despotbg 0 Posted October 22, 2015 Cao, kupio sam novog 500la pre par dana. Presao sam 400km i primetio nesto cudno. Naime kada sam u leru na ravnici prilikom pustanja kvacila gas se podigne za 300obr negde pri vrhu pustanja. Mogao bi i da odrzavam te obrtaje na toj tacki pustanja... Kada upalim kola(hladna / vruca) tek to se ne javlja tek nekad u voznji ... Video snimak pokazuje obrtaje https://www.dropbox.com/sc/bwigbf2krfk672o/AADiyfNh-CUeBIqy3ftbvc_Ma Quote Share this post Link to post Share on other sites
Ticma 537 Posted October 22, 2015 Ako imas Start&Stop sistem ili Hill asist to je normalno Quote Share this post Link to post Share on other sites
despotbg 0 Posted October 22, 2015 Imam Hill Holder... Extra, samo da ne moram po servisu da idem... Mada nemam pojma zasto to radi kad je van brzine Quote Share this post Link to post Share on other sites
Markobgd 609 Posted October 22, 2015 Ima i kod mene hill holder pa ne podiže gas, nisam siguran da ima veze sa tim.... Osim ako nije baš nešto vezano za L-a Quote Share this post Link to post Share on other sites
Ticma 537 Posted October 22, 2015 Kod mene na EVO-u dize obrtaje i receno mi je da je za vozila sa S&S i hill asist sistemom to ok. Ne hill holder nego assist. Quote Share this post Link to post Share on other sites
totti 13165 Posted October 22, 2015 Ma ok je to. Ja to videh i na Volvou V/S 60Pomaže onima koji kreću bez gasa da se ne ugasi motor. Quote Share this post Link to post Share on other sites
Markobgd 609 Posted October 22, 2015 Ok onda. Quote Share this post Link to post Share on other sites
totti 13165 Posted October 22, 2015 Hill holder i hill assist su iste stvari, samo zavisi kako ih ko zove. Quote Share this post Link to post Share on other sites
joshibeast 74 Posted October 22, 2015 Jel može to na L-u da se ugasi?Ako može neka proba kolega sa ugašenim.Ne razumem se. Ja imam stariji sistem na Stilu - noga holder Quote Share this post Link to post Share on other sites
Ticma 537 Posted October 22, 2015 Nije isto barem ne kod Fiata, na Bravu holder je drzao kocnicu jos sekund ili vise sta znam a asist sam doda gas kako auto ne bi krenuo u nazad ili se ne bi ugasio. Quote Share this post Link to post Share on other sites
despotbg 0 Posted October 22, 2015 (edited) U paketu opreme za 500l Pop Star pise da iamm HIll holder ne assist, i ja sam mislio da je to istoNema da se ugasi... To bi prvo probao. Sumnjao sam da je bas ovo:Ma ok je to. Ja to videh i na Volvou V/S 60Pomaže onima koji kreću bez gasa da se ne ugasi motor.Hvala Edited October 22, 2015 by despotbg Quote Share this post Link to post Share on other sites
Deda Jung 5 Posted October 22, 2015 Ciao i čestitke na kupovini. Ponašanje koje si opisao je sasvim normalno za novije automobile. Ako pročitaš uputstvo videćeš da piše da auto kreće iz mesta bez dodavanja gasa. Tj. auto sam dozira gas na osnovu raznih parametara bez upliva vozača. Ako ti kao vozač dodaješ gas pri kretanju, povećavaš bespotrebno potrošnju goriva.Probaj da kreneš bez gasa i videćeš da se neće ugasiti. Takođe ako pustiš papučicu gasa u recimo drugoj brzini, kada broj obrtaja padne ispod određene vrednosti, auto će sam dodati gas koliko je potrebno da se ne bi ugasio. Ovo zapravo važi i za prvu brzinu, i za treću. Verovatno i za sve ostale, pa i rikverc. Quote Share this post Link to post Share on other sites
Sinnerman 17 Posted October 22, 2015 I moj auto sam dodaje gas u leru od jula 2013 god... U voznji krecem sa gasom dok po dvoristu uglavom idem i do druge bez gasa, presaltam u drugu, pustim ga da krene a onda preko toga lagano dodajem gas... isto tako kada isparkiravam u rikverc u 99% slucajeva je bez gasa... Quote Share this post Link to post Share on other sites
mbsbane 0 Posted October 22, 2015 moj je 2015 god i isto ima tu foru sa gasom i to ti je normalno .Deda Jung je to lepo objasnio. Quote Share this post Link to post Share on other sites
NeleT 0 Posted October 25, 2015 Sasvim je normalno da krece bez pritisaknja gasa , medjutim ja sa kvacilom imam drugi problem prilikom prtiskana kvacila dok je u prvoj ili drugoj prilikom odvajana cuje se udarac! Ovo je izrazeno pogotovo na uzbrdicama i pri manjem broju obrtaja 2500-3000. Dok sam vozio punto ovakvi udarci se nisu desavali. Da li neko ima slicna iskustva? Pokusacu sutra ujutru da snimim sta se desava. Quote Share this post Link to post Share on other sites
lapobb 1 Posted October 25, 2016 On 10/22/2015 at 2:57 PM, despotbg said: Cao, kupio sam novog 500la pre par dana. Presao sam 400km i primetio nesto cudno. Naime kada sam u leru na ravnici prilikom pustanja kvacila gas se podigne za 300obr negde pri vrhu pustanja. Mogao bi i da odrzavam te obrtaje na toj tacki pustanja... Kada upalim kola(hladna / vruca) tek to se ne javlja tek nekad u voznji ... Video snimak pokazuje obrtaje https://www.dropbox.com/sc/bwigbf2krfk672o/AADiyfNh-CUeBIqy3ftbvc_Ma isto i kod mene i uzasno me nervira. Quote Share this post Link to post Share on other sites
Deda Jung 5 Posted October 26, 2016 9 hours ago, lapobb said: isto i kod mene i uzasno me nervira. Vozači stare škole Ovaj sistem (autonomno dodavanje gasa pri kretanju) se pakuje i u novije Korejce, Japance itd. Još pre Fiata viđao sam ovo kod Hyundai-ja, Kia-e, Toyota-e... Ne znam za Nemce ali svakako ga nije Italijan izmislio. Meni je prvih par meseci smetalo kad dodaje gas a menjač nije u brzini. Tada je jasno da nemam nameru da krenem i bezveze dodaje gas i diže tenziju. Ali navikne se čovek posle nekog vremena. Quote Share this post Link to post Share on other sites
totti 13165 Posted October 26, 2016 Ima toga u još dosta automobila. U Volvu npr... Quote Share this post Link to post Share on other sites
lapobb 1 Posted October 26, 2016 @Deda Jung slazem se . kod "volvo 240 GLT" nisam primetio ( duuugo sam ga vozio ). mada kod "hyundai akcent GLS" 2000 godishte, vozio sam ga do 2016 april nisam neshto primetio taj ler gas. i shto je interesantno kod "fiat 500L" taj ler gas , primetio sam pre 2-3 dana na predjenih 4000km. ! Quote Share this post Link to post Share on other sites
Zhorz 102 Posted October 26, 2016 (edited) nema ni na volvou 264 TE, ko zna sta je totti vozio Edited October 26, 2016 by Zhorz Quote Share this post Link to post Share on other sites
totti 13165 Posted October 26, 2016 Ma na Volvo Amazonu, kakav 264... Quote Share this post Link to post Share on other sites
