Ivan 17455 Posted November 1, 2015 Vrlo moguce da je kod tebe u pitanju los accu.Pod ovim sto sam prethodno napisao nisam mislio ni na koga konkretno. Vec neko moje iskustvo pri ugradnji vise uredjaja i koriscenju Proxy procedure, koje moze nekome koristiti. Quote Share this post Link to post Share on other sites
mitrovic87 0 Posted March 7, 2016 (edited) Pozdrav svima! Zamenio bih Km sat na stilu 1.9 jtd sa Abarth-ovim satom pa me zanima da li je to moguce i da li ce sve raditi, posto ja imam onaj manji ekran a abartov je veci. i drugaciji je raspored lampica. Nadjoh na oglasima, covek tvrdi da pasuje na sve modele. http://frame.goglasi.com/frame?eid=99344256&q=%20Kilometar%20sat%20Fiat%20Stilo%20Abarth%20 Hvala unapred! Edited March 7, 2016 by mitrovic87 Quote Share this post Link to post Share on other sites
nemanjas 0 Posted March 7, 2016 (edited) odgovara dzek na dzek, ali posto je ta tabla namenjena samo za benzince ti kod sebe ugradnjom te tabe ces izgubiti lampicu za grejace i nivo ulja kad das kontakt,inace sem toga sve ce da radi ok Edited March 7, 2016 by nemanjas Quote Share this post Link to post Share on other sites
Lazar357 5 Posted July 5, 2016 Da li neko zna gde mogu kupiti instrument tablu od abartha ? Nadam se da nisam pogresio temu jer vidim da se o tome pise tj o ugradnji Quote Share this post Link to post Share on other sites
Coa123 0 Posted July 5, 2016 Neko ima kombinaciju abart tabla + fabrički parking senzori? Sve povezao, uradio proxy, uredno registovano na can ali ne dozvoljava aktiviranje indikacije parking senzora na instrument tabli. Može ili jok? Quote Share this post Link to post Share on other sites
Lazar357 5 Posted July 5, 2016 Koja je cena? Nisu mi bitni parking senzori Quote Share this post Link to post Share on other sites
Coa123 0 Posted July 5, 2016 Tebi nisu, ali meni jesu. Peđa iz Inđije (imaš njegovu temu ovde na forumu), a cena... 30-50€. Quote Share this post Link to post Share on other sites
Lazar357 5 Posted July 5, 2016 To je cena za abartovu instrument tablu? Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted July 6, 2016 On 7/5/2016 at 9:35 PM, Coa123 said: Peđa iz Inđije (imaš njegovu temu ovde na forumu) Evo i linka ka temi: https://www.fiat-lancia.org.rs/forum/index.php?/topic/71141-fiat-polovni-delovi-inđija/ Quote Share this post Link to post Share on other sites
Lazar357 5 Posted July 9, 2016 da li iko zna zasto nece da mi se poveze na Proxy aligment preko elma 327 i mes aplikacije? izbaci ovo empty proxy file in compiuter body (bcm)? dali iko zna u cemu je problem Quote Share this post Link to post Share on other sites
joshibeast 74 Posted July 9, 2016 Koji elm? Na usb ili bt? Quote Share this post Link to post Share on other sites
Coa123 0 Posted July 9, 2016 Verovatno bt. Desilo mi se kada sam dodao parking senzore na can, ali samo za probu. Slab spoj i ta poruka na mes-u. Ništa zabrinjavajuće, još ako je high latency... Quote Share this post Link to post Share on other sites
Lazar357 5 Posted July 9, 2016 Usb je nije bt. Ne znam stvarno do cega je... Ali jos uvek nista nisam novo stavio. Hteo sam samo da isprobam u proxiju kako ulazi. Trebam staviti Abartovu tablu. Pa da pogledam sta i kako. Jel nije mozda do toga jer nema novih uredjaja. Quote Share this post Link to post Share on other sites
Lazar357 5 Posted July 11, 2016 On 30.4.2015. at 7:07 PM, makidada said: Pozdrav svim forumasima. Citao sam dosta postova gde sta i kako se resavaju pojedini problemi i voleo bih da izrazim veliku zahvalnost mnogima posto ovde postoji resenje za gotovo svaki kvar ili nedoumicu oko resavanja nekog kvara. Mislim da je bilo par reci oko ugradnje km sata iz Abartha u obican stilo bilo da je benzinac ili dizel E pa da krenemo: Vozim stila 1.6 16v i vec me dugo kopka da li je moguce ubaciti ovaj prelepi sat kod mene. Dosao sam u posed jednog sata iz abartha, doslo se do malo slobodnog vremena i usledila je proba. Na mom satu koji je obican postoji samo jedan konektor dok na abarthovom dva. Znaci jedan je visak a drugi je identican kao i na mom satu. Taj drugi je koliko sam skontao za parking senzore i jos ponesto ali i to cu saznati posto moj drugar ima celog abartha na otpadu pa se mora pogledati njegova instalacija i cemu tacno sluzi taj dzek koji je sad trenutno slobodan. Bilo kako bilo sat je ubacen bez ikakvih problema, vrlo je lako to je vec i opisano u nekim postovima ali skracena varijanta je da se volan izvuce skroz nazad i dole, odvrnuse 4 sarafa i tabla se lagano izvuce napolje. Otkaci se dzek i uz malo manevrisanja sa leve strane volana tabla je slobodna. Da ne zaboravim raskacivanje kleme nije neophodno bitno je samo da kljuc ne bude u bravici. Ubacivanje abarth sata ide obrnutim redosledom od malopredjasnje procedure. Dao sam kontakt igle cuda sat radi ali se desava sledece: pisti iz sve snage sa gomilom gresaka tipa - parking sezori, sezor za kisu, senzor svetala i jos neke greske koje nisam razumeo i to sve uz treptanje kilometraze. Isto tako meni u samom satu je skracen, nema stelovanja vremena, datuma, potrosnje i slicno posto se to na abarthu radi preko CN+ ili ti njegove navigacije . Sve je to normalno posto je sat izvadjen iz auta koji je imao ful opremu (cuveni ABARTH). Znaci moralo je prilagoditi sat mom stilu koji je dosta siromasniji sa opremom tacnije ima abs,asr, edb, znaci klasika. Uz pomoc ELM 327 i FES ili MES problem je resen. Procedura je sledeca (nisam slikao ali ako nekom treba detaljno slikacu pa cu postaviti) Udje se u MES opciju BODY ili ako je program na srpskom SASIJA i zatim CAN Setup/ PROXI Alignment Procedure zatim F10 CONNECT ili POVEZIVANJE, zatim F7 ADJUSMENTS ili PRILAGODJAVANJE. Prva stavka je PROXI ALIGNMENT ......... Koji MES si koristio za alignment proxi...? tj koju verziju? Quote Share this post Link to post Share on other sites
makidada 14 Posted July 13, 2016 MES 2.2 radi bez problema, instaliraj prave drajvere i nemas brige. Odgovor za sve koji pitaju da li abarth tabla moze ili ne da se ubaci u ovaj ili onaj stilo................. Sam naslov teme i njegova sadrzina potvrdjuju da moze u sve verzije stila bez problema. Samo citajte temu od pocetka tj. prvu stranu gde je sve lepo i do detalja objasnjeno sto recima sto slikovito............... On Tuesday, July 05, 2016 at 8:03 PM, Coa123 said: Neko ima kombinaciju abart tabla + fabrički parking senzori? Sve povezao, uradio proxy, uredno registovano na can ali ne dozvoljava aktiviranje indikacije parking senzora na instrument tabli. Može ili jok? Mogu da rade i parking senzori samo ih treba dobro povezati i aktivirati u mes-u . Mora da se iz donora tj. auta iz kog se vade senzori skinuti sva instalacija vezana za njih i to isto uredno povezati u svog stila i t mora da radi. Quote Share this post Link to post Share on other sites
Lazar357 5 Posted July 19, 2016 Hvala na odgovoru. Resio problem sa povezivamjem na can... samo cekam abarth km sat. Quote Share this post Link to post Share on other sites
Coa123 0 Posted July 19, 2016 Mogu da rade i parking senzori samo ih treba dobro povezati i aktivirati u mes-u . Mora da se iz donora tj. auta iz kog se vade senzori skinuti sva instalacija vezana za njih i to isto uredno povezati u svog stila i t mora da radi. Nismo se razumeli... Sve sam povezao, senzori rade, pište, viču, registrovani na can, tu je sve ok, ali ne mogu da aktiviram indikaciju na abart tabli, da mi pokazuje rastojanje, crtice, šta god... Sent from my LG-D802 using Tapatalk Quote Share this post Link to post Share on other sites
Lazar357 5 Posted August 11, 2016 (edited) Stavio sam abarth sat i sve sam ok uradio. Ali sad mi izbacuje airbag failur prvo obavestenje se skloni a drugo koje ide za par sekundi uopste ne mogu skloniti sa ekrana vec non stop stoji i svitka. Ne pisti. A na prosloj tabli aam mogo i prvo i drugo. Zasto je to tako? Mozda se na drugo dugme sklanja greska a ne na meniju? Edited August 15, 2016 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Zvezdo 931 Posted August 11, 2016 Pa zar ne bi bilo bolje da popraviš te greške? Postoji i drugi u nas popularan način popravka, zalepiš traku preko ekrana ili žvaku preko kontrolne lampice. Quote Share this post Link to post Share on other sites
Lazar357 5 Posted August 11, 2016 Pa niti lepim zvake a ni trake. Ako nemas pametnije nista onda nemoj ni pisati. To su uobicajni problemi sa stilom. Niti sam pitao kako popraviti vec kako skloniti obavestenja. Mozda cu i resiti ali ovo me interesuje a ne zvake i trake Quote Share this post Link to post Share on other sites
Bingodalton 726 Posted August 11, 2016 Pa...covek ti lepo rekao. Popravis i time uklonis. Ili zalepis nesto da ne gledas. Ti bi sad neko dugme koje kliknes i onda ne iskacu obavestenja bas ona koja ti je zelis. Ako neko bas ume, nek ti isprogramira da airbag ne obavestava, ali je to prilicno opasno, pogotovo nekom auto kasnije prodati. Zaboravi se covek lako, pa se nadam da ne postoji neko ko tako nesto zaista i radi. Kazes tipican kvar na Stilu, onda je i popravka tipicna i lako se odradi. Quote Share this post Link to post Share on other sites
Coa123 0 Posted August 11, 2016 Ne možeš skloniti obaveštenje. Tako je i kod mene bilo kada sam prešao na abart tablu. To me i nateralo da popravim i sad mir. Quote Share this post Link to post Share on other sites
Lazar357 5 Posted August 11, 2016 Ljudi neka svetli. Nije mi to problem pitao sam samo nisam reko da necu promeniti. Samo pitam.jer mi je nova tabla i ne znam da li je isto kao i na staroj. Znaci ne moze se ukloniti. Jer od te greske ja ne mogu uci u meni namestiti sat i slicno Nisam ja hteo to samo da ga ne gledam vec da bih usao u meni. Niti zelim da isprogramiram zelim sve uredu a ne zamaskiranje. Samo me interesuje da bih usao u meni. Quote Share this post Link to post Share on other sites
Lazar357 5 Posted August 11, 2016 Danas stigla Abarth tabla skinuta stara stavljena Abarth uradjen proxy aligment i sljaka sve kako treba. Sve po uputstvu prvog posta sa teme. Ali sad imam problem mislim isti ssam imao i na staroj ali sam tamo mogoao ukloniti obavestenje sa ekrana sada na abarthovoj tabli ne za airbag ali to cu resiti air bag i tako ukloniti to Quote Share this post Link to post Share on other sites
