Axic 20023 Posted May 12, 2018 Jel mozes da napišeš cenu ako nije problem? Quote Share this post Link to post Share on other sites
vicent 1263 Posted May 12, 2018 Naravno da nije problem. 3490 rsd + brza pošta = 3890rsd Quote Share this post Link to post Share on other sites
Axic 20023 Posted May 12, 2018 Očekivao sam veću cenu obzirom da je ozbiljan proizvođač u pitanju. Hvala za info. Quote Share this post Link to post Share on other sites
vicent 1263 Posted September 30, 2018 Posle skoro četiri godine druženja, sinoć, počeo da otkazuje Renoov termostat u crevu, Vernet. Prvo sam čuo ventilatore hladnjaka, šište ko tajfuni. Vreme hladnjikavo, otkud to. Temperatura za crtu, skoro dve prešla polovinu. Uključim grejanje, ništa, duva hladno. Stanem malo, ohladim ga, upalim, otvori termostat, proradi grejanje, zakuca se skazaljka na polovinu. Danas sam se otvorio 550 rsd, kupio i ugradio novi. Idemo dalje. 2 kreator and Axic reacted to this Quote Share this post Link to post Share on other sites
vicent 1263 Posted November 9, 2018 Nisam ispravio grešku, nije jadni termostat (Vernet) kriv. Propišala je vodena pumpa SKF i onako, pederski, gubila kapljice, koje su odmah isparavale i bile su teško uočljive. Ponovo odrađen veliki servis na 53000 km. Punto je počašćen i zimskim alu felnama. Sad smo kompletni. 3 Martin, neshaoct and MiloshShomy reacted to this Quote Share this post Link to post Share on other sites
Martin 799 Posted November 9, 2018 Pravi momački auto! Quote Share this post Link to post Share on other sites
danijel55 699 Posted November 9, 2018 Lep puntisa,samo sto je farbar lepo zabrljao posao na levoj strani Quote Share this post Link to post Share on other sites
MS PK 7732 Posted November 9, 2018 Ja zato uvek kazem da v.servis radim do 50hkm, ako je neki losiji set i ranije. Neki se cude, a mnogi imaju i takva iskustva u najboljem slucaju.. Quote Share this post Link to post Share on other sites
Axic 20023 Posted November 10, 2018 On 11/9/2018 at 1:39 PM, vicent said: Skinuo si folije? Quote Share this post Link to post Share on other sites
vicent 1263 Posted November 10, 2018 Pa morao sam. Sad sam kao u izlogu. 1 Axic reacted to this Quote Share this post Link to post Share on other sites
Martin 799 Posted November 10, 2018 On 11/9/2018 at 1:39 PM, vicent said: Nisam ispravio grešku, nije jadni termostat (Vernet) kriv. Propišala je vodena pumpa SKF i onako, pederski, gubila kapljice, koje su odmah isparavale i bile su teško uočljive. Ponovo odrađen veliki servis na 53000 km. Pogledaj kakav je bio moj zupčasti nakon 53000 km!!!! Quote Share this post Link to post Share on other sites
vicent 1263 Posted November 10, 2018 Pre 10-ak dana radio tehnički u 10+. Cifra 25400 rsd. Folije su morale da se skinu jer nisam želeo da jurim razne papire, potvrde i još da istresem 100eur. Na valjcima opšte oduševljenje, normalne sile kočenja su oko 1700 Nm a kod mog plavca 2350Nm. Galfer High Performance je čudo. Izsuvni gasovi kao da ima katalizator. Sve extra. 6 hours ago, Martin said: Pogledaj kakav je bio moj zupčasti nakon 53000 km!!!! Jbg, stvar je u tome što iako želiš da kupiš kvalitetne delove (po razumnoj ceni), nikad nisi siguran šta si kupio. 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
danijel55 699 Posted November 10, 2018 E da je samo 100e,85 e samo saglasnost od fiata. 1 vicent reacted to this Quote Share this post Link to post Share on other sites
@bane@ 102 Posted November 10, 2018 On 11/9/2018 at 1:39 PM, vicent said: Propišala je vodena pumpa SKF i onako, pederski, gubila kapljice, koje su odmah isparavale i bile su teško uočljive. Ponovo odrađen veliki servis na 53000 km. Punto je počašćen i zimskim alu felnama. Sad smo kompletni. I kod mene je SKF pumpa propišala i to na 36000 km Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted November 10, 2018 Pitanje je sta je SKF spakovao u kutiju... 1 Martin reacted to this Quote Share this post Link to post Share on other sites
vicent 1263 Posted November 11, 2018 I da li je uopšte SKF. 2 alfini0507 and totti reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 13, 2018 Made in Serbia, Temerin. Iako na kutiji pise Made in Italy... 1 vicent reacted to this Quote Share this post Link to post Share on other sites
vicent 1263 Posted November 13, 2018 Na valjcima opšte oduševljenje, normalne sile kočenja su oko 1700 Nm a kod mog plavca 2350Nm. Galfer High Performance je čudo.Milutine, kako komentarišeš kočione sile na valjcima ?Послато са LG-G3 Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 13, 2018 Nista manje nisam ni ocekivao mi koji ga vozimo znamo o kakvoj se robi radi... Posto su mi zadnje plocice obicna serija tj. kako smo ga krstili ovde galfer standard, nosim se nesto mislju da uzmem high performance za nazad, pa da uparim sa sportom napred Quote Share this post Link to post Share on other sites
vicent 1263 Posted June 1, 2020 (edited) Posle 2 druženja sa Galfer HP pločicama, počinjemo da se družimo sa "Akebono" karbon-keramik pločicama, koje bi trebalo da budu identične- slične - bolje Galferu. Javljam kad zamenim i iste legnu na disk. Takođe kupljene u Slajer-u, posle epidemije nemaju Galfer a ja ne volim da krene metal o metal. Već urađen mali servis koji praktikujem na 10 hkm. Drugo nema ništa, sipaj, sedi i vozi ! Edited June 1, 2020 by Ivan Sredjene slike 2 Axic and Milutinac reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted June 3, 2020 @vicent - molim te o povremenim informacijama kako radi akebono verovatno ce morati biti i moj sledeci izbor... Quote Share this post Link to post Share on other sites
vicent 1263 Posted June 4, 2020 Nisam još zamenio pločice, na Galferu ima još za par hiljada km. Javljam kad zamenim i dotične legnu na disk. Poslato sa JSN-L21 pomoću Tapatoka 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
vicent 1263 Posted July 5, 2020 (edited) Galfer pločice odradile svoje, ugrađene Akebono. Prvi utisci su odlični, čekam da fino nalegnu, posle 200 pređenih km, bez nekih snažnih kočenja, mekano i fino. mislim da su baš slične Galferu HP. Edited July 6, 2020 by Ivan Sredjene slike 3 Milutinac, ISV_01 and Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
vicent 1263 Posted October 31, 2020 (edited) Malo smo se ponovili. Alfa 147 JTDm, 2010 god. Edited November 1, 2020 by Ivan Sredjene slike 5 darkman14, MS PK, djomla and 2 others reacted to this Quote Share this post Link to post Share on other sites
Axic 20023 Posted October 31, 2020 Videh ti Punta juče kod toplane sa zimskim setom. Jel si ovo uzeo pa čekaš da prodaš Punta ili je Alfa drugi auto? Quote Share this post Link to post Share on other sites
