Ivan 17435 Posted February 7, 2023 (edited) 15 minutes ago, igor0511 said: @Ivan ja nista ne objavljujem za Deltu, diskrecija zagarantovana Nisam na tebe ni mislio, sve je transparentno. Javio se, postavio slike, donosis rostilj - svaka cast, nema sta... Nego mislim na ovog deckica koji vec danima glumi 'ajduka po forumu. @Dzimbo Ocigledno da moramo da ga na'vatamo za cascavanje dok jos gora ne olista: Edited February 7, 2023 by Ivan 1 3 Dzimbo, moron, Reacher Gilt and 1 other reacted to this Quote Share this post Link to post Share on other sites
darkman14 5792 Posted February 7, 2023 @Ivan nije valjda automatika uzeo?! Pa to crkava... 3 Reacher Gilt, Axic and igor0511 reacted to this Quote Share this post Link to post Share on other sites
Dale 6785 Posted February 7, 2023 Samo redovno da servisira varijator i rolnice i nema problema, kao i svaki skuter... 1 3 Axic, Reacher Gilt, igor0511 and 1 other reacted to this Quote Share this post Link to post Share on other sites
MS PK 7718 Posted February 7, 2023 Neka je sa srecom novo vozilo za roditelje Sada zvanicno imas i QQ i Lele ( mini) 2 9 Dale, Reacher Gilt, PremieRacing and 8 others reacted to this Quote Share this post Link to post Share on other sites
igor0511 2821 Posted February 8, 2023 (edited) Hahaha plan mi je da se u nekom trenutku i finalno zakopam sa Stelviom 2.0 Bio sam blizu i ovaj put, ali preskupi su i dalje, ponuda gotovo nikakva i onda sam digao ruke Edited February 8, 2023 by igor0511 3 1 moron, PremieRacing, Ivan-Topola and 1 other reacted to this Quote Share this post Link to post Share on other sites
MS PK 7718 Posted February 8, 2023 Pa daj sta das.. Послато са SM-A307FN помоћу Тапатока 1 igor0511 reacted to this Quote Share this post Link to post Share on other sites
igor0511 2821 Posted February 8, 2023 Roditelji su dobrim delom izabrali Posto ce i biti primarno auto za njih pustio sam da izaberu pa ja jurio opremu i stanje. Hteo sam onaj X3, ali dzabe kada nece ljudi da se dogovore. Quote Share this post Link to post Share on other sites
igor0511 2821 Posted February 16, 2023 QQ polozio gepek test Veca kolica, decije sanke sa sedistem, 3 putne torbe, 3 ranca?! gomila klope i svasta jos sto sam zaboravio. Potrosnju nisam bas uspeo da izmerim zbog haosa na putu i preko 3h rada u leru. Ali eto ispade 6.1. Rekao bih da trosi oko 1l vise od Leona u proseku 6 Ivan-Topola, djomla, Axic and 3 others reacted to this Quote Share this post Link to post Share on other sites
igor0511 2821 Posted February 23, 2023 (edited) Posle blizu 6.5 godina posedovanja Leona uhvatilo me je da mi fale grejaci sedista i parking senzori na kolima. Zamalo da narucim grejace, ali sam video da mora da se izravna sav sedalni deo i ne bih da se sece step, ali sam zato narucio parking kameru i OBD pa cu da se igram Za senzore cu videti, voleo bih da ugradim fabricki prekidac, ali to za sada samo Britanci prave i traze oko 700$ za komplet prednje i zadnje senzore sto je sumanuto. Braca Kinezi prave bezicnu kamericu koja ide u svetlo tablice i cak dobija signal o poziciji volana za fascinantnih 30$ tako da jedva cekam da stigne da se igram sa tim: Naravno, vezuje se na fabricku multimediju i aktivira kada se ubaci u rikverc. Edited February 23, 2023 by igor0511 1 bane1321 reacted to this Quote Share this post Link to post Share on other sites
totti 13151 Posted February 23, 2023 Zar nije bilo priče da će ti ugraditi senzore još na početku, kao deo nekog duga ili tako nešto?Sent from my SM-G770F using Tapatalk 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
igor0511 2821 Posted February 23, 2023 @totti jeste i ponudili mi Kineske sto piste u gepeku Rekoh neka hvala, na Stilu sam makar imao prikaz udaljenosti. Quote Share this post Link to post Share on other sites
Axic 19705 Posted February 23, 2023 @igor0511 a sta ima da gledas koliko je levo ili desno, bitno da se oglase Ja cu one sto si mi dao uz auto samo u gepeku sa strane da stavim pa nek ekran svetli koliko hoće, mrzi me da provlacim kablove skroz napred. Quote Share this post Link to post Share on other sites
igor0511 2821 Posted February 23, 2023 A lepo je kad pise udaljenost i sa koje je strane, ne zezaj. Bacas dodatnih 3$ koje sam doplatio za ekran 1 Axic reacted to this Quote Share this post Link to post Share on other sites
Ivan 17435 Posted February 23, 2023 45 minutes ago, Axic said: mrzi me da provlacim kablove skroz napred Mozes da "munes" ekrancic i negde pozadi, odmah tu kod police gepeka kao sto bi i buzzer. Kad si okrenut unazad da ga vidis ili pratis u retrovizoru , samo treba paziti na rotaciju da ne zbunjuje . Mada i provlacenje napred je boza, ispod plastike pragova i pored Body Compa kroz A stub. 3 Axic, Dale and igor0511 reacted to this Quote Share this post Link to post Share on other sites
darkman14 5792 Posted February 23, 2023 2 hours ago, igor0511 said: Braca Kinezi prave bezicnu kamericu koja ide u svetlo tablice i cak dobija signal o poziciji volana za fascinantnih 30$ tako da jedva cekam da stigne da se igram sa tim: ja to jos na marei imao ima sve na Aliju, samo treba naci. A za grejace, koliko znam stefan tpc ugradjuje, tako da verujem da on profi radi (video sam negde na insta) 1 igor0511 reacted to this Quote Share this post Link to post Share on other sites
Axic 19705 Posted February 23, 2023 1 hour ago, igor0511 said: A lepo je kad pise udaljenost i sa koje je strane, ne zezaj. Bacas dodatnih 3$ koje sam doplatio za ekran Evo ja cu da ih postavim a @Ivan ima tu cast od gepeka da provlaci do A stuba 1 igor0511 reacted to this Quote Share this post Link to post Share on other sites
igor0511 2821 Posted February 23, 2023 @darkman14 generalno je fora sa ugradnjom aftermarket grejaca sto ona folija ide izmedju sundjera i presvlake. Ako presvlaka ima usitak po sred to se sece. Nesto mi je zao da se sece deo sedista koja su presla manje od 80kkm. Sa ovom kamericom ostaje sve fabrika makar @Axic htedoh i ja da napisem kako su forumasi carevi. Kupis dobru Deltu jeftino, onda se @Ivan javi da ti ugradi senzore, mozda neko uleti i alu felne kako je krenulo 2 2 Axic, nemanja84bg, Dzimbo and 1 other reacted to this Quote Share this post Link to post Share on other sites
igor0511 2821 Posted March 7, 2023 Da predstavim i dodatno prevozno sredstvo koje jedva cekam da pustim u svakodnevnu upotrebu opet Uzet letos nakon sto sam imao naprsnuce kosti pa nisam bas bio za voznju kola. Za pola sezone je presao oko 600km. Pali, radi ide, ne trosi Za grad je super resenje jer moze da se odveze gde god i stavi pod misku / unese. Sa druge strane me jako iritira kada se neko pravi pametan i ne dozovljava da se uveze trotinet. Tipa gospoja u Maxiju koja mi rece da ne moze da se uveze "jer prlja pod". Pitam je sto se onda ljudi ne izuvaju ispred i ne zna Evo i ljute masine od 250W: 5 1 nemanja84bg, Axic, Ivan-Topola and 3 others reacted to this Quote Share this post Link to post Share on other sites
MS PK 7718 Posted March 7, 2023 Gej frendli... Послато са SM-A307FN помоћу Тапатока 2 1 9 1 Milutinac, Grafit, ISV_01 and 10 others reacted to this Quote Share this post Link to post Share on other sites
igor0511 2821 Posted March 7, 2023 Uh sto me brine to kako izgleda dok se vozim pored reke umesto da budem alfa muskarcina u guzvi i izbacim lakat kroz prozor 2 2 moron, MS PK, Lufti and 1 other reacted to this Quote Share this post Link to post Share on other sites
MS PK 7718 Posted March 8, 2023 Pa nemas vise stila kupe!Послато са SM-A307FN помоћу Тапатока 1 Ivan-Topola reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4524 Posted March 8, 2023 Meni je hit kad po guzvi i vrucini neko tako otvori prozor da izbaci lakat, a nalazi se u nekom novijem boljem automobilu gde klima hladi bogovski i jos neutralise mirise izduva/zagadjenja 1 1 3 Axic, Lufti, darkman14 and 2 others reacted to this Quote Share this post Link to post Share on other sites
igor0511 2821 Posted March 8, 2023 Ali onda se ne vidi sat i ne mozes da se mrstis devojkama Gore od toga mi je samo da vidim telefon na uvetu u ganc novim kolima. Mico nije ni Stilo bio neki sampion prakticnosti, a guzva po BG sve gora. Vikendima zato samo Minija vozim jer obicno budu prazna mesta kraca od 4m gde vecina kola ne moze da stane 3 1 ISV_01, Lufti, Ivan and 1 other reacted to this Quote Share this post Link to post Share on other sites
darkman14 5792 Posted March 8, 2023 11 hours ago, MS PK said: Gej frendli... Pretece me Mica... @igor0511 nosis li pulover dok vozis pored reke? #nohomo ***E meni je pun ***** ovih sa elektricnim trotinetima ovde po NS, kako voze i cas su na stazi, cas na trotoaru, cas na putu a to ide fino brzo 2 MS PK and totti reacted to this Quote Share this post Link to post Share on other sites
igor0511 2821 Posted March 8, 2023 Da, nosim redovno dzempere zimi i kosulje leti jer smatram da mi pozicija iziskuje da se kulturno oblacim. Nisam znao da je dzemper gej. Bas losa fora iskreno.. 1 1 moron and Lufti reacted to this Quote Share this post Link to post Share on other sites
