Nikolaq1 2 Posted May 20, 2018 Nisam nasao slicnu temu, pa cu pitati ako je problem neka administratori premeste/uklone i izvinjavam se ako pravim dupli post Imam problem sa kocnicama dakle kad ga vozim pri vecoj brzini i vecim obrtajima, i krenem da kocim, kocnica postane previse tvrda bukvalno ne moze se pritusnuti ali koci nekako, posle par sekundi pod nogom se oseti da kocnica postane mekana i onda koci mnogo bolje ali i dalje nije to to, parkirao sam auto i ne smem da sedam vise u nejga. Sta moze biti problem, hvala svima koji zele da pomognu.. 1.2 16v 2002 god sa ABS-om Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted May 20, 2018 Da li slucajno nisi drzao i gas u vreme kocenja? Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted May 20, 2018 (edited) @Goran Zemunovo se i meni desava u poslednje vreme, gas nije bio pritisnut. Edited May 20, 2018 by Rile_bg Quote Share this post Link to post Share on other sites
Nikolaq1 2 Posted May 20, 2018 (edited) Jednom prilikom sam drzao kocnicu i davao gas ali to je bilo pre 2-3 meseca a ovo se javilo od pre nedelju dana, broj obrtaja skace kada drukam kocnicu u leru Edited May 20, 2018 by Nikolaq1 Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted May 20, 2018 Verovatno je problem nepovratni ventil na servo pojacivacu. 1 Nikolaq1 reacted to this Quote Share this post Link to post Share on other sites
Nikolaq1 2 Posted May 22, 2018 (edited) Hvala Gorane, da li se to moze kupiti posebno negde, i kako se tacnije zove taj deo. Kada pitam u radnji bledo gledaju u mene Jedan prodavac me ubedjuje da je to vakum pumpa? Edited May 22, 2018 by Nikolaq1 Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted May 22, 2018 10 hours ago, Nikolaq1 said: Hvala Gorane, da li se to moze kupiti posebno negde, i kako se tacnije zove taj deo. Kada pitam u radnji bledo gledaju u mene Jedan prodavac me ubedjuje da je to vakum pumpa? Deo se zove nepovratni ventil servo uredjaja....a inace tvoj auto nema vakum pumpu.... 1 Nikolaq1 reacted to this Quote Share this post Link to post Share on other sites
Nikolaq1 2 Posted May 23, 2018 Da li odgovara od 1.2 8v ili od JTD-ja, ako moze kratka instrukcija kako se menja, 300 din kosta na otpadu taj mali delic a pravi velike probleme Quote Share this post Link to post Share on other sites
