Trofeo 115 Posted July 15, 2017 Kao sto se vidi na slici Dakle kod rucne kocnice vidim stoji "razdzekan" nema ni jedan drugi dzek osim onog sto se kaci direktno za rucnu... Quote Share this post Link to post Share on other sites
askee 0 Posted July 16, 2017 Provjeri radi li ti podesavanje retrovizora, kod mene na staroj cromi na istom mjestu je bilo to podesavanje retrovizora i jednom prilikom nisu radila podesavanja retrovizora kad sam sve raskopusao vidin da se taj dzek vrlo lako iskopča. Quote Share this post Link to post Share on other sites
Trofeo 115 Posted July 16, 2017 (edited) @askee Naravno da radi podesavanje retrovizora, kod mene se vrlo tesko iskopca koliko sam primetio Samo taj dzek bleji sam,pa sam se zapitao cemu on sluzi uopste :/ Edited July 16, 2017 by Trofeo Quote Share this post Link to post Share on other sites
nesa 169 346 Posted July 16, 2017 Da nije baš za ručnu, odnosno od indikatora kad nije spuštena? Quote Share this post Link to post Share on other sites
Trofeo 115 Posted July 16, 2017 @nesa 169 Neso u prvom postu sam napisao da ima dzek za rucnu koji je vec udzekan a ovo belji razdzekano i ide iz snopa zica ispod tepiha Slucajno sam video reko ajd da pitam od cega moze biti :/ Indikator mi radi kad povucem rucnu... Quote Share this post Link to post Share on other sites
Trofeo 115 Posted July 16, 2017 (edited) @Kuvalja Upaljac radi Edited July 16, 2017 by Trofeo Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted July 16, 2017 Cini mi se da takav dzek ude za njega. Ispitaj sta su zice, da li ima stalni plus, da li ima plus sa svetla i ima li minus.... Quote Share this post Link to post Share on other sites
Trofeo 115 Posted July 17, 2017 zaista ne znam cemu moze da sluzi... Znam samo da mi sve od elektronike radi savrseno... Quote Share this post Link to post Share on other sites
cvike19 53 Posted July 17, 2017 mozda nesto za siceve...pojas mozda...ili za grijace Quote Share this post Link to post Share on other sites
Trofeo 115 Posted July 17, 2017 (edited) @cvike19 Imam airbagove u sedistima svi su povezani zutim plastificiranim "kablom" koji je ispod sedista,bez greske... koliko znam ni jedan bravo nema grejace sedista cak i koji ima kozna a za pojas to vec ne znam ali mi se cini da on i nema signalizaciju ako ne vezes pojas... Edited July 17, 2017 by Trofeo Quote Share this post Link to post Share on other sites
Miroslavjtd 4 Posted July 17, 2017 Mnogo možda. Quote Share this post Link to post Share on other sites
Ivan 17435 Posted July 17, 2017 Na prvu se apsolutno slazem sa Kuvaljom, dzek je identicnog izgleda, velicine i na istom mestu kao recimo dzek upaljaca na Stilu. Doduse, kod njega je upaljac lociran iza poluge rucne kocnice. Evo par slicica kao demonstracija, iz mog DIY o naknadnoj ugradnji navigacije: Uzmi unimer ili probnu lampu i proveri sva 3 pina. Recimo konektor upaljaca ima napon sa kontakta, napon kada se upale poziciona svetla (za svetleci prsten oko tela upaljaca) i masu. Takodje, moze da se proveri ima li u konektoru struje kada se skine odgovarajuci osigurac (pre/posle). 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
cvike19 53 Posted July 17, 2017 nema sta bit onda drugo nego za upaljac 100% jedna zica je stalni minus druga je plus od pozicije I treca je plus od kontakta (mozda i stalni) Quote Share this post Link to post Share on other sites
Trofeo 115 Posted July 17, 2017 @Ivan Provereno,nema struje (bez kontakta i sa kontaktom)... Upaljac svetli,kao sto rekoh nemam nikakav bag sa elektrikom...sve funkcionise u najboljem redu bez gresaka... Ko zna od cega je to... Quote Share this post Link to post Share on other sites
nesa 169 346 Posted July 23, 2017 On 17.7.2017. at 0:24 PM, Trofeo said: @cvike19 Imam airbagove u sedistima svi su povezani zutim plastificiranim "kablom" koji je ispod sedista,bez greske... koliko znam ni jedan bravo nema grejace sedista cak i koji ima kozna a za pojas to vec ne znam ali mi se cini da on i nema signalizaciju ako ne vezes pojas... Ima za pojas, trebalo bi da bude desna lampica na instrument tabli. ako je ta koa na tvom avataru. Za stariji tip ne znam da li ima. Quote Share this post Link to post Share on other sites
Trofeo 115 Posted July 23, 2017 @nesa 169 Jeste to je moja tabla Za pojas nemam svetlo ima samo za airbag donjem desnom uglu zasvetli crveno nacrtan onaj "coveculjak" upalim to se ugasi Quote Share this post Link to post Share on other sites
nesa 169 346 Posted August 10, 2017 Mora biti i za pojas, a ako ti ne svetli to znači da je lampica ispustila dušu. Quote Share this post Link to post Share on other sites
pedjavw 7 Posted August 11, 2017 Slazem se, znam čoveka koji ima Bravo ima signalizaciju za pojas Quote Share this post Link to post Share on other sites
Trofeo 115 Posted August 15, 2017 @nesa 169 @pedjavw Sve i da ste u pravu,gde je muski deo dzeka? Stoji samo taj deo,zato me i buni... Ide iz snopa zica a nema gde da se udzeka,sve sam pregledao... + provereno sa kontaktom i bez njega,nema struje u dzeku... Quote Share this post Link to post Share on other sites
cvike19 53 Posted August 22, 2017 moguce da je samo ostavljena instalacija za to "nesto" sta treba da se spoji a ti to nemas u svojoj opremi sto bi znacilo da lako mozes da dodas Quote Share this post Link to post Share on other sites
Trofeo 115 Posted August 22, 2017 @cvike19 Moguce,nije ni vazno vise cisto sam onako pitao Mada sve sto moze jedan fiat bravo da ima od opreme imam vec Quote Share this post Link to post Share on other sites
Stojke87 11 Posted March 7, 2019 (edited) Od čega je ovaj džek? nalazi se iza menjača, a gledao sam ručna je spojena, a ni menjač nema nikakav dzek Edited March 10, 2019 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Zvezdo 924 Posted March 7, 2019 Priprema za nešto. Inače Fiatu nije svojstveno da daje višak žica od onoga što je ugrađeno od opreme. 1 Stojke87 reacted to this Quote Share this post Link to post Share on other sites
Stojke87 11 Posted March 7, 2019 Ja sam kontao, posto tu stoji inace ono biiip za el retrovizore, da je dzek za to Fiat Bravo 2001 je u pitanju Quote Share this post Link to post Share on other sites
