siera 2 Posted January 12, 2015 Istok + Baltičke zemlje EU,PL,SK nema mnogo biranja Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted January 12, 2015 Vozis li ribu nekad Quote Share this post Link to post Share on other sites
siera 2 Posted January 12, 2015 Ide i riba iz PL Gdanjsk, dogadja se i to Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted January 12, 2015 Papalina hahahah Quote Share this post Link to post Share on other sites
siera 2 Posted January 12, 2015 Ide svakava riba, dosta ide i te papaline Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted January 12, 2015 A jel imas jos neki svoj kamion ili samo ovaj, Mislim jel vozi neko za tebe jos? Dolazi i panirani program... Quote Share this post Link to post Share on other sites
MS PK 7732 Posted January 12, 2015 Ima i Volvo fh, ima ga na slici Quote Share this post Link to post Share on other sites
silenci 2337 Posted January 12, 2015 svaka cast na reportazi i svaka tebi cast kako si sve ovo izveo,ja kad odem 8 dana na teren u uzice,presedne mijos i sam vozis,verovatno nije lako,jedino ako pokupis neku babusku,onda je ok Quote Share this post Link to post Share on other sites
siera 2 Posted January 12, 2015 Idem isključivo sam i to mi je najlakše Quote Share this post Link to post Share on other sites
Martin 799 Posted January 12, 2015 Biću malo direktan sa pitanjem, stoga unapred - IZVINI! Da li imaš porodicu, kada si kući? Quote Share this post Link to post Share on other sites
siera 2 Posted January 12, 2015 Sad sam kući pa ko zna do kada, kod mene nepostoji pravilo, recimo 31.12.2012 stigao s puta u 20h uveče, prvu sledeću turu sam imao 31.0.3.2013 3 (tri) puna meseca kući ili recimo 17.09.2014 do 03.12.2014 kući jednostavno nje bilo posla tako da ima se vremena, ma dosadni su ovi moji kući Quote Share this post Link to post Share on other sites
MS PK 7732 Posted January 12, 2015 Nemoj nista da te cudi. Kao i svaki privatni posao a u prevozu pogotovo, radi se kad ima posla i dokle god ima posla. Kad nema, tad se sedi kuci. Quote Share this post Link to post Share on other sites
siera 2 Posted January 12, 2015 2012 sam imao jednu priliku 59 dana na putu 8 tura Moskve Quote Share this post Link to post Share on other sites
silenci 2337 Posted January 12, 2015 svaka ti cast,po ceo dan si za volanom,a sigurno da su papirologija i granice najgore,kad cekas,uvek kad negde idem na granici uvek bude mnogo kamionane znam kakva je zarada,al verujem da si zadovoljan,ipak su ovo bas duge relacije,ja kamion vozim samo u igrici,kad vozim po celoj evropi i tako zaradjujem,jako zanimljiva igrica Quote Share this post Link to post Share on other sites
siera 2 Posted January 12, 2015 Jbg, nikad u životu nisam probao da igram igrice, čak su moje kamione napravili mislim za ETS 2 Quote Share this post Link to post Share on other sites
Stilisa 313 Posted January 12, 2015 Vozim i ja po celoj evropi, cak imam i jednog radnika koji vozi za mene, dobro placaju........ali isto u igrici. Samo sto siera igra tu ''igricu'' stvarno. Svaka cast na putopisu, sve lepo zabelezis, treba se posle setiti gde si sta slikao i sta je gde bilo.... Quote Share this post Link to post Share on other sites
siera 2 Posted January 12, 2015 Ma zato i držim datum i vreme na slikama, mada me zbog toga dosta kritikuju da ružim time fotografije Quote Share this post Link to post Share on other sites
siera 2 Posted February 7, 2015 Imam na ovom drugom forumu to već uradjeno srećom postoji copy/paste. i biće ista od reči do reči Ajde da ubcim neku sliku sa početka ove ture, utovar za Belorusiju meso. Ima nekih sličica a kako će se ova tura završiti nemam pojma (nešta mi sumnjivo) Kad sam stigao on je me sačekao Dok sam čekao reko da napravim koju sličicu I onda počinje utovar Pa spašavaj paletu da nepadne 560kg jedna Pa onda ne može da stane druga Pa cirkus Kolorado Pa opet hoće da padne I na kraju je i pala i obe su morali da prepakuju. Užas, kako će se završiti ne znam [/ur l] Dan 2.Problem novi, dobio dokumenta prosledili me na carinu kad tamo-medjutimOdem u špediciju predam dokumenta Tir karnet da mi popune "kaže majstore 5000 dinara" zašta reko 5000 dinara kaže za otvaranje karneta za reko 3 reda što treba da napišete 5000din tako je kaže po cenovniku izvoznik neće to da plati nije njegov trošak a i paritet im je ex work fabrika. Doro reko odlično imamo 2 solucije to neko da plati mesto mene kao prva i druga da skoknem nazad do fabrike da ovo lepo istovare, ništa mi zato ne duguju i da odem u 3 lepe p.m. Oni me gledaju onako belo pa neveruju, valjda nisu naišli na nekog ko vozi svoj kamion pa može da odlučuje o svemu. Onda počinje sazivanje telefonom ovako onako i najveća stvar ne mogu da naplate gotovinski 5000 din nego mora preko računa. Sad se oni izmedju zezaju ko će da plati ali neka ih Nisam stigao pre da se javim a za Tir situacija je sledeća, izvoznik odbio da plati otvaranje karneta (doduše paritet za robu je EX Work) i sa prevozom nemaju ništa. Sledeće rešenje je bilo da platim Ja a to da mi refundiraju, pristao sam na to da dam tih 5000 din i odem da platim al "medjutim" špediter ne može da primi gotovinski novac već samo na račun, mislim se boli me kneko je platio mesto mene i doneli su mi dokumenta za 40minuta bili su brzi. Dodjem na našu granicu i nema neke gužve, odem na drugu stranu da uradim veterinara, tamo nema neke gužve znam ih godinama iz vidjenja kad čovek me otkači s jednom rečenicom" nemate najave, ona treba da je 24h ranije poslata" Ja zovnem opet izvoznika kažu da je najava poslata jutros u 8:30h. Ode špediter da napravi zahtev za vet pregled i da platim taksu kad su iz fabrike pozvali načelnika vet inspekcije onda ima najava i bi gotovo dok sam doručkovao i ručao. Sad se guram na Madjarsku stranu kod Madjara zastoj. Dan 3. Jutros krenuo sa Roszke u 8:35h i oko Budimpešte na M0 istočna obilaznica prizor koji ne vidjam često Imali su izgleda žešće nevreme, izvinjavam se zbog lošijih slika ipak sam u vožnji. Mnogo šume i dalekovoda polomljeno [url=http://s1142.photobucket.com/user/siera9/media/IMG_0365.jpg.html] Deonica M3 koja je počela da propada sredjena dobro, brojanje kilometraže puta Dan 4.Prošao Poljsku, završio na Poljskoj strani za neka 4 sata vremena, nije niko imao na ulasku u terminal, pravo na rampu ali je terminal bio skoro pun, sad sam u medjuzoni do BY strane imam još skoro 2km i to je puno Dan 5. Završih i tu famoznu granicu PL -BY izašao iz BY terminala u ponoć i parkirao se u 00:10h da pravim pauzu. Pošto sam probio sva moguća vremena sad pauza 11h do 11:10h danas Quote Share this post Link to post Share on other sites
