N.N.
Novi Dodge crossover iz Italije?
Prenosim vijest:
http://www.autonews.com/article/20160620/OEM/160619881/is-dodge-taking-journey-to-italy
Quote
Is Dodge taking Journey to Italy?
Fiat Chrysler will shift Dodge Journey production from Mexico to Italy when the compact crossover is redesigned for the 2019 model year, supplier sources say.
The next-generation Journey is expected to share a platform with the Alfa Romeo Giulia. That means a transition from front-wheel drive to rear-wheel drive, though all-wheel drive would likely continue to be an option.
Moving production to Europe would help FCA free up capacity in North America, where the company wants to expand output of Jeep SUVs and Ram pickups. It would also boost plant utilization in FCA’s European assembly operations, which remain underutilized as Europe continues to recover from its economic downturn.
The Journey is currently sold in Europe as the Fiat Freemont.
Fiat Chrysler’s 2014 Product Plan called for the redesigned Journey to be introduced this fall. However, as Automotive News reported in April, the current model will soldier on for at least two more model years and continue to be built at FCA’s Toluca Assembly Plant in Mexico.
Production on the 2017 Journey is scheduled to begin July 25 and the 2018 model will enter production in Toluca on July 17, 2017, an FCA source said.
Toluca Assembly also produces the Fiat 500. However, FCA is building pilot vehicles in Toluca for the successor to the Jeep Compass and Patriot. Full production of the Compass and Patriot successor is scheduled to begin at the plant on Jan. 30, 2017.
The Journey is one of FCA’s oldest models — significant U.S. sales began in 2008 — and has one of its oldest powertrains. It has a four-speed automatic transmission in its most fuel-efficient model, which is rated at 19 mpg city/26 highway.
If the redesigned version moves to a rear-wheel-drive powertrain, as expected, it would likely mean a shift to an eight-speed transmission and a significant increase in fuel economy.
They Journey received its last major freshening for the 2011 model year. Through May, sales are down  9.7 percent in the U.S. to 37,423.
Recimo da ovo ima smisla kako bi prvi sljedeći američki model na Giorgiu trebeo biti MY2021. On bi trebao biti MY2019 što će reći da prodaja počima 2018., moguće čak u prvoj polovici te godine. Pitanje je samo Pomigliano uz novu Giuliettu ili Cassino kada ga aktualna napusti.
Naslednik modela Dodge Journey / Fiat Freemont će se proizvoditi u Italiji
Američki mediji pišu da će kompanija Fiat Chrysler Automobiles (FCA) novu generaciju modela Dodge Journey predstaviti za modelsku 2019. i da će se proizvoditi u Italiji, umesto u Toluca fabrici u Meksiku kao sadašnja generacija (koja se u Evropi trenutno prodaje kao Fiat Freemont). Takođe, novi Journey će koristiti novu platformu sa zadnjim pogonom koju ima i Alfa Romeo Giulia, a kako se očekuje novi Journey će imati dosta toga zajedničkog sa budućim Alfinim SUV modelom Stelvio. Takođe, vozilo će se opciono nuditi i sa 4x4 pogonom, a biće dostupan i osmostepeni automatski menjač. Za sada o novom Journey-u nema konkretnih detalja, ali Alfa Stelvio će se nuditi sa više benzinskih i dizel motora, uključujući i 2.0 litarski turbo četvorocilindraš.
Zamena za Dodge Journey na bazi Alfe Stelvio
Pojavile su se nove informacije o tome da FCA planira novi model koji će zameniti Dodge Journey. Pojedini američki mediji pišu da će novi Journey (ako uopšte bude zadržao taj naziv) koristiti Giorgio platformu na kojoj su napravljeni Alfa Romeo Stelvio i Giulia. To takođe znači da će zamena za Journey imati zadnji pogon, kao i opcioni pogon na sva četiri točka. Očekuje nas dakle novi Dodge koji će približno biti veličine Alfe Stelvio, ali uz stajling inspiranom Dodge Chargerom. Jedan od motora u ponudi će po svemu sudeći biti 2,0 litarski turbo četvorocilindraš sa 276KS i 475 Nm obrtnog momenta. Premijera se očekuje krajem 2022. ili početkom 2023. godine, pri čemu bi proizvodnja trebalo da se odvija u Italiji.
Ovo meni ruzno. Mozda uzivo promenim misljenje ali ovako mi je bas bljak. Izmedju prednjice i zadnjice nidje veze. Ko da su sa nekog americkog sranja nalepili prednji deo na Stelvio ili nesto slicno.
Edited by francuz69
Najavljen novi Dodge crossover
Stellantis Mexico je objavio nekoliko zatamnjenih najavnih slika kojima je potvrdio da će na tom tržištu uskoro ponuditi novi Dodge crossover.
Novi i za sada neimonovani crossover će po najavama označiti novi eru za brend, ali kako izgleda u pitanju je samo Dodge verzija modela Trumpchi GS4 Plus koji u Kini pravi GAC Fiat-Chrysler (joint venture kompanija Fiat-Chrysler Automobiles i Guangzhou Automobile).
Ako je to tačno, to znači da će novi Dodge crossover (dužine 471 cm) dobiti 1.5 i 2.0 turbo-benzince (jači ima 248KS i 390 Nm, uz 6-stepeni automatski menjač), kao i 12.3-inčnu digitalnu instrument tablu i 10.1-inčni ekran infotainment sistema.
Novi Dodge Journey iz Kine
Stellantis Mexico je početkom septembra objavio nekoliko zatamnjenih najavnih slika kojima je potvrdio da će na tom tržištu uskoro ponuditi novi Dodge crossover. Sada je saopšteno da je u međuvremenu počela i njegova proizvodnja. To je novi Dodge Journey koji će po najavama označiti novi eru za brend, ali u pitanju je samo Dodge verzija modela Trumpchi GS5 koji u Kini pravi GAC Fiat-Chrysler (joint venture kompanija Fiat-Chrysler Automobiles i Guangzhou Automobile).
To znači da se i novi Dodge Journey proizvodi u Kini, a pored Meksika kasnije bi trebalo da se prodaje i u drugim zemljama Latinske Amerike (Čile, Peru, Kolumbija...).
Po pisanju lokalnih medija, 470 cm dugački Journey ima 1.5 benzinski motor, uz 6-stepeni automatski menjač i prednji pogon.
Prodaja u Meksiku će početi u novembru, ali cena za sada nije saopštena.
