Djuk85 2984 Posted January 29, 2019 Pa da, tako bi trebalo biti zato i jeste glupava situacija... Verujem da je blagi šok za grejace verglanje dok oni jos rade... Quote Share this post Link to post Share on other sites
MS PK 7729 Posted January 29, 2019 Rade oni i dok je upaljen neko kratko vreme Quote Share this post Link to post Share on other sites
bit 936 Posted January 29, 2019 A šta reći, a ne zaplakati , probaj prepipati sve kablove, utakni istakni, negde ga neki kontakt verovatno muči, takođe osigurače sve izvadi pa vrati.... Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted January 29, 2019 Videcemo nije problem, pali i radi auto normalno kad znam za caku, samo mi zanimljivo pa rekoh da priupitam... Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted March 4, 2019 Auto celu zimu drzao dobro temperaturu i sad kad je otoplilo on ne prelazi drugu crtu... Svi termostat menjaju pred zimu samo cu ja morati pred leto... Quote Share this post Link to post Share on other sites
danijel55 699 Posted March 4, 2019 I bolje, zimi kad ode nema grejanja,a sada ti grejanje ne treba ni za sta. Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted March 4, 2019 I to si upravu sad ne moram da zurim toliko sa zamenom.. Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted March 4, 2019 Imas vremena do zime da skupis kintu za onaj sa R4 1 Djuk85 reacted to this Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted March 4, 2019 Pa da, pogresio sam...to i nije zamena, samo dodatak Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted March 13, 2019 Malo osvezavanje pred leto 3 neshaoct, alfini0507 and Martin reacted to this Quote Share this post Link to post Share on other sites
neshtry 14785 Posted March 13, 2019 Takve bbs sam imao na Ascona. Dopada mi se taj oldtajmer dizajn Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted March 13, 2019 Veci sam ljubitelj jednostavnijih felni...petokrake na primer bar ne moram da koristim cetkicu za zube kad ih perem Ove su dosle uz auto pa ih trpim... 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
neshtry 14785 Posted March 13, 2019 Petnaestice? Quote Share this post Link to post Share on other sites
neshtry 14785 Posted March 13, 2019 Extra za Punta Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted March 13, 2019 Pa kupio bih ja Punta nego mi ne odgovara tako mali auto trenutno Juce sam uspeo da smestim zenu i dva decija sedista pozadi mislio sam da nece moci ali se uglavise nekako... Quote Share this post Link to post Share on other sites
neshtry 14785 Posted March 13, 2019 Pozadi je slično,mala je razlika.Ali je gepek baš malecan u Puntu. Probao u Marei hgt 20v Quote Share this post Link to post Share on other sites
MS PK 7729 Posted March 13, 2019 Udri sredinu u zlatnu 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted March 13, 2019 Razmislicu o tome do jutra Quote Share this post Link to post Share on other sites
MS PK 7729 Posted March 13, 2019 Ako, polako pozuri 1 Djuk85 reacted to this Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted March 15, 2019 Stavih letnje gume Nesto gledam na ovim michelinkama ne pise smer rotacije gume, samo OUTSIDE... Jel to znaci da je bitno samo koja je spoljna strana a ne i rotacija? Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted March 15, 2019 Bas tako 2 neshaoct and Djuk85 reacted to this Quote Share this post Link to post Share on other sites
MS PK 7729 Posted March 15, 2019 Spoljna strana i rotacija ti dodju jedno te isto, zar ne? Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted March 15, 2019 Nije isto ovde nema veze sa koje strane auta se stavlja tocak.. Quote Share this post Link to post Share on other sites
Ivan 17587 Posted March 15, 2019 I slazem se i ne slazem . Kod usmerenih guma, bitno je da se okrecu u pravcu koji je oznacen strelicom na boku i nema premestanja sa strane na stranu vozila, samo napred/nazad (ako pricamo u kompletu sa felnom). Kod asimetricnih guma treba ispostovati oznaku OUTSIDE, koja oznacava stranu koja treba da bude spoljna (slucaj kod tebe) i u pravu si za nove gume. Ali ako su koriscene, nije pozeljno prebacivati ih sa jedne na drugu stranu vozila, jer iako jeste ispostovana OUTSIDE strana, nastavice da se vrte u kontra smeru od prethodno "naostrene" sare. Sto moze da ima negativne posledice (tresenje, buka, vucenje u stranu i sl.). Problematika za razmisljanje i ko kupuje polovne gume. Mislim da sam cak vidjao (ali su vrlo retke) i usmerene asimetricne gume, koje imaju i smer rotacije i OUTSIDE stranu. Quote Share this post Link to post Share on other sites
