zunto 513 Posted July 5, 2018 E60 li je dobar auto?Послато са SM-N9005 уз помоћ Тапатока Share this post Link to post Share on other sites
Ticma 535 Posted July 5, 2018 Jeste dobar, ako nije lesina Sent from my SM-N950F using Tapatalk Share this post Link to post Share on other sites
zunto 513 Posted July 5, 2018 Jeste dobar, ako nije lesina Sent from my SM-N950F using TapatalkJa videh samo les do lesaПослато са SM-N9005 уз помоћ Тапатока Share this post Link to post Share on other sites
Ticma 535 Posted July 6, 2018 Mogu da budu ok, ako se spuca u njih 2k€ Sent from my SM-N950F using Tapatalk Share this post Link to post Share on other sites
zunto 513 Posted July 6, 2018 Mogu da budu ok, ako se spuca u njih 2k€ Sent from my SM-N950F using TapatalkJa cu lajem ako sa 2000 eur resis bilo koji e60 . Uglavnom bolji e60 napolju nema ispod 10000. Auto kao auto pun bagova i gluposti koje izvode iz takta. 159 je po pitanju pouzdanosti enterprajz za vecinu Bavaraca.Послато са SM-N9005 уз помоћ Тапатока Share this post Link to post Share on other sites
dellas 1556 Posted July 6, 2018 Ja sam upucao preko soma brzinski u odlican primerak proveren, sa full servisnom istorijom u ovlascenom servisu. I imam jos par stvari da resim onako u hodu, 2k je optimalna cifra za svaki auto iz tih godina. 1 Axic reacted to this Share this post Link to post Share on other sites
DraganUS 450 Posted July 6, 2018 Na sta si ti spucao soma. Mehanicki?Sent from my SM-J710F using Tapatalk Share this post Link to post Share on other sites
totti 13160 Posted July 6, 2018 Valjda na čašćavanje drugara Sent from my SM-G950F using Tapatalk 1 djomla reacted to this Share this post Link to post Share on other sites
dellas 1556 Posted July 6, 2018 Zajedno sa cascavanjem Soma sam spucao u mali servis, zastita od kradje, gume, felne, letva, ccc modul - felne koje sam prodao, tu je preko soma. Imam jos neke gumice balans stangle da zamenim, da uradim "veliki servis" tj set pk kaisa i da zamenim senzor nivoa ulja. A uvek ima i ulepsavanja, distanceri, stakla, poliranje... Racunaj uvek 2 soma preko da dobar primerak. Share this post Link to post Share on other sites
MS PK 7729 Posted July 6, 2018 U bre...nista od toga nisi morao da radis..sem cascavanja Послато са SM-J330F уз помоћ Тапатока Share this post Link to post Share on other sites
zunto 513 Posted July 6, 2018 Zajedno sa cascavanjem Soma sam spucao u mali servis, zastita od kradje, gume, felne, letva, ccc modul - felne koje sam prodao, tu je preko soma. Imam jos neke gumice balans stangle da zamenim, da uradim "veliki servis" tj set pk kaisa i da zamenim senzor nivoa ulja. A uvek ima i ulepsavanja, distanceri, stakla, poliranje... Racunaj uvek 2 soma preko da dobar primerak.Slazem se samo za ccc modul, ovo ostalo je tvoj cef. Dakle nasao si dobar primerakПослато са SM-N9005 уз помоћ Тапатока Share this post Link to post Share on other sites
vagenovac 4533 Posted July 6, 2018 Slicno sam i ja prosao sa e60, jedan ksenon malo potamnio, zamenio obe original sijalice, zadnja kociona creva bila su malo losija samo smo to nasli pri pretresu auta, nove letnje gume, mali servis sa separatorom, zastita od kradje i eto nas na hiljadu evra skoro, a bez ulaganja. Nije tesko naci odlican e60, kao ni 159, samo retko ko je spreman da plati. Share this post Link to post Share on other sites
Ticma 535 Posted July 6, 2018 Naravno, svi bi za male pare dobar auto.Moj problem je sto ne mogu dugo da vozim jedna kola i sto me svaka sitnica nervira pa moram da je sredim Sent from my SM-N950F using Tapatalk 1 skile86 reacted to this Share this post Link to post Share on other sites
DraganUS 450 Posted July 6, 2018 Nadji neki hobi. Mani se kola. Sent from my SM-J710F using Tapatalk 2 PremieRacing and knezevic76 reacted to this Share this post Link to post Share on other sites
zunto 513 Posted July 6, 2018 Svaki auto preko 6 godina je MATORПослато са SM-N9005 уз помоћ Тапатока Share this post Link to post Share on other sites
djomla 8386 Posted July 6, 2018 Bolje se drogiraj k'o sav normalan svet Sent from my 3310 Share this post Link to post Share on other sites
Ticma 535 Posted July 6, 2018 Ali ali ali, TFSI i 225ks 🤤Sent from my SM-N950F using Tapatalk Share this post Link to post Share on other sites
MS PK 7729 Posted July 6, 2018 To ti pricam Послато са SM-J330F уз помоћ Тапатока Share this post Link to post Share on other sites
marko.jovanovic 925 Posted July 7, 2018 9 hours ago, Ticma said: Ali ali ali, TFSI i 225ks Sent from my SM-N950F using Tapatalk Oktavia RS? Share this post Link to post Share on other sites
Ticma 535 Posted July 7, 2018 Nesto na Q Sent from my SM-N950F using Tapatalk Share this post Link to post Share on other sites
djomla 8386 Posted July 7, 2018 Q5? Sent from my 3310 Share this post Link to post Share on other sites
Ticma 535 Posted July 7, 2018 Pa, recimo, ali to posle odmora tek, mora da se poklopi par stvari.Sent from my SM-N950F using Tapatalk Share this post Link to post Share on other sites
zunto 513 Posted July 7, 2018 Q5Послато са SM-N9005 уз помоћ Тапатока Share this post Link to post Share on other sites
Ticma 535 Posted July 7, 2018 Mhm Sent from my SM-N950F using Tapatalk Share this post Link to post Share on other sites
MS PK 7729 Posted July 7, 2018 Samo S fali Послато са SM-J330F уз помоћ Тапатока Share this post Link to post Share on other sites
