Zvezdo 980 Posted May 27, 2017 Uzmi fabrički radio! Blueme izgleda radi samo nije spojen sa ulazom ovoga što je sada u autu. Može se on spojiti i na njega ali estetski odudara od ostatka auta. Quote Share this post Link to post Share on other sites
MickeyS 32 Posted May 27, 2017 Probas originalni radio kako radi sa tim usb iz kasete... Pa javi Quote Share this post Link to post Share on other sites
Buvac030 15 Posted May 27, 2017 Uspeo sam da povežem mobilni sa blue and ja i javljam se na slušalici na volanu , s tim što moram i na telefonu da pritisnem blue tooth da bi se čulo kao preko interfona i to je to. Quote Share this post Link to post Share on other sites
Ivan 17592 Posted May 28, 2017 https://www.fiat-lancia.org.rs/Manuals/Grande_Punto___Blue_me.pdf Quote Share this post Link to post Share on other sites
Buvac030 15 Posted May 28, 2017 Evo novog pitanja, ima neka kablica na kojoj pise steering wheel remote. Cemu sluzi taj kabal? Quote Share this post Link to post Share on other sites
Buvac030 15 Posted May 28, 2017 20 minutes ago, Buvac030 said: Evo novog pitanja, ima neka kablica na kojoj pise steering wheel remote. Cemu sluzi taj kabal? I ovaj konektor stoji nepovezan, zasta on sluzi? Quote Share this post Link to post Share on other sites
PuntoAbart 2 Posted May 29, 2017 9 hours ago, Buvac030 said: I ovaj konektor stoji nepovezan, zasta on sluzi? I jedno i drugo su za komande na volanu za fabrički Blaumpukt. Quote Share this post Link to post Share on other sites
Buvac030 15 Posted May 29, 2017 (edited) 10 hours ago, Buvac030 said: Evo novog pitanja, ima neka kablica na kojoj pise steering wheel remote. Cemu sluzi taj kabal? Ova zicka mi je od ne-fabrickog cd-a, mozda moze da se UBUDZI ? Mozda moze da se turi negde u onaj zuti konektor i to da radi? Edited May 29, 2017 by Buvac030 Quote Share this post Link to post Share on other sites
MickeyS 32 Posted May 29, 2017 Nemoj da UBUDZUJES nista, zameni radio za fabricki Quote Share this post Link to post Share on other sites
Zvezdo 980 Posted May 29, 2017 Jbt!!!! Full konektor za blaupunkta a ti neko smeće držiš u autu! Bacaj to i ubaci fabriku i da vidiš kako blueme radi!!! Quote Share this post Link to post Share on other sites
Smireni 524 Posted May 29, 2017 Ili kako Blue&me ne radi! Nije to bas vrhunac pouzdanosti elektronike. Quote Share this post Link to post Share on other sites
Buvac030 15 Posted May 29, 2017 samo da prodam ova dva sto imam i odma cu da kupim fabricki, mozda znate kome trebaju, imam ovog JVC-a i LG-aLCS500UR , LG kupljen nov u tehnomediji pre 6 godina. Quote Share this post Link to post Share on other sites
Dezurni 399 Posted May 29, 2017 Napravi oglas sa slikama i cenama (ne ovde) Quote Share this post Link to post Share on other sites
Srkii 3 Posted May 29, 2017 Odličan Grande,moj je isto 2007.god 120Ks 88kw T-Jet crveni ali ima crvene znakove i napred i nazad i na volanu novi tip table,sve fabrički,ide kao mećava ,prezadovoljan sam. Quote Share this post Link to post Share on other sites
Ivan 17592 Posted May 29, 2017 2 hours ago, Dezurni said: Napravi oglas sa slikama i cenama (ne ovde) https://www.fiat-lancia.org.rs/forum/index.php?/forum/115-audio/ Quote Share this post Link to post Share on other sites
Buvac030 15 Posted May 29, 2017 2 hours ago, Ivan said: https://www.fiat-lancia.org.rs/forum/index.php?/forum/115-audio/ izvinjavam se , zbog ovoga nisam imao nameru da se oglasavam, u stvari jesam ali i nisam razmisljao da ne treba ovde to da radim. Izinjavam se jos jednom!!! Quote Share this post Link to post Share on other sites
Ivan 17592 Posted May 30, 2017 Uzivaj, nije ovo forum tipa bilo kakve "strahovlade" , druzimo se i pomazemo, sto nije na predvidjenom mestu - preusmericemo, prebaciti i sl... Quote Share this post Link to post Share on other sites
Buvac030 15 Posted May 30, 2017 A zasta je ovaj kabla? A HA? Ovo je u gepeku sa leve strane 7 minutes ago, Buvac030 said: A zasta je ovaj kabla? A HA? Ovo je u gepeku sa leve strane Merio sam unimerom i tu ima neka struja, preko 13v Quote Share this post Link to post Share on other sites
Dezurni 399 Posted May 30, 2017 @Ivan pogrešno si ga usmerio. Bolje da otvori oglas kod @Markobgd u temi. Tamo ima već šanse da proda nešto Quote Share this post Link to post Share on other sites
Buvac030 15 Posted May 30, 2017 19 hours ago, Srkii said: Odličan Grande,moj je isto 2007.god 120Ks 88kw T-Jet crveni ali ima crvene znakove i napred i nazad i na volanu novi tip table,sve fabrički,ide kao mećava ,prezadovoljan sam. Ne mogu da nadjem slike tvog auta da vidim kako izgleda? Ali mislim da je moj lepsi Quote Share this post Link to post Share on other sites
Zvezdo 980 Posted May 30, 2017 samo 2 žice? vozačeva strana? svetlo u gepeku ili utičnica. Quote Share this post Link to post Share on other sites
Buvac030 15 Posted May 30, 2017 20 minutes ago, Zvezdo said: samo 2 žice? vozačeva strana? svetlo u gepeku ili utičnica. Svetlo imam , znaci uticnica? Quote Share this post Link to post Share on other sites
Srkii 3 Posted May 30, 2017 2 hours ago, Buvac030 said: Ne mogu da nadjem slike tvog auta da vidim kako izgleda? Ali mislim da je moj lepsi Pa sad...o ukusima ne treba raspravljati(slike još nisam stavio ali biće)neka te dobro služi druže,da se navozaš odličan je to autić Quote Share this post Link to post Share on other sites
Zvezdo 980 Posted May 30, 2017 1 hour ago, Buvac030 said: Svetlo imam , znaci uticnica? Ako su samo dve zice na kojima imas napon onda je definitivno uticnica. Quote Share this post Link to post Share on other sites
Buvac030 15 Posted May 30, 2017 2 hours ago, Srkii said: Pa sad...o ukusima ne treba raspravljati(slike još nisam stavio ali biće)neka te dobro služi druže,da se navozaš odličan je to autić Ne znam koliko dugo ga imas, ovaj je kod mene nekih 500km i ja sam odusevljen. Jedina mana mu je sto je registrovan za 4. Sve ostalo je super, za sada. Hvala ti na lepim zeljama, nadam se da se upoznamo na nekom od skupova pa da se druzimo. Quote Share this post Link to post Share on other sites
