Lufti 688 Posted October 4, 2020 Ugradjen fabricki woofer, sad jos da se zice povezu...Sent from my SM-A805F using Tapatalk 2 Zvezdo and Rile_bg reacted to this Quote Share this post Link to post Share on other sites
Zvezdo 931 Posted October 4, 2020 Ovo sa alcantarom je cita perverzija kako izgleda uzivo! Neverovatno koliko je podignut ugodjaj u autu a jos nije sve gotovo! Quote Share this post Link to post Share on other sites
Lufti 688 Posted October 4, 2020 Da, slazem se u potpunosti. Na slikama deluje kao da je unutrasnjost previse mracna ali je uzivo potpuno drugaciji osecaj. Kao da se vozite u nekom premium enterijeru, materijal je bas kvalitetan...Sent from my SM-A805F using Tapatalk Quote Share this post Link to post Share on other sites
Lufti 688 Posted October 9, 2020 Mini projekat u toku...Sent from my SM-A805F using Tapatalk Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted October 9, 2020 Lajsna ispred suvozaca? Quote Share this post Link to post Share on other sites
Lufti 688 Posted October 9, 2020 Da, stavljam ispod nje led ambijentalno osvetljenje, slicno resenje je fabrika primenila kod eva.Sent from my SM-A805F using Tapatalk 3 MS PK, Milutinac and silenci reacted to this Quote Share this post Link to post Share on other sites
Lufti 688 Posted October 10, 2020 Probano ambijentalno osvetljenje preliminarno...super se uklapa ako se ne pritisne lajsna do kraja na mesto. Lepak ce to resiti...Jos uvek nisam povezao na 12V, za sada radi na baterije...Sent from my SM-A805F using TapatalkKamera fokusira svetlo u mraku pa izgleda kao da ima prekida ali uzivo izgleda sasvim ok...Sent from my SM-A805F using Tapatalk 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
Axic 19729 Posted October 12, 2020 Hoće li biti dimmer u funkciji sa ostatkom osvetljenja? Da može lepo da se smanji osvetljenje table, centralne konzole i te LED rasvete zajedno. 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Lufti 688 Posted October 12, 2020 Odlican predlog. Dimmer postoji za radio i cajger. Sto tog ambient osvetljenja tice, posto ce se nalaziti ispod lajsne, nece se direktno videti tako da nece ni smetati prilikom nocne voznje, mada bih mogao da ga povezem na radio pa da se i to svetlo dimuje po potrebi...Sent from my SM-A805F using Tapatalk 1 Axic reacted to this Quote Share this post Link to post Share on other sites
Lufti 688 Posted December 24, 2020 (edited) Opet sam vadio tablu napolje, omrznuce me auto.... Tabla je presvucena u isti materijal kao i nebo i stubovi (alkantara ili imitacija alkantare, nije ni vazno, materijal je prijatan na dodir i sto je najvaznije, svidja mi se kako izgleda u kolima, nije napadan a opet odaje taj smek skupljih automobila...samo da potraje ali to ce se tek pokazati...) Ovom prilikom bih se jos jednom zahvalio Nikoli iz Lajkovca na strpljenju i umesnosti, posao je odradio majstorski! Nidza je insistirao da odradi i fioku i donje delove table...ja se nisam previse bunio... Moj drug @Zvezdo je prilikom prodaje svog GP-a sacuvao multimediju koja je bila montirana kod njega u kolima i sada je nasla mesto u plavoj munji. Cucnula je fenomenalno! (fala braci Kinezima sto su stavili rgb diode pa nisam morao opet da lemim plave smd...) Edited December 24, 2020 by Lufti 11 1 Martin, Zvezdo, PremieRacing and 9 others reacted to this Quote Share this post Link to post Share on other sites
Lufti 688 Posted December 24, 2020 (edited) A opet moram da se zahvalim Zvezdanu na velikoj pomoci, sto je kupio karavana pa smo mogli ko ljudi da odemo nekih 100-ak km od prestonice i donesemo nesto sto jurim od kad sam kupio auto... Posle toliko vremena sam najzad uspeo da ih nadjem: ! Prilicno retka (i u sklopu automobila u koje se opciono stavljaju a pogotovo kao polovna zasebno) Sabelt sedista koja idu u nekoliko tipova fiat-a 500 abarth, GP i Evo EsseEsse i Alfa Romeo MiTo Quadrifoglio. Sa njima ce enterijer najzad biti kompletiran kako sam zamislio i nakon toga cu moci da se posvetim pogonu, izvesno je da ce puntisa uskoro biti ujeden od strane skorpiona ali o tome neki drugi put...za sada cu uzivati u predstojecim praznicima posto je Deda Mraz dosao par dana pre vremena... Edited December 25, 2020 by Ivan Sredjen format 10 1 Martin, Bingodalton, MS PK and 8 others reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5188 Posted December 25, 2020 Prelepo Ali i preteruješ Svakako , a od januara da vidiš i vrata i pod da presvučeš u 'alkantaru'... To ti je samo ostalo Quote Share this post Link to post Share on other sites
Lufti 688 Posted December 25, 2020 (edited) A polica gepeka? A prtljaznik? Ljudi daju ogroman novac da bi dobili fabricki odradjeno nebo, stubove, volan i tablu u alkantari a sada ja preterujem? Mislim da ti samo nisi navikao da se vozis u takvom enterijeru pa ti se cini da je preterano. Da budem iskren, na slikama to sve izgleda drugacije (dosta tamnije) nego uzivo, enterijer uzivo izgleda fantasticno. Da je fabrika ugradila neku gumiranu plastiku koja je prijatnija na dodir, ne bih nista dirao... Posto je u GP-u plastika tvrda kao kamen, ovo presvlacenje je bilo neophodno... Sada kada ulazim u auto prvo ispipam sve (a materijal mekan ko dusa...) pa tek onda krenem da vozim... PS celo to presvlacenje (nebo, stubovi i tabla) je izaslo 250 e, da ne pomisli neko da je ulozeno ne znam koliko para, posto je prva asocijacija da to sve kosta kao Sv Petra kajgana... Nije prava alkantara u pitanju a i majstor je izuzetno jeftin tako da sam iskoristio priliku... Edited December 25, 2020 by Lufti 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
MS PK 7718 Posted December 25, 2020 Auuu sta napravi od punta , svaka cast! Posto su sedista, a ovo presvlacenje!? Послато са SM-A307FN помоћу Тапатока 1 Lufti reacted to this Quote Share this post Link to post Share on other sites
Lufti 688 Posted December 25, 2020 Fala kolega! Sto se sedista tice, placena su malo vise nego sto sam zeleo ali puno manje nego sto mogu da ih prodam... 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
bane1321 5823 Posted December 25, 2020 Auu ludilo! Ali vrlo pozitivno! Vozio sam GP i idalje mi je veoma šarmantan! Svaka čast! 1 Lufti reacted to this Quote Share this post Link to post Share on other sites
MS PK 7718 Posted December 25, 2020 Fala kolega! Sto se sedista tice, placena su malo vise nego sto sam zeleo ali puno manje nego sto mogu da ih prodam... Pa to je fenomenalno Послато са SM-A307FN помоћу Тапатока 1 Lufti reacted to this Quote Share this post Link to post Share on other sites
zunto 503 Posted December 25, 2020 bravo mladicu, sve dok ne preteras imas podrsku. Послато са MI 9 помоћу Тапатока Quote Share this post Link to post Share on other sites
Lufti 688 Posted December 25, 2020 Hvala za ovo "mladicu"! Znam da je tanka linija izmedju estetski dobro uradjenog posla i kica... Ceo auto je radjen u minimalistickom stilu sto se eksterijera tice, poskidani su svi znakovi sa gepeka i nema nepotrebno napadnih detalja. Spoljasnost ce ostati svedena. Enterijer zbog alkantare deluje bogato ali je uradjen u samo dve preovladavajuce boje (mada crna i bela po definiciji to nisu..) koje su, po mom kromnom misljenju, uravnotezeno rasporedjene. Kada se budu ubacila i sportska sedista, sve ce se uklopiti u tu neku zamisao koju vec dugo pokusavam da pretvorim u realnost... 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
Zvezdo 931 Posted December 25, 2020 Ovo uživo izgleda kao full premium auto! Samo još gornji deo one odvratne plastike da se presvuče i kraj priče! Sedišta odnosno trkaće kadice kada dođu unutra onda će biti ludnica. Sada mi je krivo što sam prodao Grandea! 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
Zvezdo 931 Posted December 25, 2020 Jedna anegdota ili kako da nazovem. Natovarimo Sabelt u svetu kravu i skrenemo po tablu kod Nikole u Lajkovac... Nakon par Km na svetoj kravi se upali check engine lampica ali bez ikakvih upozorenja ili gubitka snage vozila. Prepametna nemačka elektronika je izgleda detektovala "strano" telo u vidu instrument table iz Grandea! Nakon istovara table lampica se je ugasila! Uzrok lampice je da DPF ne pročišćava dovoljno. Zadnja regeneracija je bila pre 600Km a verovatno je naučen na uobičajenu mešovitu vožnju kada radi regeneraciju na 450-500Km. Jedva čekam da vidim šta će upaliti od upozorenja kada natovarimo motor od Škorpiona! 2 Grafit and horvat reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3396 Posted December 25, 2020 Nije prošlo nezapaženo... Quote Share this post Link to post Share on other sites
Nikola031 936 Posted December 26, 2020 Svaka cast na radovima i sedistima, pratio sam na fejsu, vrhunski izgleda 1 Lufti reacted to this Quote Share this post Link to post Share on other sites
horvat 6451 Posted December 27, 2020 Bolje nego fabricki Abarth 1 Lufti reacted to this Quote Share this post Link to post Share on other sites
