alfini0507 1653 Posted March 20, 2019 Ma tek je Delmax... Quote Share this post Link to post Share on other sites
DraganUS 447 Posted March 23, 2019 Ovako cu ja u narednom periodu. Quote Share this post Link to post Share on other sites
MS PK 7718 Posted March 23, 2019 Jedino ispravno resenje Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted March 24, 2019 Oko ležaja točka je sada ovde: https://www.fiat-lancia.org.rs/forum/index.php?/topic/78792-fiat-nuova-croma-ležaj-točka/ Uopšte oko kvaliteta delova ovde: https://www.fiat-lancia.org.rs/forum/index.php?/topic/38919-šta-je-bolje-od-delova-kupiti-originalno-kvalitet-delova/&do=findComment&comment=1488153 Quote Share this post Link to post Share on other sites
DraganUS 447 Posted April 9, 2019 Ipak je desni bio. Imam 2 nova lezaja ako nekom treba. Levi i desni. 2 Danilo1 and neshaoct reacted to this Quote Share this post Link to post Share on other sites
DraganUS 447 Posted June 21, 2019 Insektarijum 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted June 21, 2019 @DraganUS Smanji brzinu Ako imaš vremena poskidaj fleke od njih po autu dok ne zapeknu, znaš i sam koliko je nakon par dana teže... Quote Share this post Link to post Share on other sites
Martin 796 Posted June 21, 2019 54 minutes ago, DraganUS said: Insektarijum Tipično za Cromu. Quote Share this post Link to post Share on other sites
DraganUS 447 Posted June 22, 2019 Dobro je pa ima mrezica inace svenode u hladnjak. Ovako bar zadrzi tu pa se mogu skinuti. Quote Share this post Link to post Share on other sites
Siciliano 1455 Posted June 22, 2019 Problem moze biti hladnjak klime koji je u otvoru ispod tablice, dole nize. Tu cesto uleti i kamencic i tako probusi sace da izadje freon. Koga ne mrzi, tu neka postavi neki komarnik:-)))Послато са SM-G531F помоћу Тапатока 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
DraganUS 447 Posted May 27, 2020 Proslo god od zadnjeg posta jos malo. Croma gazi da ne ureknem. Sutra na zamenu diskova. Sem malog servisa nista drugo za sad... Samo sipaj bosansko i teraj. 4 registracija do sad. 5 darkman14, MS PK, Martin and 2 others reacted to this Quote Share this post Link to post Share on other sites
MS PK 7718 Posted May 27, 2020 Cetvrta!? Auu ala vreme letiПослато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
DraganUS 447 Posted March 18, 2021 I kod mene dosla na red. Samo 15k. 2 alfini0507 and Martin reacted to this Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted March 18, 2021 Zeta erre? Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted March 18, 2021 @alfini0507 Klik ovde: - https://www.fiat-lancia.org.rs/forum/index.php?/topic/64639-zeta-erre-by-autoricambi/ Quote Share this post Link to post Share on other sites
MS PK 7718 Posted March 18, 2021 Pa Djole, 200ks + Nm = nova poluosovina, posle 15god Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
DraganUS 447 Posted March 30, 2021 (edited) Zavrsio posao. Inace 150a ide u 2.4. Da bi se skinuo mora i kompresor dole. Edited March 30, 2021 by DraganUS 2 alfini0507 and horvat reacted to this Quote Share this post Link to post Share on other sites
Martin 796 Posted March 30, 2021 Lagano. Opušten posao. Krepao ili krepao i menjaš remenicu? Quote Share this post Link to post Share on other sites
DraganUS 447 Posted March 30, 2021 (edited) 6 hours ago, Martin said: Lagano. Opušten posao. Krepao ili krepao i menjaš remenicu? Bas krepao. Prepunjavao, los diodni most, intenzitet svetla poceo da varira, lezajevi otisli, nisam hteo ni da otvaram nego ga spakovao i uzeo drugi. Usput napunio koimu i zadnje plocice prvi put promenio od kako sam kupio kola. Edited March 30, 2021 by DraganUS 1 horvat reacted to this Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted March 30, 2021 Jesi li sam menjao plocice ili kod majstora? Upustio bih se sam u to ali ne znam da li je komplikovanoSent from my Redmi Note 3 using Tapatalk Quote Share this post Link to post Share on other sites
DraganUS 447 Posted March 30, 2021 51 minutes ago, alfini0507 said: Jesi li sam menjao plocice ili kod majstora? Upustio bih se sam u to ali ne znam da li je komplikovano Sent from my Redmi Note 3 using Tapatalk Nije nista strasno, imas 2 sarafa da skines sa nosaca i to je to. Plocice sa samo stave nazad, vratis kandzu, 2 sarafa i to je to. Jedino sto moras imati alat da vratis klip. 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted March 30, 2021 Pa to je to... Pretpostavljam da je klip najveci problem... Moze neka improvizacija alata ili bas mora spec? Vraca se okretanjem? Sent from my Redmi Note 3 using Tapatalk Quote Share this post Link to post Share on other sites
