dexxybor 0 Posted October 7, 2018 Fiat brava 1.6 16v '97. Nakon duze voznje kada ugasim auto nece da upali dok se malo ne prohladi. Ako pokusam nakon 2-3 minuta nakon gasenja da ga upalim cuje se kao da zavergla pola kruga i tom prilikom svetlo kabine i sijalice na instrument tabli smanje se i nema nista od paljenja sve dok ne prodje neko izvesno vreme i nakon toga pali normalno. Prilikom prvog paljenja auto pali normalno. Napon na akumulatoru u radu je oko 14.5 v. Da je ovo redovna pojava posumnjao bih na anlaser ovako nema logike da je nesto sa njim u pitanju. Molim za savet. Quote Share this post Link to post Share on other sites
Martin 799 Posted October 7, 2018 Proveri knock senzor. Quote Share this post Link to post Share on other sites
dexxybor 0 Posted October 7, 2018 Ma auto ide dobro nema problema u voznji osim sto se cuje lezaj na servo pumpi. Pada mi napamet da ne ukoci on pa zato ne moze da upali neko vreme mada mi je to nelogicno. Quote Share this post Link to post Share on other sites
kaskabgd 65 Posted October 7, 2018 Ja sumnjam na anlaser. 3 neshaoct, Mijailović P. and Djuk85 reacted to this Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted October 7, 2018 ^ +1 Biksne anasera 3 IgorBG, Mijailović P. and neshaoct reacted to this Quote Share this post Link to post Share on other sites
dexxybor 0 Posted October 7, 2018 U redu, anlaser, ali kako hladan pali iz cuga a zagrejan nece dok se ne prohladi ? Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted October 7, 2018 Kad se zagreje bikne se stegnu i ne pustaju....Ne mora da znaci da je to naravno... 1 1 neshaoct and IgorBG reacted to this Quote Share this post Link to post Share on other sites
kaskabgd 65 Posted October 7, 2018 1 hour ago, dexxybor said: U redu, anlaser, ali kako hladan pali iz cuga a zagrejan nece dok se ne prohladi ? Ja sam godinu dana muku mucio dok nisam uradio anlaser, ako bih nesto na brzinu izlazio iz kola nisam gasio auto jer nema sanse da ga upalim dok se malo ne ohladi. Posle servisa anlasera nikad vise. 2 neshaoct and IgorBG reacted to this Quote Share this post Link to post Share on other sites
dexxybor 0 Posted October 7, 2018 Ima logike oko paljenja, nema logike od cega se anlaser toliko zagreva. U svakom slucaju moracu da ga proverim. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted October 7, 2018 Ne zagreva se nego bixne imaju lufta, elipsaste su pa zakoce osovinu 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Trofeo 115 Posted October 9, 2018 On 10/7/2018 at 9:31 PM, kaskabgd said: Ja sam godinu dana muku mucio dok nisam uradio anlaser, ako bih nesto na brzinu izlazio iz kola nisam gasio auto jer nema sanse da ga upalim dok se malo ne ohladi. Posle servisa anlasera nikad vise. Isti slucaj Quote Share this post Link to post Share on other sites
Dexa313 13 Posted November 15, 2018 takodje imao taj problem. odem kod auto elektricara on servisira alanser on pali ko mina. posle nekog vremena opet ista stvar. ovaj opet servisira i sve ok . Desi se to i treci put. ja reko neces majci. ja skinem alanser pogledam podatke u servisnom upustvu i vidim da je neko pre moje kupovine stavio slabiji alanser od punta ili vec cega. cini mi se da je bio 0,9 kw a treba 1,3kw. kupio polovan i nikad vise problemaSent from my Mi A1 using Tapatalk Quote Share this post Link to post Share on other sites
Trofeo 115 Posted November 15, 2018 8 hours ago, Dexa313 said: takodje imao taj problem. odem kod auto elektricara on servisira alanser on pali ko mina. posle nekog vremena opet ista stvar. ovaj opet servisira i sve ok . Desi se to i treci put. ja reko neces majci. ja skinem alanser pogledam podatke u servisnom upustvu i vidim da je neko pre moje kupovine stavio slabiji alanser od punta ili vec cega. cini mi se da je bio 0,9 kw a treba 1,3kw. kupio polovan i nikad vise problema Sent from my Mi A1 using Tapatalk Ne mora da znaci da je od punta Nisu iste jacine alnaseri za brava sa klimom i bez klime,neka me neko ispravi ako gresim Quote Share this post Link to post Share on other sites
kreator 288 Posted November 15, 2018 (edited) Kad sam jurio pre par godina za moj Bravo 1,6 sa klimom ovaj koji sam skinuo bio je 1,3 ili 1,4 kw nisam siguran..Znam da je bilo nekih slabijih u ponudi polovnih..Ipak mi je majstor dao predlog i sredio mi ovaj koji je skinut..Koštalo je nekih 45 evra i od tad radi besprekorno.. Edited November 15, 2018 by kreator Quote Share this post Link to post Share on other sites
