Milutinac 5906 Posted October 6, 2017 Nema odustajanja samo napred... Vidis sta vec imas navijaca Quote Share this post Link to post Share on other sites
DraganUS 450 Posted December 18, 2017 Izmerio kompresiju. Na svim je oko 11bara. Lezaj na radili koji je okrenuo je Vlada zamenio i nije se vise bakcao sa tim. Ja sam pogresno shvatio misleci da je jos tamo i cudio kako auto ne lupa. Medjutim kad sma skinuo karter dole je sve bilo u redu. Skinuo jedan leteci i izgleda ok. Ostali svi na mestu. Nije se stiglo skinuyi pumpu ali ce ona najverovatnije napolje i nova unutra. Na kraju polovna radilica na standardu i srediti kako treba. Quote Share this post Link to post Share on other sites
DraganUS 450 Posted March 12, 2018 Da bacim update pre vađenja motora za koji dan. 4 1 gorank82, neshaoct, PremieRacing and 2 others reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 12, 2018 Odakle tebi te felne??? Haaaa??? Quote Share this post Link to post Share on other sites
DraganUS 450 Posted March 12, 2018 Da si u BGu bio, felne bi dobio. Dobio drugaraku cenu, a komsina mi je 3 min od mene. Quote Share this post Link to post Share on other sites
jevta BG 111 Posted March 12, 2018 Pocinje pravljenje Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted March 12, 2018 Cucnule su profi Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 12, 2018 Eeeeeee jbg Dragane! Okasnio sam izgleda @Danilo1 - tvoje felne stvarno? Quote Share this post Link to post Share on other sites
Ivan-Topola 329 Posted March 12, 2018 (edited) 5 minutes ago, Danilo1 said: Da da Pa gde si bre ti DG jbt? Opario si se.. zato danas lutas po gradu, vidjen si, posle 3 meseca si sisao sa padine do grada malo.. Inace, felne su cucnule da bolje ne moze, pravi izbor! Edited March 12, 2018 by Ivan-Topola Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted March 12, 2018 @Ivan-Topola Druze ne secam se kada sam vozio Stila poslednji put skupljam polako pare za Brava.. Ako ti treba nesto od delova, tu sam 1 Ivan-Topola reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 13, 2018 10 hours ago, Danilo1 said: Da da Eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee Quote Share this post Link to post Share on other sites
DraganUS 450 Posted May 9, 2018 Ako nekom trebaju neke plastike pre nego sto se bace. 1 Danilo1 reacted to this Quote Share this post Link to post Share on other sites
jevta BG 111 Posted May 9, 2018 Au al si ga ogulio...oce da padne neki rollbar... Quote Share this post Link to post Share on other sites
DraganUS 450 Posted May 9, 2018 Zato ga polako i pripremam. Vadim ovaj plin pa ako nekom treba. Sve plastike su napolju. Ovde je jos.dosta ostalo na slikama ali sam i to izbacio....iskreno garaza je mama, nema zurbe i polako. Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted May 9, 2018 weight reduction 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
DraganUS 450 Posted June 1, 2018 Zop zop Stiglo donorce.... 2 Danilo1 and jevta BG reacted to this Quote Share this post Link to post Share on other sites
marko.jovanovic 925 Posted June 1, 2018 Greota za Kappu Quote Share this post Link to post Share on other sites
DraganUS 450 Posted June 1, 2018 1 minute ago, marko.jovanovic said: Greota za Kappu Jeste, ali jbg ne da ne mozes naci delove nego pretesko. Gledao sam da uvezem motor i da bude sve legalno ali sam se smorio zbog peripetija. tako da je ovo ostalo kao opcija. Quote Share this post Link to post Share on other sites
DraganUS 450 Posted August 10, 2018 Bice napolju za dan dva.... Quote Share this post Link to post Share on other sites
jevta BG 111 Posted August 10, 2018 Sta si do sad radio...oces biti spreman za usce... 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
DraganUS 450 Posted August 11, 2018 Akcija. 1 Danilo1 reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted August 13, 2018 @DraganUS Pa, daj slike akcije...izvadi li motor? 1 Danilo1 reacted to this Quote Share this post Link to post Share on other sites
DraganUS 450 Posted August 14, 2018 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
DraganUS 450 Posted August 14, 2018 @neshaoct Evo jedna amaterska za tebe. 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
