bit 937 Posted February 18, 2021 Skinuo pa išao kupovati, zanitovao opet, mogao sam i šarafe staviti... Pusti me u... Mogao sam završiti za sat ipo... Sad sam raskopusao čitava vrata https://streamable.com/iletas Quote Share this post Link to post Share on other sites
Martin 799 Posted February 19, 2021 Budi jak. 1 bit reacted to this Quote Share this post Link to post Share on other sites
bit 937 Posted February 23, 2021 Završio to, nije bilo šarafa viška , ko što nekad bude, ali moraću ponovo.Posao je stresan prvi put, drugi put limunada. zvučnik sam izvadio pa još ne znam šta da uradim, kupim nove, polovne, ili da se zezam pa restauriram stare, to vešanje da obnovim, moram otići do kafane gde dolazi moj stari drugar koji se sa ozvučenjem bavi pro, a nikako da mi se da da odem, pre podne... Inače uopšte ne znam zašto sam sam to radio... Verovatno iz dosade.Pozdrav. 4 djomla, Djuk85, Martin and 1 other reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted February 23, 2021 Kupi polovne kod Bakica, 500din komadПослато са SM-A307FN помоћу Тапатока 1 bit reacted to this Quote Share this post Link to post Share on other sites
bit 937 Posted March 11, 2021 Idemo...FAP mašina, prvo paljenje od 15.avgusta 2020. Ako se neko pita gde kilometar sat, tu je pored mene gde i miševi... https://streamable.com/572buz I fini ler rad https://streamable.com/okgp87 2 Djuk85 and Martin reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted March 11, 2021 Fap masina pali na "čvrgu" jedina Послато са SM-A307FN помоћу Тапатока 1 bit reacted to this Quote Share this post Link to post Share on other sites
Martin 799 Posted March 12, 2021 Idi bre, sve pčele si rasterao! 1 bit reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3445 Posted March 12, 2021 Misliš, pomrele ... 1 bit reacted to this Quote Share this post Link to post Share on other sites
bit 937 Posted April 24, 2021 Eko FAP u napadu https://streamable.com/gzttwbVoćnjak jabuke delta agrar čelarevo.Ogroman voćnjak 6-7km duž asfalta samo. 2 MS PK and Djuk85 reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3445 Posted April 24, 2021 (edited) Jbte, ne čuje se! Edited April 24, 2021 by Mijailović P. 1 bit reacted to this Quote Share this post Link to post Share on other sites
bit 937 Posted September 18, 2021 E da, tamo negde u u julu, ne ide fjato nikako dan, dva, gas do poda on ništa, odem kod mog majstora on sa vrata odmah vakum ventil turbine, dobro.Kupim u prvoj online prodavnici fiatshop mislim da beše oko 6000din, piše da je švapski. Majstor zameni i ono crevo dvokrako od filtera do motora i turbine, i uradimo mali servis sa filterom vazduha, bilo znojavo i verovatno par rupica čim je znojavo.Fjato opet na nokat na gasu čupa. 2500 dinarijos ruke..... Odneo mu sutra dve tegle meda. 4 Djuk85, MS PK, stex_pb and 1 other reacted to this Quote Share this post Link to post Share on other sites
bit 937 Posted December 3, 2021 Pomoć prijatelji , auto na servisu, veliki servis 50000, mali, sajla ručne, i sitnice zadnja prskalica, amortizeri 5 vrata...Neće da pali kao što je nekada (sumnjamo u regulator pritiska) to će sutra prvo paljenje sa dijagnostikom. Nego maehaničar je imao problem sa nabavkom nosača motora (uklanjanje vibracija) uzimao je iz 3 prodavnice i ni jedan ne pasuje... On mi je ovu sliku poslao. Jel tsj treba ili... Quote Share this post Link to post Share on other sites
bit 937 Posted December 3, 2021 E da svi cilindri su proverereni 25bara, kao i dizne kod bošiste, sve ok. 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted December 4, 2021 25 i preko ide kod novih motora, koliko znam Sto ne stavis odma nosac od benzinca?Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
bit 937 Posted December 4, 2021 Ma pusti, prepao me mehaničar, kže brže vergla možda je motor otišao, ima stariji ali odličan uređaj za merenje kompresije, ubacuje se kartica (papirna), ima iglu za iscrtavanje (prbi put gledao merenje), kad je prvi pokazao 25 pa drugi, treći, ostao četvrti kad je i četvrti pokazao 25, laknulo mi. Zašto i kako od benzinca, koji. Quote Share this post Link to post Share on other sites
Ivan 17650 Posted December 4, 2021 (edited) 4 hours ago, bit said: Ma pusti, prepao me mehaničar, kže brže vergla možda je motor otišao Identican utisak kao kada prvi put tamo 2008., za JTD kupih Exide od 760A udarne struje . Edited December 4, 2021 by Ivan 1 bit reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted December 4, 2021 Od benzinca 1.8 bese, ne znam, iz razloga sto je odlican a jeftin valjda. Znam da svi stavljaju Послато са SM-A307FN помоћу Тапатока 1 bit reacted to this Quote Share this post Link to post Share on other sites
darkman14 5900 Posted December 4, 2021 Jeste od 1.8 benzinca, duplo je jeftiniji ali mora šraf sa starog nosača jer je od benzinca kraći. Mislim da je to to koliko me sećanje služi 2 MS PK and bit reacted to this Quote Share this post Link to post Share on other sites
bit 937 Posted December 5, 2021 Dobro, sutra ću mu to preneti za šraf, verovatno su mu taj i dali, rekao mi je da je kraći i da motor ostane na aluminijumu I da vidim šta mu je dijagnostika rekla za to teško jutarnje paljenje, koliko sam čitao, može biti pogrešno očitavanje temperature, map sensor, regulator pritiska i to je to Quote Share this post Link to post Share on other sites
MS PK 7732 Posted December 5, 2021 ...dizne, pumpa , alnaser, akumulator,egr... Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
bit 937 Posted December 6, 2021 Javio mi jutros, kaže na regulatoru skače i pada pritisak od 40-90 bara(valjda).Tako da će regulator ovog puta polovan biti naručen iz inđije, ženica daje garanciju.... pa ako nije on da ne bi bilo... To što si pobrojao je prekontrolisano i ok je, ja sam sumnjao na dizne međutim bile su kod bošiste na stolu, sve su ok. I moram šoferku menjati, kvrcnula, nova da ugradnjom 14.500, jel to ok, ili da pitam ovu gospođu iz inđije. Quote Share this post Link to post Share on other sites
Ivan 17650 Posted December 6, 2021 Vidi samo koja soferka je u pitanju. Ako je slucajno nesto kvalitetnije (Saint Gobain, Pilkington), to je odlicna cena. 23 minutes ago, bit said: ja sam sumnjao na dizne međutim bile su kod bošiste na stolu, sve su ok Bas me cudi za JTD . 1 bit reacted to this Quote Share this post Link to post Share on other sites
bit 937 Posted December 6, 2021 Baš ću da zovnem i pitam, i zaboravih da mu kažem da je tonirana zelenkasta. Quote Share this post Link to post Share on other sites
ISV_01 4032 Posted December 6, 2021 49 minutes ago, bit said: , kvrcnula, nova da ugradnjom 14.500 Slicno cenovna je moja, nije Gobain kao sto Ivan kaze, OEM i od njih su dosta skuplje. Ova moja je neki poljak, ok je. Menjao u Car Glass. Quote Share this post Link to post Share on other sites
Ivan 17650 Posted December 6, 2021 Uzimali su ljudi svojevremeno Saint Gobain u nekoj firmi u Sapcu za cca 18.000 din za Stilo. Secam se da je bilo bas povoljno. E sad, ne vozim Stilo vec skoro 4 godine, pa nemam ni blizu detaljnih informacija kao ranije. Quote Share this post Link to post Share on other sites
