MilanStilo 2 Posted January 5, 2015 Ovde pise opel i alfa. Dal ce da radi na daciu? Hahaha Deki hvala ti Skinuo sam vag-com ne znam dal ce on moci. Odoh do njega pa cemo probati. Sta da radim :/ Quote Share this post Link to post Share on other sites
deki87 7 Posted January 5, 2015 Ja sam se na citroen i ford kacio preko scanmaster. Quote Share this post Link to post Share on other sites
gogi1101 0 Posted January 5, 2015 Koji adapter imas?Ako je elm327 mislim da ne mozes vag-com,mislim da on moze samo sa KKL kablom.I VAG-kom je valjda za das Auto. Quote Share this post Link to post Share on other sites
Dovla 9 Posted January 5, 2015 Uzmeš VAGCOM 409.1 (onaj plavi) i skineš program DDT2000. Quote Share this post Link to post Share on other sites
MilanStilo 2 Posted January 5, 2015 ELM327 je u pitanju. Ipak nisam uspeo sa ovim scanmaster da vidim dal se slaze km u kompu sa ovom na bordu a ni u kakvom su stanju dizne,turbina itd... Video sam da nema gresku i to je to Quote Share this post Link to post Share on other sites
gogi1101 0 Posted January 5, 2015 Za stanje dizni,turbine ... mislim da moze samo Renault Can Clip da pomogne.Ali to je skupa igracka samo za proveru prijateljima :-) Quote Share this post Link to post Share on other sites
deki87 7 Posted January 6, 2015 A to sto ti hoces ne moze sa time. Quote Share this post Link to post Share on other sites
Dovla 9 Posted January 6, 2015 Uzmeš VAGCOM 409.1 (onaj plavi) i skineš program DDT2000. Quote Share this post Link to post Share on other sites
MilanStilo 2 Posted January 6, 2015 Ok. Hvala vam! Quote Share this post Link to post Share on other sites
Psiho 0 Posted January 12, 2015 Zvezdo Skinuo sam ovaj MES 2.2 i instalirao na lap top po prilozenom uputstvu. Medjutim kad unesem kljuc resetuje se i vrati u registrovanom modu ali kad ugasim MES i ponovo ga pokrenem on se vrati u neregistrovan mod....sta raditi ili imas ideju u cemu je problem.... Quote Share this post Link to post Share on other sites
milan-jtd 317 Posted January 12, 2015 Isti slucaj i kod mene, ali mi nije tesko da unesem serijski broj kada mi zatreba Quote Share this post Link to post Share on other sites
Psiho 0 Posted January 12, 2015 (edited) Isti slucaj i kod mene, ali mi nije tesko da unesem serijski broj kada mi zatrebajbg ja sam sa malo crnogorske krvi pa me mrzi da trazim kljuc svaki put ako ne moram. Ako mora jbg onda Edited January 12, 2015 by Psiho Quote Share this post Link to post Share on other sites
tox 42 Posted January 12, 2015 I meni se desavalo to i mislim da je problem u tome sto program nakon sto se pokrene ,spoji se sa svojim serverom,proveri serijski broj,utvrdi da je fake i ponisti registraciju.Ja sam to resio sto sam mu blokirao pristup netu u firewallu i to se vise ne desava to jest registracija ostaje.Drugo resenje je ne spajati racunar uopste na internet Quote Share this post Link to post Share on other sites
Dovla 9 Posted January 12, 2015 Internet je problem. Isključiti internet pre pokretanja programa. Quote Share this post Link to post Share on other sites
Psiho 0 Posted January 12, 2015 Hvala drugari...net je problem sada cu ga vezati na kratkoE sad radi Quote Share this post Link to post Share on other sites
Psiho 0 Posted January 13, 2015 Resio sam privremeno. Zabranjen mu je odlazak na internet ali je ogranicen na 20 minuta rada. i posle 20 minuta se ugasi ima li negde krekovana ili otkljucana verzija mes-a Quote Share this post Link to post Share on other sites
tox 42 Posted January 13, 2015 (edited) Ako se gasi posle 20 minuta znaci da je ponistio "registraciju" ili uopste i nije bio registrovan to jest da je free verzija.Link za skidanje imas na mnogo mesta u ovoj temi a najsvezije na pocetku prethodne strane.Evo da se ne smoris previse trazecihttp://www.fiat-lancia.org.rs/forum/index.php?/topic/42823-fiat-lancia-alfa-dijagnostika-adapterisoftver-i-primena-by-banetv/page-108#entry1153694 Edited January 13, 2015 by tox Quote Share this post Link to post Share on other sites
Zvezdo 931 Posted January 14, 2015 Nikada nisam pokretao program dok sam na netu tako da nisam primetio problem!Bitno je da postoji rešenje.Nego. Stari ELM mi vrisnuo (problem sa usb kabelom) kupio od "prijatelja-partner kluba" drugi i nastao problem!Čim sam ga uključio u komp on ga ne prepoznaje bez obzira što ništa nije menjano!?? Stavio opet FTDI drivere i sve podesio ali opet ne radi! Identična stvar na dva kompjutera! Da li je moguće da su mi poslali neispravan ELM? Quote Share this post Link to post Share on other sites
BigBadWolf 0 Posted January 14, 2015 Resio sam privremeno. Zabranjen mu je odlazak na internet ali je ogranicen na 20 minuta rada. i posle 20 minuta se ugasi ima li negde krekovana ili otkljucana verzija mes-aMoras da ga instaliras ponovo. Deinstaliraj nekim programom koji skida kompletno sve, npr. Revo uninstaller, iskljuci se sa neta, instaliraj, blokiraj ga u firewall i trebalo bi da radi i da koristis net istovremeno. Quote Share this post Link to post Share on other sites
Dovla 9 Posted January 15, 2015 Nikada nisam pokretao program dok sam na netu tako da nisam primetio problem!Bitno je da postoji rešenje.Nego. Stari ELM mi vrisnuo (problem sa usb kabelom) kupio od "prijatelja-partner kluba" drugi i nastao problem!Čim sam ga uključio u komp on ga ne prepoznaje bez obzira što ništa nije menjano!?? Stavio opet FTDI drivere i sve podesio ali opet ne radi! Identična stvar na dva kompjutera!Da li je moguće da su mi poslali neispravan ELM? Naravno da je moguće Kako ga prepoznaje kompjuter u Device Manageru? Pod kojim imenom? Quote Share this post Link to post Share on other sites
Psiho 0 Posted January 15, 2015 (edited) proradilo za sada sve kako treba. Sta mi od kablova treba da bi sa MES 2.2 i lap topom pristupio svemu ponudjenom u programu. Najvise me interesuje kako moze da se promeni servisni interval koji je 20.000. da se resetuje, ocitavanje gresaka i brisanje istih. Izbacuje mi za air bag gresku kad neko sedi na suvozacevom mestu a ja stisnem sirenu. Edited January 15, 2015 by Psiho Quote Share this post Link to post Share on other sites
Dovla 9 Posted January 15, 2015 Za to bi već bilo korektno da pročitaš malo temu. Pisano gomilu puta sve što si pitao. Quote Share this post Link to post Share on other sites
Zvezdo 931 Posted January 15, 2015 Nego. Stari ELM mi vrisnuo (problem sa usb kabelom) kupio od "prijatelja-partner kluba" drugi i nastao problem!Čim sam ga uključio u komp on ga ne prepoznaje bez obzira što ništa nije menjano!?? Stavio opet FTDI drivere i sve podesio ali opet ne radi! Identična stvar na dva kompjutera!Da li je moguće da su mi poslali neispravan ELM? Naravno da je moguće Kako ga prepoznaje kompjuter u Device Manageru? Pod kojim imenom? Resio sam problem!U device Manageru ga je uredno video kao COM port. Sa FTDI driverima probao stariju i najnoviju verziju istih medjutim jednostavno ga MES ili bilo koji drugi program ne vidi! Posto sam pre sa starim ELMom na drugom kompu sve podesio za 2 minuta bio sam ubedjen da je problem u novom ELMu te se obratio "Vlaki-Prijatelju" i u kratkim crtama mu izlozio problem.Da ne duzim previse, jednostavno svaka generacija ili proizvodjac uredjaja treba drugacije drivere da bi ELM radio kako treba. Pustio Win da ih sam nadje na netu i pronasao neke PROFILIC drivere. Instalirao ih i gle cuda! Radi!Na drugom kompu (mali lepi top) imam Win7 starter i on nije htio da sam trazi po netu drivere pa sam ih skinuo sa Proficove stranice i naravno i tamo sve radi!Sta reci? Jeftino Kinesko smece koje stvara probleme ali ako se osposobi zavrsava posao!Uz novi ELM sam dobio CD ali ga dva racunara nisu mogla otvoriti na trecem jedva uspio i na njemu (CDu) hrpa necega sve razbacano bez uputstva i ikakvog smisla tako da nisam ni pokusavao gubiti vreme sa njim. Quote Share this post Link to post Share on other sites
Zvezdo 931 Posted January 16, 2015 Još samo da se uspem spojiti sa autom! Sinoć nisam uspio?!?Bog dragi zna šta ga sad muči?Kupiš nešto što si već imao i proverio i dobiješ nešto sasvim drugo koje samo izgleda kao ono prvo! Quote Share this post Link to post Share on other sites
mladenke 7 Posted January 16, 2015 Mozda je fabricka zastita od kineskih elm-ova Slucajno vidim na jednom drugom forumu temu na oko ne vezano za ovu nasu ovde ali...Elm interfejsi koriste FTDI drajvere za koje je proizvodjac skoro pustio drajvere preko Windows update-a a koji "brikuju" ne originalane uredjaje to jest sve ove nase interfejse koje dobijamo od kineza.Drajver posle instalacije na specifican nacin proveri da li je chip u uredjaju originalan ili ne i ako nije upisuje mu u memoriju neki kod koji blokira rad uredjaja.Ne mogu reci 100% da li ovo stvarno ima veze sa elm interfejsima ali ne bi bilo lose malo pripaziti odakle se instaliraju drajveri to jest ne preko windows update-a ili sajta proizvodjaca.Konkretno moj elm u sebi nema uopste FTDI chip nego neki Prolific ali vecina koristi bas ovaj FTDI. Vise informacija:http://www.elitesecurity.org/t479872-0-Novi-presedan-FTDI-Chipshttp://www.zdnet.com/ftdi-admits-to-bricking-innocent-users-chips-in-silent-update-7000035019/ Isti slucaj i za vagkkl 409. Noviji drajveri blokiraju cip pa tako uredjaj ne reaguje i MES ga ne vidi. Ko ima taj problem moze probati sa ovim drajverima. https://mega.co.nz/#!ot0SBKwC!-B50jd71WYCaZlyng71Hqgnfv5_ycj8-k_2oqZWsE1g Quote Share this post Link to post Share on other sites
