sanja.obradovich 8 Posted November 23, 2017 Ali nisi imao problema sa Lukas pumpom? Quote Share this post Link to post Share on other sites
cuore_sportivo 79 Posted November 23, 2017 To jeste..ali ako tako razmisljas onda neces nikada nigde putovati samo opusteno,preventivni pregled pre puta i vozi. Quote Share this post Link to post Share on other sites
sanja.obradovich 8 Posted November 23, 2017 Realno gledano, u pravu si Sa psihološke neke strane- Strah sprečava ljude da žive punim plućima. Quote Share this post Link to post Share on other sites
dellas 1556 Posted November 23, 2017 Letos sam isao na more silom prilika punticem doduse 1.2 16v i vrlo se korektno pokazao, nekih 750-800km u jednom pravcu. Nije za vece brzine na AP ali do 130-40 je sve ok. 1 cuore_sportivo reacted to this Quote Share this post Link to post Share on other sites
sanja.obradovich 8 Posted November 23, 2017 120km/h je i ograničenje. Pa preko i nema potrebe. Quote Share this post Link to post Share on other sites
Ivan 17670 Posted November 23, 2017 Nema . Maksimalno vozim 119 km/h kod nas na autoputu, a 79 km/h na magistrali. Kroz Hrvatsku na AP znam da nagazim i do 129 . Quote Share this post Link to post Share on other sites
dellas 1556 Posted November 23, 2017 On 11/23/2017 at 3:19 PM, sanja.obradovich said: 120km/h je i ograničenje. Pa preko i nema potrebe. Ako ti je u planu da usput malo i odspavas, onda nema Quote Share this post Link to post Share on other sites
sanja.obradovich 8 Posted November 23, 2017 Ja sam ovog mog pre dva meseca vozila 150km/h na AP kod Čačka. Sada nekada magistralom kada ga poteram 110km/h već imam osećaj da će motor kočiti iz haube. Quote Share this post Link to post Share on other sites
gorank82 183 Posted November 23, 2017 Postavi ovde i neku svoju sliku da svi budu zadovoljni 1 cuore_sportivo reacted to this Quote Share this post Link to post Share on other sites
sanja.obradovich 8 Posted November 23, 2017 Mašem vam. 1 gorank82 reacted to this Quote Share this post Link to post Share on other sites
sasha015 34 Posted November 23, 2017 Savet je da ne vozis 150 kmh po autoputu,ili 100 po magistrali jer taj auto nije za te brzine. Nije bio ni kad je bio nov, a kamoli sad. Ne znam kako 1.9 d i moze da ide 150 kmh a da se ne raspadne. Nebitno.... Pre putovanja auto u neki dobar servis na pregled i na tehnicki da proveris ispravnost kocnica na valjcima. Uplatis ams clanarinu ili neku drugu pomoc na putu. Poneses dovoljno kesa da imas za slucaj nepredvidjenih okolnosti,tipa 400-500 evra i karticu sa dosta lova. isplaniras rutu putovanja,dobro se naspavas i krenes,Ja bih negde spavao i put podelio na dva dela. Dobro raspolozenje i bez straha. Sretno. Quote Share this post Link to post Share on other sites
sanja.obradovich 8 Posted November 23, 2017 Da imam 400-500e keša i karticu sa dosta love, ne bi se vozio punto. Ali, saveti su ti svakako na mestu. Hvala. Quote Share this post Link to post Share on other sites
Markobgd 609 Posted November 23, 2017 Sa istim motorom u Doblu (doduše malo jačim jer ima onih 46kw ranije pominjanih) sam prešao Srbiju xy puta uzduž i popreko ili ti dobrih preko 220kkm bez da me auto ostavio na putu. Sa pumpom imam taj "problem" od prvog dana kada sam kupio auto i evo još malo 9 godina se tako vozim. Opusti se i uživaj... Quote Share this post Link to post Share on other sites
sanja.obradovich 8 Posted November 23, 2017 To mi kaži, bre! Quote Share this post Link to post Share on other sites
igor0511 2882 Posted November 23, 2017 (edited) Krenulo je sa reakcijama na poruke, a ima da zavrsimo kao drustvena mreza gde cemo da kacimo slike Za ove novije clanove par saveta: 1) Postoje privatne poruke da ne morate javno da pitate devojke za godine 2) Kada smo to savladali svakako ne pitajte devojke za godine 3) Ako ste bas pitali i dobili nakon toga sliku, barem udarite taj like kad ih je vec Nesa otkljucao A sto se kola tice 400-500km je sprdnja za bilo koji ispravan auto, a i za bilo kog zdravog vozaca. Astra 1.4 nije mnogo brza od tog Punta niti ima tempomat pa je moji roditelji uredno odvezu i po 1000km u jednom smeru. Edited November 23, 2017 by igor0511 1 sanja.obradovich reacted to this Quote Share this post Link to post Share on other sites
sanja.obradovich 8 Posted November 23, 2017 ^ Samo još da me vreme posluži i sve će da bude super. I recite mi vi koji ste iz Srbije, gde nalazite "čepove" za blok motora? U CG nema nigde da se kupe i bukvalno sam za 3 čepića platila 30e, plus 30e ruke. Ako mi drugi put zatreba, da znam. Quote Share this post Link to post Share on other sites
totti 13165 Posted November 23, 2017 On 11/23/2017 at 5:01 PM, sanja.obradovich said: Mašem vam. Evo i ja mašem 1 3 gorank82, igor0511, Markobgd and 1 other reacted to this Quote Share this post Link to post Share on other sites
silenci 2337 Posted November 23, 2017 a srecan put i samo polako,nema 150 na sat,pre svega hrvatska policija je rigorozna postuj ogranicenja a samo pre puta proveri sve tecnosti,ponesi neku litru vode cisto da se nadje i cepaj,ovaj motor jest na papiru slab sa 60 konja,al nije za bacanje,moze i on da grize,ja sam sa njim isao u tivat 530 km,skoro bez stajanja,jos 2008me Quote Share this post Link to post Share on other sites
VladaG9 147 Posted November 23, 2017 @sanja.obradovich Moji prijatelji su putovali iz parizA do Skoplja i nazad,u pravcu oko 2500km. Upravo sa tim autom punto 2 i 1.9D motorom,i sve je bilo ok. Ja sam putovao u Grcku sa Puntom Classic 1.3mjet . U principu nije bas najudobnije za duzi put. Mogu njih da zamislim ,ali moze da se izgura. Samo da je auto ispravan. A pogotovo taj 1.9 motor. Quote Share this post Link to post Share on other sites
silenci 2337 Posted November 23, 2017 to cimanje je najvise zbog broja obrtaja,trazi malo veci broj obrtaja,to ja tako,nije neki problem,najveci problem puntu je city servo,ako je slabiji akumulator odmah se iskljucuje servo i posle muke,zato proveri napon akumulatora Quote Share this post Link to post Share on other sites
sanja.obradovich 8 Posted November 23, 2017 Da li je previše za motor nagaziti 70km/h trećom brzinom i onda šaltati u četvrtu? Sa city servom problema nikada nisam imala i uvek je uključen. Quote Share this post Link to post Share on other sites
silenci 2337 Posted November 23, 2017 moze,al najbolje do 60 na sat pa menjaj u cetvrtu 1 jocifer93 reacted to this Quote Share this post Link to post Share on other sites
Ivan 17670 Posted November 23, 2017 2 hours ago, igor0511 said: A sto se kola tice 400-500km je sprdnja za bilo koji ispravan auto, a i za bilo kog zdravog vozaca. Apsolutno se slazem, bas sprdnja. I da je varijanta magistrale i da vozis laganica u najgorem slucaju hvatas prosek minimum 60 km/h a to je 7-8 sati voznje, autoputem oko 40% manje. Jos vise se slazem za ono pod stavkom 2. Nego, seca li se neko kada je Dejica kacio slike Webasta u Stilu ? @totti Generacijo, nikad bolje nisi izgledao . Quote Share this post Link to post Share on other sites
sanja.obradovich 8 Posted November 23, 2017 On 11/23/2017 at 6:41 PM, totti said: Evo i ja mašem Bila bi dobra fora, samo, da sam i ja stvarno skinula fotku sa neta. Ovako, nice try. 1 gorank82 reacted to this Quote Share this post Link to post Share on other sites
DraganUS 450 Posted November 23, 2017 Ne znam da li napisano, ali kojim putem planiras? Quote Share this post Link to post Share on other sites
