dobri nikola 15 Posted January 13, 2018 Dali je neko radio dijagnostiku na Palio 1,2l 8V 65KS 2001 godiste, ima tropinski prikljucak? Dali se na tom autu sa kkl interfejsom moze uraditi adaptacija klapne, jer je menjan step motor i senzor leptira. Quote Share this post Link to post Share on other sites
psyman 1 Posted February 17, 2018 (edited) Da li vredi uzimati ovo sa slike za rad sa mes 3.7? Ili mozda uzeti nesto drugo? Edited February 17, 2018 by psyman Quote Share this post Link to post Share on other sites
viper 108 Posted February 17, 2018 Vredi naravno. Quote Share this post Link to post Share on other sites
psyman 1 Posted February 18, 2018 Radi znaci sve bez problema? Quote Share this post Link to post Share on other sites
viper 108 Posted February 18, 2018 http://www.multiecuscan.net/ Ovde imaš detaljan opis, pa malo pročitaj. Quote Share this post Link to post Share on other sites
Iggy_pop 1 Posted February 20, 2018 molim vas ako neko moze da mi kaze odakle da skinem driver-e imam onaj modifikovani kkl vag-com 409.1 ja sam ga modifikovao sam i radio je besprijekorno. onda sam morao da oborim windows na lapopu i od tada nikad nisam uspio da ga nagovorim da radi. znam da sam se i tada mucio dok sam drivere sabrao. Win7 64bit Hvala unaprijed Quote Share this post Link to post Share on other sites
pantadv 0 Posted April 5, 2018 Jel se javljala ova greska nekom ili samo meni? Greska se javlja tek kad krekujem program. Inace skinuo sam otpornik 121 sa elm327, ali nisam mogao da pristupim ecu ni preko MES, ni preko scan master, a ni preko Scan tool. Sada sam ubacio po jedan otpornik i kondenzator izmedju pina 14 i mase i pina 6 i mase. Sada pristupam ecu preko scan mastera i scan tool, ali MES nece. Zna li neko gde je problem? Quote Share this post Link to post Share on other sites
gagyns 35 Posted April 6, 2018 On 2/20/2018 at 10:29 PM, Iggy_pop said: molim vas ako neko moze da mi kaze odakle da skinem driver-e imam onaj modifikovani kkl vag-com 409.1 ja sam ga modifikovao sam i radio je besprijekorno. onda sam morao da oborim windows na lapopu i od tada nikad nisam uspio da ga nagovorim da radi. znam da sam se i tada mucio dok sam drivere sabrao. Win7 64bit Hvala unaprijed Ako te zeza device da neće da se startuje u Windows-u a u pitanju je PL2303 USB na RS232 konverter ovaj driver bi trebao da reši problem http://www.ifamilysoftware.com/Drivers/PL2303_64bit_Installer.exe Quote Share this post Link to post Share on other sites
puntara 26 Posted May 2, 2018 Prica je jednostavna.Pre pet godina kupljen punto klasik a kad je poceo da pali greske kupljen elm pa i kkl sa dip prekidacima kako ne bi razvlacio i naticao one kablove.Kupljen za svoje potrebe a ponekad ali retko bi se zakacio i neki autic od ortaka uz casu soka.Uputstvo za prekidace bi na netu i sve bi potaman ali ne lezi vraze.Pre desetak dana ortak ispazari punta m jet pa ajde da ga nakacimo na dijagnostikicu.Pogledam mes za m jet i ne registrujem da je uputstvo samo elm i kl sa adapterima.Naravno da nisam mogao da se konektujem na abs jer nisam znao kako da podesim dip prekidace a one adaptere nemam.Ne mogu da se oslonim ni na broj adaptera jer se za kl 1,kl 9 i kl 12 koristi adapter 1 a polozaj dip prekidaca nije isti za ove kl ove. Slicno je i sa elm om.Napravio sam gresku sto ono staro uputstvo nisam skinuo celo na flesh a nisam dovoljno ni vest za racunarom da bih ga pronasao.Bio bih zahvalan ako neko zna gde da skinem ono celo staro uputstvo il da bespotrebno ponovo kupujem elm ove,kkl ove,kablove i majkine..... Quote Share this post Link to post Share on other sites
akiro 4 Posted May 7, 2018 (edited) Da li zna neko neki servis u Zemunu koji ima dijagnostiku za Fiat, a da nije preskupo? Zvao sam "Fiat Bogunovic" u Tosinom bunaru, cena je 2400 rsd samo da prikaci auto... Edited May 7, 2018 by akiro Quote Share this post Link to post Share on other sites
Markobgd 609 Posted May 7, 2018 Servis Goran na Altini. Imaš brojeve u partnerima kluba Quote Share this post Link to post Share on other sites
neshtry 14847 Posted May 7, 2018 Sevis Goran Možeš i na googletu Quote Share this post Link to post Share on other sites
Ivan 17666 Posted May 7, 2018 Imas i nasu temu: Quote Share this post Link to post Share on other sites
sashko 0 Posted May 11, 2018 (edited) pozdrav Jedan dan resih da odradim pranje sedista .Raskacim prednje izvadim ga napolje sve ja to lepo sredim i vratim sediste unitra posto je pao mrak sutra cu nastaviti.Sutra dan otkljucam i udjem u auto dam kontak da otvorim prozor i naravno skontah da sam se zezno jer nisam spojio konektor sedista na airbag i izbacuje mi sada gresku. Imam lm327 1.5 ali auto nema obd konektor nego moze li mi neko iskusan reci gde se tacno spaja i kako diagnostika da bih ponistio gresku. Cito sam ponesti i spominje se konektor sa tri pina ,ali to je za motor ispod haube sa leve strane ? Edited May 11, 2018 by sashko Quote Share this post Link to post Share on other sites
Citizen 0 Posted July 9, 2018 Jel koristi neko vdm2 dijagnostiku? Jel je ok za Lanciu? Poslato sa FRD-L09 uz pomoć Tapatoka Quote Share this post Link to post Share on other sites
SrdjanNS86 20 Posted August 7, 2018 Mala pomoc oko softvera multiecuscan.Instalirao sam nov Windows i opet instalirao program pa sam ga kasnije deinstalirao jer sam imao problema oko drajvera USB nebitno.Uglavnom opet sam instaliro program i uopste neprijavljuje da je registrovan.U pitanju je 1.4 verzija uzet preko foruma program i kablovi za dijagnostiku.Dali je potrebno kad se brise program brisati jos nesto iz nekih foldera sem odraditi uninstal i obrisati u program files ili ima jos negde da ostavlja tragove Quote Share this post Link to post Share on other sites
Danko77 6 Posted August 16, 2018 (edited) Pozdrav drugari kupio bih blutut dijagnostiku ELM 327 original, imao sam kinesku kopiju sa Aliexpressa ali nije radila na PUNTU, mozda je bila u kvaru ili sta vec pojma nemam, zamolio bih za pomoc gde nabaviti originalnu verziju ELM 327 dijagnostike blutut ili wifi verzija za mobilne telefone. Isto me zanimaju vasa iskustva sa pomenutom dijagnostikom da li se to isplati kupovati ili ne? Hvala. Edited August 17, 2018 by neshaoct spojeno Quote Share this post Link to post Share on other sites
lemy 24 Posted August 17, 2018 Ja kupio isto sa alija kao sa slike i nece ni jedan software da radi sa njime, navodno nije originalni čip... Mislim da nema veze sa autom nego sa tim čipom unutra. Dodouše skinuo sam i jos jedno 5 novih software ali nikako da probam posrto će da radi verovatno isto, tj nikako Quote Share this post Link to post Share on other sites
Home 56 Posted August 17, 2018 Imaš na kupujem prodajem 10 prodavaca koji imaju uređaje sa pravim elm327 softverom, mnogi misle da je elm327 oznaka čipa, ali nije već firmvera u čipu...postoji aplikacija koja proverava originalnost uređaja....nemoj da kupuješ one male plave ,a i ovaj sa slike svi kopiraju...ja ovaj što sam uzeo bukvalno otvara sve...čak može i kalibracija volana da se uradi, kao i da se resetuje ECU na nulti stanje....VEOMA KORISNA MOGUĆNOST. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted August 17, 2018 11 hours ago, Danko77 said: ...mozda je bila u kvaru ili sta vec pojma nemam C...nece da bude. Kolega @VladaNS mi rece da je otvarao tu sa alija i da je otvarao jednu koju je kupio valjda preko KP i da su unutra potpuno razlikuju...tako da...uvale nam Kinezi patku samo tako... Samo mi nije jasno, kupio sam uredjaj koji je imao tipa 3000 pozitivnih ocena...no dobro... Imate i ovde kod u partnerima kluba. Prodaje se uredjaj koji sigurno radi. Dosta ljudi je narucivalo Quote Share this post Link to post Share on other sites
djomla 8386 Posted August 17, 2018 3 hours ago, Home said: ovaj što sam uzeo bukvalno otvara sve...čak može i kalibracija volana da se uradi, kao i da se resetuje ECU na nulti stanje....VEOMA KORISNA MOGUĆNOST. Koji, gde, šta, kako? Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted August 17, 2018 11 hours ago, Danko77 said: Isto me zanimaju vasa iskustva sa pomenutom dijagnostikom da li se to isplati kupovati ili ne? Hvala. Pogledaj sada, nakon spajanja tema, sve ranije napisano u temi na kojoj smo. Sigurnost u kupovini dijagnostike dobijate kupovinom preko linka koji je Milutinac ostavio. Tu ne postoji šansa da ne radi, imate garanciju - sve funkcioniše kako treba. 1 Danko77 reacted to this Quote Share this post Link to post Share on other sites
mishja 1 Posted August 19, 2018 On 8/7/2018 at 5:57 PM, SrdjanNS86 said: Mala pomoc oko softvera multiecuscan.Instalirao sam nov Windows i opet instalirao program pa sam ga kasnije deinstalirao jer sam imao problema oko drajvera USB nebitno.Uglavnom opet sam instaliro program i uopste neprijavljuje da je registrovan.U pitanju je 1.4 verzija uzet preko foruma program i kablovi za dijagnostiku.Dali je potrebno kad se brise program brisati jos nesto iz nekih foldera sem odraditi uninstal i obrisati u program files ili ima jos negde da ostavlja tragove moras nekim programom obrisati sve, ja koristim revouninstaler kad brisem neki program, on obrise sve kljuceve i besplatan je On 8/17/2018 at 1:25 AM, Danko77 said: Pozdrav drugari kupio bih blutut dijagnostiku ELM 327 original, imao sam kinesku kopiju sa Aliexpressa ali nije radila na PUNTU, mozda je bila u kvaru ili sta vec pojma nemam, zamolio bih za pomoc gde nabaviti originalnu verziju ELM 327 dijagnostike blutut ili wifi verzija za mobilne telefone. Isto me zanimaju vasa iskustva sa pomenutom dijagnostikom da li se to isplati kupovati ili ne? Hvala. mislim da je tebi bolji kkl, ja imam jedan na prodaju i mogu ti doneti u Nis na probu sledece nedelje 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Danko77 6 Posted August 25, 2018 On 8/17/2018 at 9:38 AM, djomla said: Koji, gde, šta, kako? Ko to ima koja kinta? Jel se isplati kupovati elm 327 I jer se može raditi kalibracija volana;) sa njime? Koji je dobar uređaj posle elm 327? Quote Share this post Link to post Share on other sites
djomla 8386 Posted August 25, 2018 Nemam pojma, i ja se isto pitam.@Home čini mi se da je uzeo neki da valja. Sent from my 3310 Quote Share this post Link to post Share on other sites
