sam palio libru.Prenocila napolju.Sem cekicanja dizela i malko duzeg verglanja nije bilo. @MS PK Slazem se sa time da jeftiniji a bolji auto nema.Odrzavanje smesno. Baci pogled na remenice. 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted January 16, 2020 E a na koliko se pale grejači na jtd?Pretpostavljam da se ne pale uvek... Sent from my Redmi 4X using Tapatalk Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 16, 2020 Uvek se pale, i zimi i leti. Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted January 16, 2020 Baš sam se nadao da se ne pale uvek Sent from my Redmi 4X using Tapatalk Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 16, 2020 Palili ne palili, isti mu djavo. Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
djomla 8386 Posted January 16, 2020 Baš sam se nadao da se ne pale uvek Sent from my Redmi 4X using TapatalkŠtediš struju? Sent from my 3310 using Tapatalk Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted January 16, 2020 Ma ne nego nikako da se nateram da ih zamenim + još neke sitnice...a auto pali kao i leti pa rekoh da pitam Sent from my Redmi 4X using Tapatalk Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 16, 2020 Posle kad ne budes mogao da odvijes bice veselo. Sent from my SM-J530F using Tapatalk 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Axic 20048 Posted January 16, 2020 7 hours ago, Flex said: Uvek se pale, i zimi i leti. Sent from my SM-J530F using Tapatalk Mislim da se ne pale leti. I sam znaš da indikator za grejače nikad ne vidiš na tabli kad je temperatura recimo iznad 15. Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 16, 2020 Mislim da pali uvek grejace, samo leti na krace verovatno. A za lampicu pojma nemam, nije mi ni palo na pamet da gledam da li je pali. Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
darkman14 5900 Posted January 16, 2020 Koliko je meni poznato, grejace pali samo ispod 3 stepena (ili tako nešto). Isto kao što ni kompresor klime ne pali ispod 5 stepeni. 3 Djuk85, Axic and vicent reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 16, 2020 Kompresor ne pali sigurno, zastita od crkavanja. Mogao bih da se zakunem da sam procitao da rade grejaci i na visim T. Mozda@Ivan zna tacno? Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted January 16, 2020 Koliko je meni poznato, grejace pali samo ispod 3 stepena (ili tako nešto). Isto kao što ni kompresor klime ne pali ispod 5 stepeni.Tako sam i ja čuo nešto, zato sam i pitao Sent from my Redmi 4X using Tapatalk Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted January 17, 2020 Grejace pali stalno, poruku za grejace izbacuje na tabli kada preporucuje da sacekas pre verglanja, a ljudi tu poruku vezuju sa paljenjem grejaca. Kao nekad sto se mislilo da se turbina "pali" na 2000rpm i slicno, kad pocupa maksimalni obrtni moment, e tek onda se "upalila", slicno i sa grejacima, upalili su se tek kad se vidi. Naravno ima tu mnogo varijacija na temu, od toga na koliko stepeni ce da izbacuje poruku, do toga koliko dugo nastave da rade nakon palenja auta, pa do nekih koji rade razlicitim intenzitetom u zavisnosti od raznih faktora, dakle nije samo "on/off" itd. Auto sa grejacima mirnije i mekse radi nakon startovanja. 2 Djuk85 and MS PK reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted January 17, 2020 Na rad grejača naravno ne utiče spoljna temperatura, već temperatura rashladne tečnosti. Sent from my SM-G950F using Tapatalk 1 vicent reacted to this Quote Share this post Link to post Share on other sites
vicent 1263 Posted January 17, 2020 Rekao bih da grejaci na mom Puntu jtd rade samo na niskim temp. rashladne tecnosti. Prosta kineska spravica, bode se u upaljac i pokazuje voltazu akku. Ujutru, na hladnom.startu, -3°C, aku se 5-6 min. puni strujom od 13,9 V, nakon toga struja punjenja, cujem i promenu u radu motora, raste na 14,4 V. Pri povratku s posla, danas je bilo 5-6° C, odmah je krenuo da puni 14,3- 14,4V. Tih 0,5 V napona vuce centrala grejaca, na osnovu senzora temp rashladne tecnosti.Voltmetar stoji vec mesec dana i siguran je pokazatelj.Poslato sa Honor 8X pomoću Tapatoka 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted January 17, 2020 Mislim da se ne pale leti. I sam znaš da indikator za grejače nikad ne vidiš na tabli kad je temperatura recimo iznad 15.Indikator na tim "novijim" vozilima nikad i ne vidis fakticki, samo se pojavi na sekundu i toliko. Grejace pali uvek, pre par god. sam bas ja mislio da ih ne pali do debeeelog minusa pa su Ik. i strucna komisija radili ispitivanje i dosli do tog zakljucka Moze da bude samo ovo sto je kolega Vagenovac pisao, da se razlikuje mozda vreme koliko dugo ostaju ukljuceni i slicnoПослато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 17, 2020 Ebali vas grejaci. Lupalo opet danas (doduse krace) pa odoh sutra do mehanicara (po milioniti put, ebem ti Stila) da vidimo koji mu je. Daleko bilo vise. Primetih da i dalje hoce da stucka kad ubrzava lagano sa dosta malih obrtaja (~1000) tako da zamena protokomera nije bila resenje ipak. Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7732 Posted January 17, 2020 Mazohista, a?Послато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 17, 2020 Ne ide da ga uteram nekom sa problemom. Da resim i ovo pa da polako razmatram prodaju. Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
djomla 8386 Posted January 17, 2020 Esi snimio to što ti lupa? Sent from my 3310 using Tapatalk Quote Share this post Link to post Share on other sites
