Martinnis13 1 Posted June 23, 2017 Unapred hvala Quote Share this post Link to post Share on other sites
Martinnis13 1 Posted June 24, 2017 Evo koji problem mene muči, ukratko... Povezivanje interfejsa uspešno, prikaz da je interfejs učitan uspešno, ali kada kliknem na test interfejsa tu izbacuje grešku, isto tako i sa povezivanjem motora... Quote Share this post Link to post Share on other sites
dobri nikola 15 Posted June 25, 2017 On 22.6.2017. at 11:10 AM, Martinnis13 said: Za multiecuscan nigde nisam mogao da crack ili licencni kljuc, ako neko ima bio bih mu zahvalan Ako ti odgovara verzija MES 3.0 imam krek za registrovanu verziju. Quote Share this post Link to post Share on other sites
dobri nikola 15 Posted June 25, 2017 Da li si uspeo da sredis MES? Quote Share this post Link to post Share on other sites
Martinnis13 1 Posted June 25, 2017 Ma neće, izgledami da je problem do kabla jer ima onaj cip ch340 kineski.... Ili me pak zeza zato što imam windows 10 Quote Share this post Link to post Share on other sites
dobri nikola 15 Posted June 26, 2017 ne znam, kod mene radi savrseno MES... Quote Share this post Link to post Share on other sites
Iron_Floyd 3 Posted June 27, 2017 On 6/25/2017 at 11:20 PM, Martinnis13 said: Ma neće, izgledami da je problem do kabla jer ima onaj cip ch340 kineski.... Ili me pak zeza zato što imam windows 10 Imao sam problem da nije hteo da mi se poveze na engine na punta 1.2 16v, ali kada sam stavio windows XP sve lepo radi.. Isto sam probao sa windows 10 u pocetku. Quote Share this post Link to post Share on other sites
turbopunto 0 Posted July 17, 2017 Da li neko imao iskustva sa ovim, poveze se preko bt lepo ali nista ne ocitava barem na telefonu, obrtaji pisu 200 itd...punto 2 jtd Quote Share this post Link to post Share on other sites
turbopunto 0 Posted July 18, 2017 Sa laptopa na multiscan nema sanse da se povezem, a na alfaobd izbacuje ovo obavestenje, samo preko scanmastera mogu da se povezem na bluetooth ali isto daje obrtaje 200, nesto ne radim kako treba, da li je neko imao slicno sa bt Quote Share this post Link to post Share on other sites
Martinnis13 1 Posted July 20, 2017 Najbolje rešenje, i ja sam kupovao te odb zajebancije i jeb*vao se dan i noć, neće ovo neće ono.... Lepo uznem ispobacam sve u kanti i kupim Delphi 150E i završim posao. Moja vam je preporuka da nadjete lepo delphi kao ja što sam našao potpuno ispravan za 6.000 na kupujem prodajem i završite se brige i nervoze. Quote Share this post Link to post Share on other sites
dobri nikola 15 Posted August 8, 2017 Da li neko ima licencni kljuc za MES 3.5 ili 3.6? Quote Share this post Link to post Share on other sites
mishja 1 Posted September 6, 2017 da li neko zna kako da se uradi patch, imam mes 3.6 al treba da se uradi patch a ja ne znam da uradim to Quote Share this post Link to post Share on other sites
dobri nikola 15 Posted September 6, 2017 Mozda bi Seki142 mogao da pomogne i detaljno objasni kako je uspeo da registruje MES 3,6. Quote Share this post Link to post Share on other sites
Seki1424 0 Posted September 7, 2017 Samo da stignen sa posla i da vam dam link odakle mozete da skinete patch napisacu i objasnjenje.Послато са Lenovo K50a40 уз помоћ Тапатока Quote Share this post Link to post Share on other sites
dobri nikola 15 Posted September 7, 2017 Danas dobih od drugara verziju MES 3.7 i kompletno odradjena kako bi bila registrovana. Ako mi u skorije vreme naleti fiatov auto testiracu koje su mogucnosti ove verije i ako je sve uredu zamolicu drugara da mi objasni gde je skinuo program sa patch-om. Pa bi rado podelio sa vama, pozdrav svima... Quote Share this post Link to post Share on other sites
Seki1424 0 Posted September 8, 2017 https://mega.nz/#!9rAD0C7Y!8Tx5fs9ycrRSLh3wPFkw2MNFwXJ-ePbukUkObHXkkv8Postupak prvo raspakujte oba zip fajl, ja nisam ih raspakovao, samo sam ih otvorijo i nije prihvatio. 1. Deinstalirajte predthodne verzije2. Install SetupMultiecuscan36.msi3. Iz fodera Multiecuscan_3.6_Full_(Patch+key)_By_MrRorry\Multiecuscan_3.6_Full_(Patch+key)_By_MrRorry\Patch_Multiecuscan\Patch_Multiecuscan sve prekopiras u folder C:\Program Files\Multiecuscan.4. Zatvorite prozor i sa desktopa pokrrnite program.Kada se pokrene dole levo imate prozor za registraciju udjete u njega i u doljnem pravugaojiku upisete serial key: 77C1B-20088-32A2585. Multiecuscan ce se restartovati.6. Program je resgistrovan.PS. Program sam nasao na Youtube, probao i uspeo sam da ga registrujem na ovaj nacin ali nemam uredjaj da proverim da li on zaista radi.Ako je protiv pravila FLCS ja se izvinjavam.Послато са Lenovo K50a40 уз помоћ Тапатока Quote Share this post Link to post Share on other sites
dobri nikola 15 Posted September 11, 2017 Nemogu sebi da oprostim sto nisam sa MES-om odradio dijagnostiku stila 1,8l 97kw i da vidim kako program radi. Greska na stilu je P0122. U pitanju je problem sa pedalom gasa, da li neko ima el. semu za taj auto, pogledao bih raspored zica na papuci gasa... Quote Share this post Link to post Share on other sites
Ivan 17587 Posted September 11, 2017 (edited) Imas ovde kompletan eLearn za Stilo (tehnicki podaci, opisi, procedure, ozicenje, konektori i jos mnogo toga): Edited September 11, 2017 by Ivan Quote Share this post Link to post Share on other sites
Martinnis13 1 Posted September 13, 2017 On 8.9.2017. at 7:48 PM, Seki1424 said: https://mega.nz/#!9rAD0C7Y!8Tx5fs9ycrRSLh3wPFkw2MNFwXJ-ePbukUkObHXkkv8 Postupak prvo raspakujte oba zip fajl, ja nisam ih raspakovao, samo sam ih otvorijo i nije prihvatio. 1. Deinstalirajte predthodne verzije 2. Install SetupMultiecuscan36.msi 3. Iz fodera Multiecuscan_3.6_Full_(Patch+key)_By_MrRorry\Multiecuscan_3.6_Full_(Patch+key)_By_MrRorry\Patch_Multiecuscan\Patch_Multiecuscan sve prekopiras u folder C:\Program Files\Multiecuscan. 4. Zatvorite prozor i sa desktopa pokrrnite program. Kada se pokrene dole levo imate prozor za registraciju udjete u njega i u doljnem pravugaojiku upisete serial key: 77C1B-20088-32A258 5. Multiecuscan ce se restartovati. 6. Program je resgistrovan. PS. Program sam nasao na Youtube, probao i uspeo sam da ga registrujem na ovaj nacin ali nemam uredjaj da proverim da li on zaista radi. Ako je protiv pravila FLCS ja se izvinjavam. Послато са Lenovo K50a40 уз помоћ Тапатока Seki1424, radi odlično I ako koristim delphi skinuo sam da probam da bih vam rekao Quote Share this post Link to post Share on other sites
dobri nikola 15 Posted September 14, 2017 Molio bih za pomoc okospomenute el. seme za stila 1.8 16V 97KW, hvala na razumevanju... Quote Share this post Link to post Share on other sites
Martinnis13 1 Posted September 14, 2017 P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input Nisam imao takvih problema, ali iz druge priče kontam i mislim da ti je otišao senzor za kočnicu.... Evo linka kako se menja senzor: Quote Share this post Link to post Share on other sites
mishja 1 Posted September 22, 2017 (edited) MES 3.7 sa krekom https://mega.nz/#!rsFBmKxY!lO1MbZf-WvzFOV69stXigsTDr0uMG0n2u1OHHPy3veE cepaj dok ima Edited September 22, 2017 by mishja Quote Share this post Link to post Share on other sites
dobri nikola 15 Posted September 23, 2017 Steta je sto nisu objasnili kako se skida jer ni najmanje nije naivno. Quote Share this post Link to post Share on other sites
Pluto 448 Posted September 24, 2017 Koji kabal treba da bih povezao na komp? Gde mogu da ga kupim? Quote Share this post Link to post Share on other sites
dobri nikola 15 Posted September 25, 2017 Moja preporuka je da uzmes elm327, po mogucstvu sa aluminijumskim kucustem. Pokazali su se boljim u odnosu na plasticna kucista, program ces skinuti sa foruma i slobodno radi dijagnostiku u kucnoj varijanti... Quote Share this post Link to post Share on other sites
