dekirs 4819 Posted January 20, 2018 Pa da, tako ce i biti.. Pokusavam da shvatim dal su morali nesto vezano za antifriz da diraju da bi dosli do hladnjaka Quote Share this post Link to post Share on other sites
Dezurni 399 Posted January 20, 2018 Samo dva creva Quote Share this post Link to post Share on other sites
dekirs 4819 Posted January 20, 2018 Znaci moze biti da je iscurelo malo ili nije stegnuto Quote Share this post Link to post Share on other sites
Timke 16 Posted January 21, 2018 Ok..nisam znao za to za mali hladnjak. Quote Share this post Link to post Share on other sites
Axic 20047 Posted January 21, 2018 22 hours ago, dekirs said: Nemojte Micu da dirate, dobar coek Baš dobar, da ga j***s ne bi ti reč rekao. @asterix Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted January 31, 2018 Skoro sam kratko provozao Dekijev Bravo...jako, jaaaaako dobar auto. Unutra očuvan, svi znamo da je urađen turbo, tih je, ne lupa ništa, vuče skroz ok za broj KS koji ima...tako da kada jednom bude na prodaju biće dooobra kupovina nekome. 1 dekirs reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted January 31, 2018 Hvala Neso Samo da znate nisam platio Nesi da reklamira brava Quote Share this post Link to post Share on other sites
totti 13165 Posted January 31, 2018 A Nešina testiranja... pun gas prva i druga, nabod kočnice, 180 stepeni okret, još jednom ista procedura i to je to Quote Share this post Link to post Share on other sites
skile86 539 Posted January 31, 2018 Malo da luduje kad vec ne moze na svojim kolima. Quote Share this post Link to post Share on other sites
dekirs 4819 Posted January 31, 2018 Svideo se coveku auto Quote Share this post Link to post Share on other sites
DraganUS 450 Posted February 1, 2018 Karavan pa ne ide. Quote Share this post Link to post Share on other sites
dekirs 4819 Posted February 1, 2018 Ide dobro alfa bar ono kratko sto sam potopio gas Quote Share this post Link to post Share on other sites
Dezurni 399 Posted February 1, 2018 Čekaj da te čuje Irena da si stiskao njen auto Razbiće vas obojicu 2 1 djomla, Axic and totti reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted February 2, 2018 Malopre me zaustavlja idiot kod sajma tera me da duvam i trazi dokumenta, dok ih trazim in gleda stakla i govori skini folije neko ce ti napisati kaznu, reko pa nisu folije fabricka su kaze gde pise ? Zavrsilo se sve na tome idi u amss neko ce ti pisati kaznu. Kako uopste naci oznaku da su fabricki tamna jer ja ne mogu da provalim dal je folija zalepljena ili sam slep. Naleteh na forumima da ovo "V" oznacava fabricki tamna ali nisam siguran.. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted February 2, 2018 @dekirs Da, to slovo V. Imam ga i na Alfi na fabrički zatamnjenim zadnjim bočnim i zadnjem staklu. Slikaću sutra. Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted February 2, 2018 Odakle ti sedmice na staklima? Mislii da je tvoj bravo noviji. Takodje ne vidim as oznaku, obicno je as3 zatamnjena stakla, as2 obicna, a as1 soferka. Quote Share this post Link to post Share on other sites
skile86 539 Posted February 2, 2018 Mogu da budu starija stakla od godista automobila. Kolega na novom Sportage-u ima sva sarena godista na staklima. Quote Share this post Link to post Share on other sites
Ivan 17670 Posted February 2, 2018 (edited) Jeste V ta oznaka, negde pise i kolika je propusnost. A folija se vidi iz aviona, pogotovo na obodima (unutra) ili preko ovih slova na staklima. Na gepeku narocito, jer maltene niko to ne uradi toliko pedantno da pozadi ne ostane cuveni "milje" po obodu gde su tackice na staklu. Ovo mi (samo na osnovu slika) deluje da ja fabricki, bez dileme. A brate mili, 100 godina si na forumu - ukucaj VIN u ePer i proveri imas li stavku "Tinted windows" setovanu na "Yes". Sa tim se retko ko naknadno igra. Edited February 2, 2018 by Ivan Quote Share this post Link to post Share on other sites
dekirs 4819 Posted February 2, 2018 Jesam to sam i gledao odmah po kupovini, pitao sam iz razloga sledeci put kad me indjanac zaustavi i krene da pametuje da mogu i ja da krenem sa oznakama Quote Share this post Link to post Share on other sites
Ivan 17670 Posted February 2, 2018 Pa ako su toliko nedokazani, neobuceni, a vrse kontrolu, spusti mu zadnje staklo pa nek' krene sa njihovom cuvenom metodom - nokta. Ili odstampaj ePer pa nosi sa sobom . Quote Share this post Link to post Share on other sites
dekirs 4819 Posted February 2, 2018 Ja spustio staklo, pokazujem mu da nema folija kaze on ne, ne to su folije.. Jos on meni kao cini uslugu i daje savet idi kao u AMSS kazna je 6 do 20 hiljada. Mislim se covece teraj se i ti.. Nema vecih lopova postave 2 radara na 700m, klasicna otimacina para.. Al to je vec neka druga prica. Za sada mi ne trosi vodu, ne znam koliko je dana proslo nekih 10ak i dalje je voda na max. Quote Share this post Link to post Share on other sites
Ivan 17670 Posted February 2, 2018 Nemas ti tu sta da se brines, sve je fabricki. Jedino mozes da izgubis zivce i vreme da te neko neobucen (a prosto ne mogu da verujem da je tako) ne maltretira sa slanjem na KTP. Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted February 2, 2018 Vodu ne trosu, al naftu dere Quote Share this post Link to post Share on other sites
dekirs 4819 Posted February 2, 2018 Pa da, ne bi me cudilo da naletim na "strucno" lice.. Zanimljivo je da ovaj 1.6 trosi kao da je 2.0 A moze i ovako Quote Share this post Link to post Share on other sites
MS PK 7732 Posted February 2, 2018 Zanimljivo je da svaki mali trosi kao veliki al je ogromna usteda na registraciji, jbg Quote Share this post Link to post Share on other sites
