Milutinac 5906 Posted February 3, 2014 Imas 327 i preko USB-a... Quote Share this post Link to post Share on other sites
deki87 7 Posted February 3, 2014 Da imas i elm327 preko usb-a proguglaj malo imas ih i na limundu i kupujem prodajem.Ja imam elm327 1.5v bluetooth i radi odlicno nemam problema. Quote Share this post Link to post Share on other sites
Dovla 9 Posted February 3, 2014 ma meni treba nesto za 5-6 hiljada recimo, uzmem kabal i disk i da citam i brisem greske... nista profesionalno... Pa eto, ima na prethodnim stranama i za mnogo manje pare. Quote Share this post Link to post Share on other sites
peki_92 1 Posted February 4, 2014 (edited) nasao sam http://www.kupindo.com/Prateca-oprema/12947981_VAG-COM-KKL-za-FIAT-ALFA-LANCIA-vozila-sa-prekidacima i http://www.kupindo.com/Prateca-oprema/16686133_AUTO-DIJAGNOSTIKA-ELM-327-MINI-OBD . jel moze to da se koristi na FIAT vozilima konkretno punto 1.8 HGT 16V 2002 godiste, iscitavanje i brisanje gresaka, servisa i citanje vrednosti senzora i davaca i koja je dijagnostika bolja od ove dve? hvala vam Edited February 4, 2014 by peki_92 Quote Share this post Link to post Share on other sites
deki87 7 Posted February 5, 2014 Sa elm327 mozes sve to osim servisnog intervala,a sa vagcom mozes sve. Quote Share this post Link to post Share on other sites
Dragan G 0 Posted February 5, 2014 Kupis oba, ovaj vagkom sa prekidacima i jedan ELM bez prekidaca . Oba da budu kablovski i zavrsio si posao. Quote Share this post Link to post Share on other sites
peki_92 1 Posted February 5, 2014 sta ce mi oba ako su oba slicna? Quote Share this post Link to post Share on other sites
deki87 7 Posted February 5, 2014 Pa rekosmo ako hoces samo za fiat onda uzmi vagcom,ako hoces za sva vozila onda elm stim da ne mozes da brises servisni interval i da ulazis u airbag i abs. Quote Share this post Link to post Share on other sites
peki_92 1 Posted February 5, 2014 na fijatu mi je ovaj konektor ...to znaci da nepasuje taj konektor od dijagnostike koju sam hteo da kupim? Quote Share this post Link to post Share on other sites
Dovla 9 Posted February 5, 2014 Zadnjih nekoliko postova ce biti obrisano jer su konfuzni i kontradiktorni.'Ajde da pokusam da pitam jos jednom: Na prethodnih 88 strana nisi pronašao ništa korisno? Nijedan savet? Preporuku? Uputstvo? Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted February 5, 2014 'Ajde ti to malo bolje uporedi i docices do sasvim suprotnog zakljucka a moderi , ako se slazu, neka brisu nepotrebno u vec i ovako pretrpanu temu ! Quote Share this post Link to post Share on other sites
peki_92 1 Posted February 5, 2014 ako vi kazete da je konektor isti, oki... ja ga kupio Quote Share this post Link to post Share on other sites
deki87 7 Posted February 5, 2014 Isti je bree! Quote Share this post Link to post Share on other sites
dejica 21 Posted February 6, 2014 (edited) jedno pitanje da limogu sa ovim VAG COM KKL sa prekidacem da pristupim reset servisnog intervala na stilo ? ako moze na kom stepenu da postavim prekidac ? ili mi je potreban adapter dodatni na primer A1 i A2 ili moze bez njih samo sa VAG COM KKL sa prekidacem ? Edited February 6, 2014 by dejica Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted February 6, 2014 Na žalost Dejo, ne može bez ELM interfejsa za tvoje Fiat-e ! zulutapka Quote Share this post Link to post Share on other sites
deki87 7 Posted February 6, 2014 Kolko se ja razumem sa elm327 ne moze,a sa vagcom moze! Quote Share this post Link to post Share on other sites
vladac81 23 Posted February 6, 2014 Na fiat stilu sa elm 327 MOZES pristupiti servisnom intervalu,ponistavati ,dodavati kupone itd... Quote Share this post Link to post Share on other sites
deki87 7 Posted February 6, 2014 Pa moze ako se prepravi! Quote Share this post Link to post Share on other sites
vladac81 23 Posted February 6, 2014 (edited) Svi koji su kupljeni preko http://www.fiat-lancia.org.rs/forum/index.php?/topic/53767-fiatalfalancia-dijagnostika-vlaka-doo/ rade bez greske,posto ne pise koji je uredjaj zato sam i napisao da moze...O prepravci ima par postova unazad...Znaci moze ovako ili onako... Edited February 6, 2014 by vladac81 Quote Share this post Link to post Share on other sites
Dovla 9 Posted February 6, 2014 Ljudi zar je toliko teško pročitati nekoliko instrukcija?! - Odeš na Multiecuscan sajt- Pronađeš svoje vozilo u tabeli- Vidiš koje su oznake za koji modul (one u boji)- Na tom isto mestu pogledaš legendu šta koja oznaka znači I gle čuda - saznaješ šta ti je potrebno za dijagnostiku tvog auta! Evo za stila: Service Interval Reset |INFO|ADJ| ELM OBDKey Što dalje implicira da je potreban SAMO ELM327 za pristup resetu servisnog intervala. Takođe u toj istoj tabeli primetite da Stilo 1,9mjet 8v 120ks nije podržan kroz MES (Multiecuscan) uopšte. Voila! Quote Share this post Link to post Share on other sites
dejica 21 Posted February 6, 2014 Nista moracu da kupim ELM 327 jer vec imam VAG COM KKL sa prekidacem . Quote Share this post Link to post Share on other sites
deki87 7 Posted February 6, 2014 Ja imam elm327 pa ne mogu da brisem interval servisa. Quote Share this post Link to post Share on other sites
Dovla 9 Posted February 6, 2014 @dejica Tako ćeš imati kompletnu dijagnostiku za svoj auto. @deki87Da si prelistao makar ovu temu, znao bi da postoje ELM327 sa problematičnim pločama koji ne mogu da pristupe modulima na CAN-u. Najčešće je potrebno skinuti jedan otpornik, mada se dešava i da ne može da se reši. Ako hoćeš, rastavi svoj ELM pa okači slike da vidimo kako izgleda i da li možeš rešiti problem sa skidanjem otpornika. Quote Share this post Link to post Share on other sites
deki87 7 Posted February 6, 2014 Ajde vazi za vikend kad ugrabim malo vreme. Quote Share this post Link to post Share on other sites
