coa565 10 Posted February 28, 2015 I jos mi doneli na kucnu adresu, ma pred vrata Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 28, 2015 Jel imas neke oznake na njemu, po obliku izgleda slicno kao kod mene, ali ne znam da li je isti za Punta 1 i Punta 2 Quote Share this post Link to post Share on other sites
coa565 10 Posted February 28, 2015 E to ne znam mozda i jesu. Ovo pise na njemu:CCD47.uP/F2 Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 28, 2015 Moracu da proverim sta pise kod mene Quote Share this post Link to post Share on other sites
coa565 10 Posted February 28, 2015 Ok, a sto jel te zeza relej? Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 28, 2015 Nisam siguran, ali moguce je da je i do njega problem. Quote Share this post Link to post Share on other sites
coa565 10 Posted February 28, 2015 Kod mene je prvo ptavio otpor i samo 40 % struje je propustao zato nije palio i sve manje struje propustao i od zagrevanja se sprzila ploca Quote Share this post Link to post Share on other sites
coa565 10 Posted March 8, 2015 Sinoc reko malo da ga upalim ali me mrzelo da ga ottrpavam uz snega posto kod mene 80 cm snega napadalo i ottrpam samo vozaceva vrata i upali odma i posle 10 minuta rada se ugasi i izbi dim iz haube, ja da probam da upalim samo vergla. Ottrpam haubu iz snega, otvorim i vidim bije dim kod filtera za vazduh ja ga skinem i vidim bas bije dim i posle 1-2 minuta kad se razdimio ja probam da upalim i odma upali ko da nista nije bilo. Da li je ovo moglo da ostavi neke posledice na motor. Kako sam ja ukapirao nije imao odakle da vuce vazduh i vuko ulje na iberlauf i ugusio se. Quote Share this post Link to post Share on other sites
coa565 10 Posted March 11, 2015 MozeKakve, kako da proverim da li je ostavilo posledice? Quote Share this post Link to post Share on other sites
MS PK 7732 Posted March 12, 2015 Videces kad ga budes vozio. Ako ide ko sto je iso i ne trosi vise ulja onda mu nije nista. Trebalo bi da je sve ok jer je bilo na kratko. Quote Share this post Link to post Share on other sites
coa565 10 Posted March 12, 2015 On ide isto, bar po meni. A za ulje cu videti da li ce trositi ubuduce posto mi od zamene vrlo malo potrosio. Na meracu je pao nivo za oko 5 mm. Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted March 12, 2015 Kako si proverio ulje? Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted March 12, 2015 Ako pali na toliki sneg i toliki minus, nemoj ga prodajes Quote Share this post Link to post Share on other sites
coa565 10 Posted March 12, 2015 Kako si proverio ulje? Ocistio od snega i ispred put cistio jedno 2 sata, spustio na ravnicu i izmerio Quote Share this post Link to post Share on other sites
coa565 10 Posted March 12, 2015 @Buca_Tipo:Pali bre kao mina pogotovo sad kad mi komsa pozajmio nov akumulator posto mu kola u kvaru Quote Share this post Link to post Share on other sites
MS PK 7732 Posted March 12, 2015 Au ti si zatrpan bio. Dobro da si ga naso Quote Share this post Link to post Share on other sites
coa565 10 Posted March 20, 2015 Ako pali na toliki sneg i toliki minus, nemoj ga prodajes Jao bre bem ti globu, prolepsalo se vreme i od pre dva dana samo na gurku oce i trepti ova lampica grejaca trepnem je u relej. Sigurno crko neki od ovih kineza grejaca ili ga urece Buca salim se Quote Share this post Link to post Share on other sites
coa565 10 Posted March 22, 2015 Juce resen problem sa paljenjem, crkla 2 grejaca i jutros super upalio, takodje i opran malo ljubimac  Quote Share this post Link to post Share on other sites
MS PK 7732 Posted March 22, 2015 Jos sneg kod tebe Quote Share this post Link to post Share on other sites
coa565 10 Posted March 22, 2015 Ima jos malo Inace zaboravi da kazem, bas se lako menja onaj prvi grejac, skidao sam ga sat vremena a jos bio zapeko Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted March 22, 2015 Da vidis kod mene kako se menja onaj skroz levo gledano spreda, kao kinez sam ga zavrtao pincetom Quote Share this post Link to post Share on other sites
coa565 10 Posted March 22, 2015 To je ovaj skroz levo, a pumpa skroz pribijena uz njega. Prvo dok sam ga odvio potrosio sam pola wd-a jer nije nikad menjan a posle sam ga sa pincetu vadio pored bos pumpe a ove ostale sve bukvalno za 15 minuta. Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted March 22, 2015 Potrazi u mojoj temi da vidis sta je sex Quote Share this post Link to post Share on other sites
coa565 10 Posted March 22, 2015 Uf bre pa ti moras i usis da skidas, znam kako je ima moj komsija bas tog 1.9d secam se kad menjao grejace koliku muku imao a i vec jednom menjao motor i radio punu generalnu skoro Quote Share this post Link to post Share on other sites
