Milutinac 5906 Posted May 15, 2020 1 hour ago, dekirs said: Koliko konjskih snaga dodaje ovaj upgrade? Nema vise gde da uguram. To se osipa... 1 dekirs reacted to this Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted May 15, 2020 Sad si malo manje NE kul sa dizelom 2 Milutinac and Axic reacted to this Quote Share this post Link to post Share on other sites
Ivan 17668 Posted May 15, 2020 (edited) Pazi koja slucajnost... Moji crni spojleri, a bas ih trazim po parkingu celo jutro . Ko ono rece da ti je doneo paketic? Edited May 15, 2020 by Ivan Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted May 15, 2020 Ja sam posteno platio robu, da li je legalna ili nije - meni svejedno. Sve ostalo moras da vidis sa Paparazzo Danilom Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted May 15, 2020 @Ivan a tako je to kad pod stare dane slabije vidis probaj da opipas, sigurno su jos na kolima @Milutinac nisi ih jos namontirao? + papucice i tabla pa ce biti pravi sport (na sledecem skupu cu odvuci paznju Ivanu oko alarma a ti se posluzi ) 1 2 horvat, Milutinac and Ivan reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted May 15, 2020 Ja sam moje -Sportisanje- vrlo verovatno i zavrsio nije mi bio cilj da pravim -Sporta- od -Emotiona- vec samo da metnem ono sto mi falilo nekako. Bez papucica i table mogu...jeeeeeeedino ako bas izleti nesto a ja bez nekih drugih ideja Quote Share this post Link to post Share on other sites
dekirs 4819 Posted May 15, 2020 Zelja svakog decaka je da ima Sportaka 1 2 Ivan, Mijailović P. and Milutinac reacted to this Quote Share this post Link to post Share on other sites
Ivan 17668 Posted May 15, 2020 (edited) 29 minutes ago, Milutinac said: Ja sam moje -Sportisanje- vrlo verovatno i zavrsio nije mi bio cilj da pravim -Sporta- od -Emotiona- vec samo da metnem ono sto mi falilo nekako. Bez papucica i table mogu...jeeeeeeedino ako bas izleti nesto a ja bez nekih drugih ideja Da, da, sve mislim da mozes , to pricaj kuci... A kad sam te zafrkavao da je lakse bilo da si odmah kupio Sporta, ti negiras ... A onda Mile te Sport felne, te Sport enterijer, te Sport auspuff, te Sport sajtne i kacketic... Sto kaze Danilo, jos alu-papucice sa restyle (one lepe kao na Giulietti) i Sport cajgeri... E da, jos da ti omogucimo Sport mode za jos malo boosta/reskiji odziv na gas/tvrdji volan, tamna stakla i to je to. Imas jos 4 stavke za domaci . Salu na stranu, verujem da ce spojleri bas lepo da legne na tu boju auta. Samo jos tamna stakla pozadi i bombona. 31 minutes ago, Danilo1 said: @Ivan a tako je to kad pod stare dane slabije vidis probaj da opipas, sigurno su jos na kolima Zaje*avajte vi starije ljude... Deder @Milutinac , slikaj mi te sajtne i kacket sa unutrasnje strane. Ako nadjem lemilicom urezano "IVO" , kao na poklopcima felni - ima vas dvojicu neko debelo da opipa ... Nego, pazi sad ovo - nema mi ni poklopaca felni ni antene . Edited May 15, 2020 by Ivan Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted May 15, 2020 1 hour ago, Ivan said: jos da ti omogucimo Sport mode say no more Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted May 17, 2020 Detalji detalji...dosada dosada Debeli diskrecija... E sad...kada sam radio usisnu, cistio IC i creva (nedugo zatim i gasio DPF i EGR) uzeo sam i nov MAP senzor. Stari nisam hteo da prskam onim cleanerima iako znam da moze. Evo ga MAP ugledao svetlost nakon nekih 35000-40000km 3 ISV_01, Danilo1 and horvat reacted to this Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted May 17, 2020 (edited) Nisam jos video da tako nesto raste na drvetu Edited May 17, 2020 by YUgisa 1 1 horvat and Ivan reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted May 17, 2020 E druze moj...nisi onda dugo bio u Vrbasu tamo sta ima...ne bi verovao Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted May 17, 2020 A jbg ja krenem za Vrbas ali onda zalutam u Kuli Quote Share this post Link to post Share on other sites
totti 13165 Posted May 17, 2020 (edited) https://www.chiptuning.com/vw/multivan-t6-sgf-sgm-sgn-2015/2-0-tdi-4motion-204ps-150kw-1968ccm/pedalbox.html Edited June 1, 2020 by neshaoct dodao printscreen Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted May 17, 2020 @totti - VW multivan??? Ako se dobro secam Nesa je imao nekih iskustava sa vanovima na auto-putu. Ja tih problema nemam Quote Share this post Link to post Share on other sites
Ivan 17668 Posted May 17, 2020 A koliko se ja secam, nisu bili problematicni vanovi, nego Transporter . 1 Axic reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted May 17, 2020 On 5/17/2020 at 3:31 PM, Milutinac said: [mention=10479]totti[/mention] - VW multivan??? Ako se dobro secam Nesa je imao nekih iskustava sa vanovima na auto-putu. Ja tih problema nemam Ma ja to zbog rešenja za Sport dugme A Transporteri su sleeper-i... čas posla se zaebeš i navuku te 1 Ivan reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted May 17, 2020 On 5/17/2020 at 4:56 PM, totti said: Ma ja to zbog rešenja za Sport dugme Eeeeeeeee, to da dzaba, i to da metnem reci ce - ALI NIJE OEM Quote Share this post Link to post Share on other sites
totti 13165 Posted May 17, 2020 A njima kao to radi... Džaba im što je OEM, lažu sami sebe Quote Share this post Link to post Share on other sites
horvat 6456 Posted May 31, 2020 1 1 neshaoct and Milutinac reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted May 31, 2020 Ova ova Hvala @horvat 5 dekirs, skile86, PremieRacing and 2 others reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5315 Posted May 31, 2020 6 hours ago, horvat said: This car stops where real fun begins... 4 3 Mijailović P., neshaoct, darkman14 and 4 others reacted to this Quote Share this post Link to post Share on other sites
Axic 20045 Posted May 31, 2020 (edited) @horvat Došo na optiku u NS pa usput uslikao Milutinca? Edited June 1, 2020 by Ivan Skinut nepotreban citat, dodat tag 1 djomla reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted May 31, 2020 U NS sam vec probao optiku, sad testiram Beogradjane 1 1 Axic and djomla reacted to this Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted May 31, 2020 Ocekujemo uskoro putopis "Jedan krug na Hanteru" 1 3 Axic, ISV_01, neshaoct and 1 other reacted to this Quote Share this post Link to post Share on other sites
