Milutinac 5906 Posted September 20, 2019 3 minutes ago, andreja.micovic said: @Milutinac jesu pitali a gde je DPF? Rekao sam im na kraju. Pricali smo malo, ja reko nema tu nista i pokazujem na haubu, sta nema nista, reko nema DPF-a, oni aaaaaaaaaaaa 1 dekirs reacted to this Quote Share this post Link to post Share on other sites
Ivan 17594 Posted September 20, 2019 19 minutes ago, andreja.micovic said: I eto pljeska kod Brene dok traje tehnicki Ih, da je samo pljeska . Zaje*avamo se malo, ali kome je usput, zasto ne iskoristiti... Quote Share this post Link to post Share on other sites
totti 13160 Posted September 20, 2019 VBS, na Bul. Vojvode StepeZar nije logičnije da se zove BVS? Sent from my SM-G950F using Tapatalk 1 2 bglion, PremieRacing and SkyBlu reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted November 4, 2019 @Milutinac Sve nesto bih da pitam oko folija na retrovizoru, al ne mogu da se setim ko je stavljao i onda se setih tebe.Da li imas neke preliminarne rezultate/istrazivanja u realnosti hidrofobnih folija na retrovizoru ? Meni su isto stigle ali nisa ih jos stavio jer je vreme blagi krs i uzas. Hvala vi unapred Sent from NOMU S10 PRO using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7729 Posted November 4, 2019 Kakvo to vreme treba da bude da zalepis parce folije 3x3cm Послато са SM-J330F помоћу Тапатока 2 dejan_ns and Sedla reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 5, 2019 (edited) Ceka April a onda mu nece ni trebati Salim se, imaju neku funkciju, definitivno nekad oko folije ima vise kapljica, nego na njoj. Kazem - nije neki revolucionarni proizvod, i nije ni totalni must have za sezonu 2019-2020... Edited November 5, 2019 by Milutinac 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted November 5, 2019 Aha, fala vi za info Onda ce jos malo da bleje u steku, valja to stavljati na cistiji auto Sent from NOMU S10 PRO using Tapatalk 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5307 Posted November 5, 2019 Ide dembeli na maleni smajling Više u sledećem javljanju... 3 horvat, dekirs and djomla reacted to this Quote Share this post Link to post Share on other sites
Ivan 17594 Posted November 5, 2019 Teaser: 6 Axic, dach@, djomla and 3 others reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5307 Posted November 5, 2019 Jbg, my bad Prvo sam rekao "hop" a nisam skočio... Nema majstor materijala u kvalitetu za Milutina Više sreće drugi put 1 horvat reacted to this Quote Share this post Link to post Share on other sites
MS PK 7729 Posted November 5, 2019 Sta je znaci ovo bilo, klik bejt!?Послато са SM-J330F помоћу Тапатока 3 1 PremieRacing, horvat, djomla and 1 other reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5307 Posted November 5, 2019 Da vas odvučem od moje teme dok završim pisanje... Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 5, 2019 7 hours ago, PremieRacing said: Ide dembeli na maleni smajling Više u sledećem javljanju... Aaaaa pa mogao sam i ovde onda. Nema veze. Eto bio sam malo i u romingu 5 hours ago, Ivan said: Teaser: Nije to. Bice uskoro 1 horvat reacted to this Quote Share this post Link to post Share on other sites
Ivan 17594 Posted November 6, 2019 Moramo da napravimo neku akciju da ti nadjemo onu plastiku iznad auspuha . Gledah ti bas juce u ePer po svom VIN - donji deo branika za Sporta ide samo u kompletu (isecen je za duple izduve i sa integrisanom gornjom plastikom, slika im je samo ilustrativna ocigledno): Tako da nista od narucivanja samo te plastike kao posebnog kao dela. Jedino da se negde iskopa polovno, ako vec nemas neku drugu ideju. 1 horvat reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5307 Posted November 6, 2019 Ja sam mu dao drugu ideju koja košta 50,- dinara Neka prvo to proba, a ako nije zadovoljan bar ima prelazno rešenje do nabavke ovog specifikuma... Quote Share this post Link to post Share on other sites
Ivan 17594 Posted November 6, 2019 (edited) Cudno mi bilo sad na skupu, vidim ja nesto se Mile pogrbljen mota oko auspuha Sportova parkiranih kod Intera... Izgleda da se ta plastika teze skida, jbm li ga . Mada nema veze, dok se on trudio, ostao je bez antene . Edited November 6, 2019 by Ivan Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 6, 2019 Tvoja se lako skida, probao sam ja vec bio sam fin pa sam i vratio... Probao sam da trazim, ne vredi. NIko nigde nema, niti redovne prodavnice, niti ovi sto je bave prodajom tih plastika - branika, pragova itd Ceo deo se naziva spojler zadnjeg branika, to je znaci ceo taj crni, donji deo na braniku. Ima druga varijanta, probacu tako. Ima da se uzme lajsna, slicna toj plastici iznad auspuha, mislim da ce biti taman kako treba... Quote Share this post Link to post Share on other sites
Ivan 17594 Posted November 6, 2019 (edited) Ako imas tetku u Brazilu, nek'ti sibne ovaj branik , kad vec radis: PS: Ovo je bila neka njihova Xtreme verzija (stvarno se tako zvala) - cudno neko trziste i sa dizajnom i sa motorizacijom . Edited November 6, 2019 by Ivan Quote Share this post Link to post Share on other sites
MS PK 7729 Posted November 6, 2019 Nije moj Mile takav 1 1 dekirs and Milutinac reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 6, 2019 On 11/6/2019 at 12:04 PM, Ivan said: Ako imas tetku u Brazilu, nek'ti sibne ovaj branik , kad vec radis: Steta, samo tetka u Kanadi...jbg Znam za tu verziju, neke 2012-2013 su je predstavili. Od napred je tek blagi uzas...mada evo jedne adekvatne slike Quote Share this post Link to post Share on other sites
dekirs 4819 Posted November 6, 2019 Dobar list. 1 1 djomla and ISV_01 reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted November 6, 2019 Bas bi bila fora da "dole imas brazilku" If you know what I mean..... 4 Axic, djomla, Milutinac and 1 other reacted to this Quote Share this post Link to post Share on other sites
darkman14 5898 Posted November 6, 2019 16 minutes ago, dekirs said: Dobar list. Deki se pustio u promet... po ostalim temama... Eno ga stuca... Quote Share this post Link to post Share on other sites
dekirs 4819 Posted November 6, 2019 Nisam ja kriv sto me ljudi spominju Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 9, 2019 Zavrsih u pitanju je folija... To je ono sto sam hteo. Da ne bude tuning-smajling. Da ne bude crno CRNO. Da bude diskretno i malo drugacije. 10 djomla, dekirs, MS PK and 7 others reacted to this Quote Share this post Link to post Share on other sites
