endbringer 15 Posted August 3, 2017 Ljudi, 1.6 mjtd 120 hp koliko vam troši? U gradu piči mi I do 10l, put za grčku prosek 6l sa klimom, nas troje i gepek stvari Quote Share this post Link to post Share on other sites
simpson_H 18 Posted August 3, 2017 Evo isti motor u znacajno tezoj Delti po ovom paklu sa klimom do panja, surovi grad prva-druga-treca+ kratke relacije sa mnogo uzbrdica ne prelazi 7.7l. Mislim da su uslovi takvi da ne mogu biti gori po potrosnju auta. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted August 3, 2017 2.0 u mene ne trosi toliko... Grad ajd imam toliko kratke relacije da ni ne palim klimu, ali ne ide preko 8.5 - 9, a na otvorenom sam oko 5.5, moze i manje ako drzim na 120 Quote Share this post Link to post Share on other sites
endbringer 15 Posted August 3, 2017 Na bordu ili čep čep? Bord mi pokazuje litar manje Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted August 3, 2017 Samo bord sto se mene tice... Quote Share this post Link to post Share on other sites
simpson_H 18 Posted August 3, 2017 Meni bord poprilicno tacan. 1 Siciliano reacted to this Quote Share this post Link to post Share on other sites
vandu 37 Posted August 4, 2017 Čep-čep 4.8, board 5.2, mešovita vožnja. Grad 30%, otvoren put 70%. Dualogic menjač. Quote Share this post Link to post Share on other sites
endbringer 15 Posted August 4, 2017 Juče merio, 9,5l u gradu. Nije bilo velikih stajanja u gužvama I 150km pređene vožnje. Svi parametri u redu, nema grešaka, sipam na molu, da li je neko imao sličan problem i uspešno ga rešio? Quote Share this post Link to post Share on other sites
skile86 539 Posted August 4, 2017 Ta potrosnja moze da bude ok samo ako imas ultra krtatke relacije, pod jakim gasom i ukljucenom klimom. Sta si konkretno gledao, pa kazes da su svi parametri u redu? Quote Share this post Link to post Share on other sites
endbringer 15 Posted August 4, 2017 Ovako. Do posla je 10km,mirijevo topčider i nazad. Ujutru protrčim, mala gužva. Popodne malo veća. Klima jeste on, normalna vožnja, ne silim ga. Ispod 9 nikada nije išao, obično je 10l. Nova lambda sonda, svi parametri na dijagnostici ok čak i u vožnji. Ne dimi, glasovi 0, dpf naravno. Dizne, maf, map? Ne prikazuju van parametara podatke Quote Share this post Link to post Share on other sites
Smireni 524 Posted August 4, 2017 To je baaas mnogo. Ajde tih 6 do Grcke je ok (zavisi kako vozis), ali 10l po gradu.... Meni sa ful klimom gradska ne ide preko 7.5 ali to bas kad je stani-kreni po BG-u. Po Sapcu uglavnom kratke relacije, bez klime, ispod 7. Vidi da ti neki dobar mehanicar pretrese auto. Quote Share this post Link to post Share on other sites
endbringer 15 Posted August 4, 2017 Trenutno Goran sa Altine muči muku. U ponedeljak idem opet. Znam, ne bi smelo da ide preko 8 Quote Share this post Link to post Share on other sites
shomispc 832 Posted August 4, 2017 Ja idem svaki dan Mirijevo - NBG (sa klimom samo popodne), ujutru maltene bez guzve jer idem bas okolo (Mir. Bulevar, Visnjicka, ona mahala, Viline Vode, Brankov most) a popodne kroz centar da bih pokupio devojku i uglavnom je oko 7. Zavisi kako kad, poslednji put sam merio bilo je 7.2, pre toga je bilo 6.8. Bord standardno laze za pola litre manje... Quote Share this post Link to post Share on other sites
endbringer 15 Posted August 31, 2017 Znači, nova lambda, map, proverene dizne i sve je kako treba da bude. Potrošnja ista. Da li da probam kod nekog tjunera da ga "čipujem"? Iskustva? Quote Share this post Link to post Share on other sites
DraganUS 450 Posted September 1, 2017 Promeni pumpu za pocetak. Ako hoces donecu ti ja 20-30l iz bosne dizela da testiras. Meni drugi auto sa gorivom iz bosne. Ako isto bude i tad onda ti nacin voznje vuce toliko. Quote Share this post Link to post Share on other sites
endbringer 15 Posted September 1, 2017 Sipam I u bosni buraz, dosta često. Skoro 80 posto je Bosna jer živim blizu. Normalna vožnja, optimalno šaltanje I bez cigle na gasu. Izgleda da je i prodat iz francuske zbog ovoga, video sam u istoriji da su menjali turbo, egr i čistili dpf par hiljada kilometara pre prodaje. Možda mu i nije moguće smanjiti potrošnju. Dosta često uključuje regeneraciju, možda tu ima neki zeza. Quote Share this post Link to post Share on other sites
shomispc 832 Posted September 1, 2017 Onaj drugi MAP sto si pricao sa Goranom nije pomogao? Nadam se da si odustao od onih kutija za cipovanje.. PS. pricali smo uzivo kod Gorana prosle nedelje na ovu temu Quote Share this post Link to post Share on other sites
endbringer 15 Posted September 1, 2017 pomogao je u smislu da nemam više seckanje I gubitak snage kada ubrzava na malim obrtajima I to je ekstra, ali je potrošnja ostala. Juče u servisu dizni, kažu OK su samo su podloške bile neodgovarajuće I stavili su fabričke. Sada troši litar više, loooooooool Videću prosek posle 100 km Quote Share this post Link to post Share on other sites
Ticma 537 Posted September 1, 2017 Koliko cesto radi regeneraciju dpf-a? Meni je ona znacajno dizala potrosnju... Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted September 1, 2017 Regeneracija DPF-a hoće tako da utiče, treba ipak usijati DPF, a komp to uradi tako što naliva naftu. Naročito se primeti ako se radi regeneracija u mestu (npr. pokrene se Examinerom), onda i smrdi i dimi pozadi. Quote Share this post Link to post Share on other sites
endbringer 15 Posted September 1, 2017 Pa pazi, poslednji prosek bio je 200km. Pre 2 dana uradio prinudnu regeneraciju uspešno, znači nije još pun. Ludilo za podloške dizni, stavili fabričke po prospektu I povećao potrošnju. Ludilo Quote Share this post Link to post Share on other sites
endbringer 15 Posted November 13, 2017 Ovako, pokušao sledeće. Bord pokazuje u gradu oko 7,6 a realno je 8,6. Pre par dana na autoputu raspalim trećom 3000rpm jedno 20 min do Bg. Sada bord posle 100km gradske pokazuje 6,5l/100km. Znači dpf def zeza kada je pun za više od litar po gradu. Quote Share this post Link to post Share on other sites
Ivan 17652 Posted November 13, 2017 Baci pogled i na ovo iskustvo sa potrosnjom... Ista generacija motora, samo 1956 ccm varijanta: Quote Share this post Link to post Share on other sites
endbringer 15 Posted November 18, 2017 Jel može zadnji lonac, koji je dotrajao, da zeza izlaz gasova a time i potrošnju? Quote Share this post Link to post Share on other sites
