krcevac2011 0 Posted May 5, 2015 e ljudi imam gadan problem tesko pali i neravnomerno radi na leru i gasi se,a ne pusi na aspuh nista i ne tros ulje! Jel neko ima neku ideju sta je to, odjednom su se pojvili sintomi pre par meseci... pumpa ne curi i na dovodno crevo sam ugradio nepovratni ventil Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 5, 2015 Uzubljenje, stepen paljenja, ventili, pumpa, dizne, fals vazduh, vakum crevo,.. jel nesto radjeno pre tog trokiranja? Quote Share this post Link to post Share on other sites
krcevac2011 0 Posted May 5, 2015 nije radjeno nista,osim nepovratnog ventila,kada duze stoji tesko upali izbaci gomilu crnog dima i trokira jedno 20 sekundi pa posle zalece nema vise miran rad Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 5, 2015 Probaj bez njega da vidis da li ce normalno da radi u leru. Jel ti vlazi pumpa negde? Neko crevo? Quote Share this post Link to post Share on other sites
krcevac2011 0 Posted May 5, 2015 i sa i bez isto,pumpa suva,gledao pisa pumpa na sve strane i bolje ali od mje suve Quote Share this post Link to post Share on other sites
deki87 7 Posted May 5, 2015 Samo Bosch Pumpa. Quote Share this post Link to post Share on other sites
krcevac2011 0 Posted May 5, 2015 znaci remont Quote Share this post Link to post Share on other sites
deki87 7 Posted May 5, 2015 Kad je stave na sto znace se. Quote Share this post Link to post Share on other sites
krcevac2011 0 Posted May 5, 2015 jel pasuje turbina od jtd-a na ovu moju bedu? Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 5, 2015 Sta ce ti? Samo je skuplja i da pasuje a ne dobijas nista. Quote Share this post Link to post Share on other sites
sindrom 18 Posted May 6, 2015 To su dizne i grejaci, proveri njih prvo da ne bacas pare dzabe. Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted May 6, 2015 Reko bih i ja da su grejaci za paljenje problem, ima isti taj problem i kolega sa tipom a za nepravilan rad bih reko dizne. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 6, 2015 Nece zbog grejaca stalno da trokira u leru. Ja tipujem na s.paljenja, dizne, ventile a mozda je i sama pumpa, iili vakum...ma sve sto sam reko gore vec Quote Share this post Link to post Share on other sites
krcevac2011 0 Posted May 7, 2015 grejaci su ok,probacu dizne ali da su one onda bi pusio crno na auspuh,problem je palenje i ler...juce sam primetio da vecim usponima nema snagu ali i opet preko 3000 obrtaja ne dimi za kolima Quote Share this post Link to post Share on other sites
krcevac2011 0 Posted May 7, 2015 cim budu bile neke donacije u vidu kesa teram ga kod bosiste pa da vidimo sta je Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted July 12, 2017 Ja na Marei 1.9td u zadnje vreme imam neravnomeran rad na leru, idu obrtaji od 600-900 onako skakucu... Ulosci dizni novi i onaj senzor ugla paljenja na pumpi je nov... Sta moze biti ima li ko ideju? Quote Share this post Link to post Share on other sites
