bakston 0 Posted January 2, 2015 Pozdrav svima.Zanima me sta je sve potrebno i da lije izvodljivo da se zameni ceo prednji kraj na puntu mk2, tacnije farovi, hauba krila.. sa mk2.b Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 2, 2015 I mene je ovo kopkalo, znam da moze, vidjao sam jednog mk2a sa farovima od mk2b i ostalim, ali ne znam sta od onoga sto se ne vidi treba da se prebaci Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 2, 2015 Mozda je covek imao havariju, pa kad vec menja, da podmladi auto Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted January 2, 2015 Ja imam mk2b a lepi mi stariji tip... Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 2, 2015 I meni je lepsi stari tip, i branik i hauba bez maske i far pogotovo Quote Share this post Link to post Share on other sites
bakston 0 Posted January 2, 2015 imam mk2 i mnogo mi svidjaju ovi veci farovi. samo me zanima da li je potrebno menjati i prednji vezni lim i sta sve jos. a trenutno sam i u potrazi za trecim vratima sa modela 2b, sa onim nalim svetlima na samim vratima Quote Share this post Link to post Share on other sites
paun ts 1 Posted January 2, 2015 I meni je lepsi stari tip, i branik i hauba bez maske i far pogotovo Nije sto je moj ali stvarno lepo izgleda Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 2, 2015 Paune, nemoj da se sepuris od tog velikog fara moze neko da strada kad blicas Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted January 2, 2015 Da ne offujemo coveku temu... ali razmisli ti to dobro... da ne bude fankenstajn... ili ti gedora... Quote Share this post Link to post Share on other sites
paun ts 1 Posted January 2, 2015 I ja se slazem da tvoj lepo izgleda i ne budzi ga nista napred. Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 2, 2015 Verovatno mora i vezni lim ...ali ne znam kako se kaci hladnjak posle, da li ima razlike Quote Share this post Link to post Share on other sites
paun ts 1 Posted January 2, 2015 Morace mozda i krila da se menjaju. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted January 2, 2015 Moze da se napakuje jer su karoserije iste. Od mk2B se sve pase na mk2A. Konkretno za prednjicu moraju i krila mislim Quote Share this post Link to post Share on other sites
bakston 0 Posted January 3, 2015 prvi razlog zamene je sto uglavnom vozim nocu, i trebaju mi bolji farovi. imam sluzbenu zastavu 10 sa velikim farovima i ksenonima, i osvetljenost ne moze da se poredi. Drugo, hteo bih da malo podmladim auto bar na izgled, jer u nekoj blizoj buducnosti necu moce da uzmem nesto mladje. Quote Share this post Link to post Share on other sites
Markoni Bg 74 Posted January 3, 2015 Daces dosta para za izgled po meni bacanje para , bolje uzmi neki dobar xenon i resio si problem , ako ga nekada budes prodavao svi ce bezati od njega jer ce misliti da je bio havarisan. Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted January 3, 2015 Tako je xeoni i na starom resavaju problem... vidi na forumu ima primera... Quote Share this post Link to post Share on other sites
Angell 11 Posted January 3, 2015 (edited) Ako covek ima para koje moze da potrosi na izgled auta, tj face lifting, neka odradi to, pogotovo ako ne planira da ga proda u narednih par godina.Ako se to coveku svidja, neka odradi.Samo treba napomenuti da je to skup zahvat.Ako je osvetljenje problem, moze da ispolira farove i ugradi xenone.Pravo resenje. Edited January 3, 2015 by Angell Quote Share this post Link to post Share on other sites
bakston 0 Posted January 3, 2015 ako je to zahvat od nekih 200enaravno polovni delovi vec u istoj boji to je ok ako me bude izaslo preko to mi je vec previse. Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 3, 2015 (edited) Farovi 50+Hauba 70+Krila 60+Branik 30+ Jos unutra ti limovi da se pokupuju i sitnice ... izadje dosta, mozda i nadjes sve u boji, ali opet ko zna u kakvom je stanju pa racunaj i na farbanje ... po meni skup sport, osim ako nije moranje, ne bih radio tako nesto Naravno racunaj da mozes svoje stare delove da prodas, ali racunaj da i to moze da se oduzi ... Edited January 3, 2015 by beli_Punto Quote Share this post Link to post Share on other sites
bakston 0 Posted January 3, 2015 po ovoj racunici si upravu. to je dosta para. mislio sam da je mnogo jeftinije.pozdrav Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 3, 2015 Cene su tu negde, gore dole 50e Quote Share this post Link to post Share on other sites
bakston 0 Posted January 3, 2015 znas li slucajno cenu za treca vrata ob mk2b Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 3, 2015 Ne znam tacno, za ove delove znam, jer sam nekad kupovao za drugara i pricao sam sa komsijom kad je i on nabavljao pa su mi ostale u memoriji Quote Share this post Link to post Share on other sites
paun ts 1 Posted January 3, 2015 Ja bih kupio odmah te farove za 50€ da ima. Gledao sam na internetu od 140-170€ par, tako da si @Beli u pravu da je to skup sport, a i slazem se sa @Markoni-jem da ako ga nekad budes prodavao svi ce misliti da je bio havarisan.Tako da @bakstone proguglaj malo po netu sta koliko kosta stavi na papir pa ako ti se isplati kreni na posao. Quote Share this post Link to post Share on other sites
