MS PK 7732 Posted May 24, 2018 Neko mi.iscupao nocas poklopac lajsne na krovu ( onaj gde se srafi nosac za krovni kofer) i bacio pored kola, medjutim prodju neka kola i zgaze ga, tako da mu fali malo parce. Gde to ima da se kupi? Pretpostavljam da moram da kupim celu lajsnu na otpadu? Stilo kupe Quote Share this post Link to post Share on other sites
totti 13165 Posted May 24, 2018 Nemoj samo sad da skačeš u Toplicu ili da se besiš Quote Share this post Link to post Share on other sites
djomla 8386 Posted May 24, 2018 Kupi ceo krov, poklopac uzmi a ostatak salji meni Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 24, 2018 Hahaha oces da pravis kokosinjac il poljski wc? Quote Share this post Link to post Share on other sites
djomla 8386 Posted May 24, 2018 Tendu Mico Nego, jesu ti poklopci svi isti? Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 24, 2018 Kako isti? Pa fabricki su Quote Share this post Link to post Share on other sites
djomla 8386 Posted May 24, 2018 Sad sam pogledao kod sebe, rek'o jel ima veze napred, nazad i sl. Pitacu sutra, prekosutra drugara da li moze da nabavi. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 24, 2018 Ajd djomla tebra Quote Share this post Link to post Share on other sites
djomla 8386 Posted May 24, 2018 A sta cu ja za tendu posle? Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 24, 2018 Cu ti dam neki stari carsav Quote Share this post Link to post Share on other sites
totti 13165 Posted May 24, 2018 On 5/24/2018 at 10:46 PM, MS PK said: Kako isti? Pa fabricki su O ebem te tupava... Pa ne pita te dal ti pasuju sa Lade i tristaća, nego dal su sva 4 ista 2 djomla and Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted May 24, 2018 Pa stvarno, biiip tupava i ja Quote Share this post Link to post Share on other sites
Ivan 17668 Posted May 25, 2018 13 hours ago, MS PK said: Pretpostavljam da moram da kupim celu lajsnu na otpadu? Mico, bacih pogled u eLearn da li to moze da se naruci kao poseban deo, ako ne nadjes vec negde po otpadima... Koliko vidim - ne moze, celu lajsnu vode kao jedinstven deo. Ima jedino ovaj "Clip", oznacen brojem 8, ali mislim da je to zabica kojom se lajsna pricvrscuje: Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 25, 2018 Jeste verovatno. Hvala Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 25, 2018 Nasao preko fb grupe Quote Share this post Link to post Share on other sites
totti 13165 Posted May 25, 2018 Ivane, zna on da može da se poruči, ali čeka da neko pokloni 1 1 Ivan and djomla reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 25, 2018 Ne moze bre ide u sklopu sa lajsnom. A nju ako skindam ima da polomim i zabice i ko zna sta jos. U svakom slucaju, poklonio covek vec tj nekoliko njih se javilo 1 totti reacted to this Quote Share this post Link to post Share on other sites
Ivan 17668 Posted May 25, 2018 Fina neka FB grupa, znas i ti gde sa se privalis . Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 25, 2018 Pa i ja vozim 100god stila a i brt svi zivi ih sad rasturaju a to verovatno nikome i ne treba i tako..ostave ljudi i pozitivan utisak "radi dalje saradnje" Quote Share this post Link to post Share on other sites
totti 13165 Posted May 25, 2018 Će se ovajde od tebe za dalju saradnju... 1 djomla reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 25, 2018 Daleko bilo baxuze matori Quote Share this post Link to post Share on other sites
djomla 8386 Posted May 25, 2018 I sad ja ostajem bez tende? Quote Share this post Link to post Share on other sites
Mijailović P. 3448 Posted May 25, 2018 Uaaa čela ! Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 25, 2018 Kakvu tendu to pravis? Quote Share this post Link to post Share on other sites
