Danilo1 1159 Posted April 6, 2019 Evo jel bolje ovako? @Ivan @Milutinac 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted April 6, 2019 Bolje. Samo kad TO nesto izvadis iz kola on ce opet da se propne kao divokoza Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted April 6, 2019 A ko bi vadio 3 devojke iz kola? 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
shomispc 832 Posted April 9, 2019 Pa ako su zive onda niko 1 djomla reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted April 9, 2019 A Bravo tesan, pa nemaju gde da beže. Quote Share this post Link to post Share on other sites
shomispc 832 Posted April 9, 2019 Visok onaj menjacki tunel, pa ako ta u sredni nosi minic onda pun pogodak 1 1 djomla and Danilo1 reacted to this Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted April 9, 2019 Bravisti da li ste za neki mini skup 21.4? Quote Share this post Link to post Share on other sites
MS PK 7728 Posted April 9, 2019 Zavisi, dal dolazis sa te 3 devojke ili ne 1 djomla reacted to this Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted April 9, 2019 ako je to u pitanju, napunicu i Stila Quote Share this post Link to post Share on other sites
MS PK 7728 Posted April 9, 2019 Odkad to nije bilo u pitanju? 1 Danilo1 reacted to this Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted April 17, 2019 pala i fabricki zatamnjena stakla sledeci farovi ili crno nebo Quote Share this post Link to post Share on other sites
Ivan 17587 Posted April 17, 2019 Na kraju ipak folija na zadnjoj soferci? Nadam se da neces imati problema, nazalost u onih zadnjih par akcija bas nisu imali milosti sa skidanjem tablica i slanjem na KTP. Tada sam i zgulio Llumarke sa Stila, nek se ***... Mada vidim da opet ima ljudi koji voze folije cak i napred, naravno sve neatestirano. Ili veza ili opet APP, ocigledno. Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted April 17, 2019 Ma da, vise mi se isplati 10 puta da skidam nego da placam atest.. A atest je postao smesan, atestiraju skoro providnu foliju, posle skinu tu providnu i stave 80% zatamnjenosti Mozda stavim i 50% napred, skoro pa da se i ne vidi folija.. P. S. Ako budes imao vremena dodji u nedelju na Kosutnjak na skup Bravista Quote Share this post Link to post Share on other sites
Ivan 17587 Posted April 17, 2019 (edited) Pa kazem ti da u zadnje vreme vidjam ne mali broj njih koji opet pici folije napred, blage ali opet primetim, pozadi naravno nikakav atest... Sa skidanjem imaj u vidu da mozes da nacnes po neki grejac stakla. Nadam se da neces imati problema. PS: Ako vreme dozvoli, imacu u vidu - hvala na pozivu svakako . Ako ne, vidimo se nekad kod Intera, ni tamo nisam bio odavno... Edited April 17, 2019 by Ivan 1 Danilo1 reacted to this Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted April 21, 2019 Za prvi skup sasvim dovoljno 5 silenci, Stilisa, dach@ and 2 others reacted to this Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted May 21, 2019 4 neshaoct, Stilisa, silenci and 1 other reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9590 Posted May 22, 2019 Reklamiraš Vojvođansku banku... Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted May 22, 2019 @neshaoct Dobijam procenat Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted June 1, 2019 (edited) dosli na red i farovi Stilo vratii mi se salu na stranu, farovi i branik se mnogo lakse skidaju na Bravu (2 srafa od fara sa gornje strane, zabica u krilu i kada se skine branik ima jos jedan sraf na sastavu branika i krila; branik ima jedan sraf i zabice sa strane) ali je zeznut nosac branika koji se nalazi na donjoj strani fara.. Oba fara fabricka sto me je pozitivno iznenadilo ali sam se brzo razocarao kada sam video rdju na srafovima koji spajaju far i taj nosac branika, morao sam da ih razbusim i da stavim nove sto se tice otvaranja, pomogao mi je Aleksandar Kacimbas (mozete pogledati na fejsu i instagramu sta sve radi) uspeli smo da ubacimo umesto fabrickih H1 2.5" projektora nove 3" D2S bi-xenon projektore ubacuju se sraf na sraf, ali je problem rozetna oko projektora koju sam isturpijao sa unutrasnje strane i spolja isekao prsten 1cm debljine. Drugu rozetnu (koja ide do stakla) sam ofarbao u crno. Sve smo upakovali bez nekih vecih problema, sto se stelovanja tice, ako su farovi pre toga nastelovani, bice onda i ovi. Levi projektor kao da je malo ulevo zakosen ali takav cutoff mi je bio i sa starim projektorom, u voznji nista ne smeta, vidim sve lepo sa leve strane, levu sijalicu bih mogao jos malo mozda da okrenem jer je malo nazuljana sa zadnje strane pa je hotspot na levom faru za nijansu nizi nego na desnom.. Cim sam krenuo od Ace odmah sam video veliku razliku u odnosu na stare.. sto se tice blicanja H1 led na dugim + projektori = ubica jedino treba jos malo farovi da se ispoliraju da bi se dobio pun efekat i jos nesto, odlicna stvar za prasinu i dlake sa sedista - valjak za pse Edited June 1, 2019 by Danilo1 3 marko.jovanovic, Ivan and Milutinac reacted to this Quote Share this post Link to post Share on other sites
danijel55 699 Posted June 1, 2019 Daj neku sliku po mraku kako sijaju Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted June 1, 2019 @danijel55 bice samo ovo vreme da se prolepsa Quote Share this post Link to post Share on other sites
Ivan 17587 Posted June 1, 2019 (edited) Kuckali smo se na PP, ali evo i ovde da pohvalim radove . Mnogo bitnija je funkcionalnost i dobra vidljivost. Ali svakako, zasto ne iskoristiti otvaranje i za estetiku - ova tamnija varijanta unutrasnjosti fara i migavca (kao na restyle) daleko lepse izgleda nego ona sjajna svetla sa zutim migavcima (sa pocetka produkcije). Edited June 1, 2019 by Ivan Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted June 1, 2019 (edited) prvenstveno zbog toga sam ih i radio Italijani farbaju sve u crno, samo sto kod nas ne bih nikad prosao tehnicki.. Edited June 1, 2019 by Danilo1 1 horvat reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted June 1, 2019 Izgleda odlicno bas. Kolika je razlika u odnosu na stare projektore i standardne h1 posebno po nocu i kishi ? (Ofc, ako taj auto uopste i kisne , a ne ko moj eno upuvao se na parkingu)Sent from NOMU S10 PRO using Tapatalk Quote Share this post Link to post Share on other sites
