silenci 2315 Posted May 1, 2019 aha dobro moze da se sad nezezam,hvala ti Quote Share this post Link to post Share on other sites
bit 936 Posted May 1, 2019 (edited) Kako skinuti čiste instalacije sa Microsoft sajta pa onda samo primeniti neki od kms lepa tema za pročitati i primeniti na benchmark forumu dovoljno zadnjih desetak postova https://forum.benchmark.rs/showthread.php?383329-Tutorijal-kako-legalno-skinuti-instalacione-iso-e-svih-verzija-Windowsa-i-Office-a Edited May 1, 2019 by neshaoct sređen link 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Pluto 448 Posted May 1, 2019 KMSpico je najbolji aktivator, ali na netu je 90% virusčina, mogu da uploadujem i okačim ovde fail ako dozvoli @neshaoct samo mora da se ugasi Defender na Win 10, pošto ga on odma briše 3 bit, silenci and djomla reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted May 1, 2019 22 minutes ago, Pluto said: ...mogu da uploadujem i okačim ovde fail ako dozvoli @neshaoct Uradi upload gde hoćeš, samo nemoj link jednostavno ''zalepiti'' u svoj post na Forumu, nego ga stavi u ''Code''. Quote Share this post Link to post Share on other sites
Pluto 448 Posted May 1, 2019 https://gofile.io/?c=ADOkfV Takođe može i licenca za Office 1 bit reacted to this Quote Share this post Link to post Share on other sites
silenci 2315 Posted May 1, 2019 e Pluto,za sta je ovo,jel to moj problem il nesto trece Quote Share this post Link to post Share on other sites
shomispc 832 Posted May 1, 2019 Za tvoj problem mora da se reinstalira ceo operativni sistem, nema drugog resenja 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
silenci 2315 Posted May 1, 2019 to sam i mislio,to ja kao da vozim auto sa dva cilindra,a nisam ni znao dok mi momak sto sam kupio od njega memoriju nije rekao Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted May 2, 2019 @silenci Sve što si stoji na particiji (delu) hard diska gde ti je Windows, ili prebaci na onaj drugi deo diska, ili na neki USB, jer sve će to biti prebrisano kad uradiš instalaciju novog Windows-a. Ako tu nemaš ništa što ti treba, onda ne moraš ništa da prebacuješ nigde, briši sve. Sve programe ćeš morati ponovo da instaliraš, od browser-a, pa dalje. Kad sve to zavšiš i proradi kako treba, obriši stari Windows kako bi oslobodio mesta na C (pretpostavljam da ti tu stoji Windows), ali se ne briše kao svaki drugi fajl, nego ovako: https://www.cnet.com/how-to/how-to-delete-the-windows-old-folder-from-windows-10/ Quote Share this post Link to post Share on other sites
silenci 2315 Posted May 2, 2019 a imam eksterni hard disk,pa cu u njega sve,al nemam nesto pun,nesto slika i filmova i nesto dokumenata,pa cu onda da krenem Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted May 2, 2019 @silenci Odlično, sve što ti treba sa C prebaci na taj eksterni. Možeš da pogledaš programe koje sad imaš na kompu, pa napraviš njihovu listu kako bi ti lakše bilo da ih instaliraš ponovo. Možeš ih odavde verovatno sve pokupiti: https://filehippo.com/ Možeš i sada, dok nisi ništa još počeo, da poskidaš sve poslednje verzije programa koje imaš, napakuješ i njih na eksterni, pa onda samo redom instaliraš sve na novom Windows-u. Neće ti biti problem oko Win instalacije videćeš, uglavnom je sve samo klik na ''Next'' i ''Agree''. Malo će te smarati Cortana oko podešavanja, ali nije ništa strašno... Quote Share this post Link to post Share on other sites
djomla 8385 Posted May 2, 2019 Slike, muziku itd baci na drugu particiju, trebace ti i flash da spakujes na nju instalaciju 10ke. To mozes uz pomoc prograna koji skines odavde https://rufus.ie/ 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
bit 936 Posted May 2, 2019 I ono što se uvek previdi, šifre iz browsera za forume mejlove i td, prebaciti 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
silenci 2315 Posted May 2, 2019 sve sam prebacio na eksterni disk,a programe cu sve ponovo instalirati,kad bude sve zavrseno Quote Share this post Link to post Share on other sites
arnage 28 Posted May 4, 2019 (edited) Nemojte da skidate i instalirate aktivirane Win10 sa torrenta ili bilo odakle. Sve to ima definisane bitcoin miner snippete i slične stvari koji će vam ojaditi resurse kompa. Win10 samo i isključivo treba skinuti sa Microsoft sajta. Sve drugo je besmisleno. Sad, kako to dobiti za Dž stvarno ne znam. Ja sam kupio USB Win10 Home licenciran... Edited May 4, 2019 by OmenVeritas Quote Share this post Link to post Share on other sites
Siki97 395 Posted May 4, 2019 Ako pravis butabilan fles preko Rufusa on ti u novim verzijama ima podesavanje samo za UEFI. U zavisnosti od toga kako pravis butabilan fles dal UEFI ili Legacy, moraces drugacije da setujes BIOS. Eo link kako da aktiviras Windows10, aktivacija radili ali zna nakon odredjenog vremena pukne. Onda ga ponovo aktiviraj. Neces imati problem kao sa raznim generatorima koje Defender prepoznaje... 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
silenci 2315 Posted May 6, 2019 (edited) e konacno resen windows,nisam mogao nikako sam,zahvaljujem presedniku i drugu clanu Nocni koji je odradio instalaciju windowsa Edited May 6, 2019 by silenci Quote Share this post Link to post Share on other sites
DraganUS 447 Posted May 11, 2019 On 5/1/2019 at 7:51 PM, Pluto said: https://gofile.io/?c=ADOkfV Takođe može i licenca za Office Fale ti fajoovi, verovatno ti je antivirus sklonio pre neko sto si zapakovao. Quote Share this post Link to post Share on other sites
Pluto 448 Posted May 11, 2019 Fale ti fajoovi, verovatno ti je antivirus sklonio pre neko sto si zapakovao. Glupi defender, ubacujem sutra novi linkSent from my POCOPHONE F1 using Tapatalk Quote Share this post Link to post Share on other sites
Pluto 448 Posted May 14, 2019 @DraganUS izvini što si čekao, sada bi trebalo da bude ok https://ufile.io/rgjs7nkg Quote Share this post Link to post Share on other sites
sima21 3 Posted May 21, 2019 (edited) A da ga preuzmete preko sajta? Samo se nadogradi? https://www.microsoft.com/sr-latn-rs/software-download/windows10 Edited May 21, 2019 by sima21 1 silenci reacted to this Quote Share this post Link to post Share on other sites
Nebek 1418 Posted May 2, 2021 (edited) Jedan od najvećih problema sa Defenderom kod W10 je nemogućnost isključenja istog, odnosno da bi se isključio Defender u potpunosti potrebno je proći nekoliko zahtevnih setovanja, a što je znatno komplikovanije nego kod prethodnih operativnih sistema. Takođe, i pored potpunog isključenja Defendera dešava se da se nakon spontanog (da ga tako nazovem) apdejta neki delovi istog ponovo aktiviraju, tako da je potrebna stalna kontrola da li je Defender isključen. To je jedan od glavnih razloga što se neki programi ne mogu instalirati, jednostavno Defender ih prepoznaje kao opasnost i odmah ih odstranjuje. Edited May 2, 2021 by Nebek 1 dach@ reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted May 7, 2021 Microsoft konačno menja ikonice iz ere Windowsa 95 Microsoft se priprema da konačno osveži svoje ikonice koje potiču još iz ere operativnog sistema Windows 95. Softverski gigant je polako unapređivao ikonice koje koristi za Windows 10, a to je deo ''vizuelnog podmlađivanja'' planiranog za ovu godinu. Niz novih sistemskih ikonica smo videli u martu, a među njima su ikonice File Explorera, Foldera, Recycle Bina, ikonice diskova i slično. Microsoft sada planira osvežiti ikonice iz ere Windowsa 95 koje su takođe deo Windowsa 10. Deo fajla shell32.dd u Windowsu 10 su nove ikonice za memoriju, floppy i networking. DLL je ključni deo Windows Shall-a, koji prikazuje ikonice u različitim prozorima operativnog sistema. Sve promene su deo velikog osvežavanja dizajna kodnog imena ''Sun Valley''. Vizuelne promene dolaze sa Windows 10 21H2 nadogradnjom koja se očekuje u oktobru. 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
gagyns 35 Posted May 7, 2021 https://msguides.com/microsoft-software-products/2-ways-activate-windows-10-free-without-software.html metod jedan za aktivacju Windows-a 10 proveren više puta:) 1 bit reacted to this Quote Share this post Link to post Share on other sites
