deyoooooo 3 Posted November 22, 2017 (edited) Pozdrav, da li je neko skidao skije (nosace na krovu na koje se kace klasicni nosaci) sa Stila karavana? Jedna mi se otpustila pa pravi dosta buke u voznji. Vidim postoji kao neki poklopac, verovatno je ispod vijak na samoj skiji... Ali ne mogu da ga skinem, a bojim se da ga ne polomim. Kako da ga skinem bez upotrebe prekomerne sile? Evo dve slike da ne bude zabune gde imam problem. Hvala. Edited March 13, 2018 by Ivan Sredjen post i slike Quote Share this post Link to post Share on other sites
deyoooooo 3 Posted November 30, 2017 Zar niko to nije skidao.:( Quote Share this post Link to post Share on other sites
Punto Abarth 18 Posted December 10, 2017 Najverovatnije se srafi odozdo, tj kad skines ili odvojis nebo Quote Share this post Link to post Share on other sites
deyoooooo 3 Posted December 10, 2017 Ne verujem da je odozdo jer od kad sam farbao auto od tad mi se cuje. Verovatno su to skidali jer im je lakse ofarbati i nisu dobro vratili, a ne vidim da su nebo dirali. Quote Share this post Link to post Share on other sites
deyoooooo 3 Posted March 13, 2018 Pomozite ljudi molim vaaaasss! Quote Share this post Link to post Share on other sites
djomla 8386 Posted March 13, 2018 (edited) Mora nekako da se skine, ispod su šrafovi. Edited March 13, 2018 by Ivan Ubacena velika/zumirana slika iz ePer-a 1 Ivan reacted to this Quote Share this post Link to post Share on other sites
Ivan 17670 Posted March 13, 2018 (edited) 2 hours ago, deyoooooo said: Pomozite ljudi molim vaaaasss! Aj' da bacimo pogled u cemu je toliki problem ... U eLearn ih zovu "Longitudinal Support for Roof Rack Bars", sifra je 7065C19... Evo i sazvakano do detalja - pozicije i broj srafova kao i procedura (de)montaze: Ukoliko je u pitanju zadnji deo nosaca, evo i jos dve linkovane seme. - 7055A62 - Moulding on One Pillar: - 7040B23 - Back Upper Side Trim: Edited March 13, 2018 by Ivan Quote Share this post Link to post Share on other sites
djomla 8386 Posted April 29, 2018 I, sta bi na kraju? Uspeo li si da skines nosače? Sent from my 3310 Quote Share this post Link to post Share on other sites
deyoooooo 3 Posted May 13, 2018 (edited) Izvinjavam se sto nisam stigao ranije da odgovorim. Uspeo sam skinuti i i resiti problem. Plastika se skida povuce se malo prema napred i ravno prema gore se bukvalno iskine iz jedne zabice. Samo sto je kod mene vec bila polomljena i lepljena pa sam je i ja slomio. Ali sam zalepio i vratio i sad je ok. Problem nije bio odvrnut saraf nego kao da se pojavio neki luf izmedju skije i tog prednjeg njenog nosaca. Pa sam zaglavio trakicu lima debljine 0.5mm na tesno i samo vratio plastiku i resen problem. Evo i par slika kako to sve izgleda rastavljeno ako nekom nekad bude trebalo. Hvala svima na pomoci. Edited May 14, 2018 by Ivan Sredjene slike 2 1 Djuk85, Ivan and djomla reacted to this Quote Share this post Link to post Share on other sites
