neshaoct 9592 Posted December 31, 2020 Deo postova je sada ovde: - Servisni interval / skraćivanje servisnog intervala? 1 igor0511 reacted to this Quote Share this post Link to post Share on other sites
igor0511 2881 Posted January 13, 2021 Otvorih danas haubu da vidim stanje tecnosti kad sam vec umazao ruke menjanjem sijalica na Delti. Ovako izgleda nikad prebrisani motor posle 4 godine 4 Decak Iz Vode, darkman14, rkoma1986 and 1 other reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted January 13, 2021 Ne kontam kako je moguce da je toliko cist posle 4 godine Quote Share this post Link to post Share on other sites
igor0511 2881 Posted January 13, 2021 Dobro je zatvorena hauba pa nista ne ulazi. Mozda i najbolje zapecacena hauba koju sam video na kolima ove klase. A i zaista nije bio nikada u nekom teskom blatu koje bi se rasulo svuda Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted January 13, 2021 Znam al leti ima bas dosta prasine, gde god da si. Ovi mi sa slike deluje kao da auto nikad iz garaze nije izasao 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
igor0511 2881 Posted January 13, 2021 Tu je negde, jos nije dosao do 50kkm Quote Share this post Link to post Share on other sites
Bingodalton 737 Posted January 13, 2021 Brisu mu na servisu, a ni ne zna. Vidis da retko otvara haubu covek 2 Axic and rkoma1986 reacted to this Quote Share this post Link to post Share on other sites
Martin 799 Posted January 13, 2021 Verovatno nije video ništa van autoputa. 1 igor0511 reacted to this Quote Share this post Link to post Share on other sites
igor0511 2881 Posted January 13, 2021 @Bingodalton otvaram haubu pre i posle servisa zbog dobrih prica o Porshe-u Ada Redovno se obelezi filter nafte i proveri boja ulja pre i posle zamene. Plastike uvek jednako izgledaju. A od otvaranja haube sam se bas odvikao. Na Stilu sam nekako barem jedno u 2-3 nedelje nesto proveravao, dok na Leonu i Delti retko otvaram haubu, tek da proverim stanje tecnosti. @Martin recimo da je 80% kilometraze presao na otvorenom putu. Za offroad nema mogucnosti 1 Bingodalton reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted January 13, 2021 Ne kontam kako je moguce da je toliko cist posle 4 godineNišta čudno... slikaću sutra moj motor, otp isto/slično ovako. Kod mene za 3 1/2 godine nije nikad pran, bog te pita za ranije.Sent from my SM-G770F using Tapatalk 1 igor0511 reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted January 13, 2021 Ja ne znam, ko da zivim u ataru nekog sela. Motorni prostor vecito prasnjav 1 Martin reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 13, 2021 Kod mene isto cisto. Na Stilu sam cistio doduse povremeno ali minimalno prljavstine. Sad nisam prebrisao ni jednom od kupovine (6 meseci) i super izgleda. Sent from my Nexus 7 WiFi using Tapatalk Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted January 13, 2021 Ja ni ne znam kako je kod mene ispod haube 4 rkoma1986, igor0511, djomla and 1 other reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4032 Posted January 13, 2021 Zavisi i kako je hauba i hladnjak (ulaz) uradjen, tj koliko stroke se podvuce ispod i kroz. Na stranu uslovi voznje. Secam se klipova ganc nove Lade Vesta SW cross i posle krace lude voznje motor prljav uzasno. Kazu ovi sto su testirali - keder traka kao za vrata se zalepi ispod haube i nema brige, jer zadihtuje prostor do motora. Isto i kod mene, paucina se uhvatila ispod haube, a ima neke masnoce na crevu jos od momenta kada sam ga kupio. Radi? Ne cackaj, pranje motora moze biti i dobro odradjeno ali i pocetak igranke koja ti ne treba 1 igor0511 reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 13, 2021 Ja ni ne znam kako je kod mene ispod haube Ja se ubih sa dosipanjem tecnosti za brisace. Sent from my Nexus 7 WiFi using Tapatalk 1 rkoma1986 reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted January 13, 2021 Manje prskaj 3 3 Axic, PremieRacing, Flex and 3 others reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted January 13, 2021 Čovek ne vozi, podiže km umesto da skida kao neki Sent from my 3310 using Tapatalk 1 1 igor0511 and Bingodalton reacted to this Quote Share this post Link to post Share on other sites
igor0511 2881 Posted January 14, 2021 Dignem prednje tockove na klocne u garazi i pustim u 6. brzini 80km/h da bih kacio niske potrosnje na forumu 2 1 Bingodalton, moron and djomla reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted January 14, 2021 ŠOKANTNO: Evo kako se u Srbiji LAŽIRA potrošnja. FOTO VIDEO Sent from my 3310 using Tapatalk 2 igor0511 and moron reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 14, 2021 Dize km k'o da Alfu vozi. Sent from my ATU-L21 using Tapatalk Quote Share this post Link to post Share on other sites
igor0511 2881 Posted April 22, 2021 Da napisem ovde kratki update: 54kkm i sve savrseno i dalje. Potrosnja je blago opala nakon nekih 35kkm i ide mozda mrvu bolje. Na kraju godine i garancija istice. I zanimljiva stvar oko servisa: Naredni mali servis u ovlascenom ce kostati oko 11000din! Razlog je: automobil ke star preko 4 godine. Prethodni mali servis je izasao preko 35000din, inace. Bezobrazno, ali ideja je zadrzati ljude kako god izgleda. 1 moron reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted April 22, 2021 Zaobidji, za 11.000 u ovlascenom mogu da ti doliju litar ulja i produvaju filter kompresorom U top kvalitetu ili sa oem uljem i filterima ti treba jedno 15 hiljada samo za delove, bez ruku/rada.Послато са Mi MIX 2 помоћу Тапатока 3 1 djomla, moron, igor0511 and 1 other reacted to this Quote Share this post Link to post Share on other sites
srdjos 1601 Posted April 22, 2021 (edited) 20 minutes ago, igor0511 said: Da napisem ovde kratki update: 54kkm i sve savrseno i dalje. To za dizela nije ništa, možeš da počneš da kukaš na njega kad pređe 250kkm i više i to tipa, morao sam da menjam grejače. A servis, ne znam, i Ford ima posebnu politiku za vozila u garanciji, vozila stara do 10 i preko 10 godina. Recimo, ako ti vozilo ima preko 200 kkm, bez obzira na godine, savetuju menjanje ulja na 15kkm, inače je na 20 kkm (1.6 tdci motor). Tako i cene prilagođavaju a imaju i neke akcije u servisu pa nekad naletiš za 11-12 000 dobiješ sve original delove, a kad nije akcija, traže za isti servis 20 000 i više din Edited April 22, 2021 by srdjos 1 igor0511 reacted to this Quote Share this post Link to post Share on other sites
igor0511 2881 Posted April 22, 2021 Doduse ovo je akcijska cena, da napomenem. Verovatno me nece sacekati jos 10kkm. Videcu jos sta da radim za servis. Ne znam ni za jedan proveren VW servis tako da cu nastaviti u ovlascenom ako ne bude neko veliko udaranje po usima Quote Share this post Link to post Share on other sites
srdjos 1601 Posted April 22, 2021 Ja sam na kraju isao i sam kupio delove neke srednje klase, odneo kod drugara koji ima radionicu i on mi sve zamenio i pregledao auto. I to me koštalo 10 000 Sačuvao račun za delove i ulje i upisao kilometražu i eto servisne istorije 1 moron reacted to this Quote Share this post Link to post Share on other sites
