Dusankmg 0 Posted December 18, 2014 Majstoru sam se javio zbog potrosnje i on nije nista nasao ali je nasao da mi pumpa bije pritisak gorivo umesto 0.8 kako treba kod mene je 1.5 i reko mi je da promenimo samo membranu da lice to biti dobro ili ceo regulator pritiska? Quote Share this post Link to post Share on other sites
Martini 11 Posted December 18, 2014 Neka samo podesi oprugu u regulatoru. Quote Share this post Link to post Share on other sites
sanja.obradovich 8 Posted November 27, 2017 Danas mi je na dijagnostici računar prijavio da mi ne radi kako treba regulator pritiska za gorivo i da trebam da ga zamenim. Obratim se jednom servisu koji je iz Srbije i oni mi kažu da moj model punto mk.2, 1.9D, 44kw nema taj regulator. O.o Dok mi jedan drugi dovori da ima. Ima li ovde neko stručan da mi kaže da li ima ili nema? Quote Share this post Link to post Share on other sites
Memphis 15 Posted November 27, 2017 (edited) pumpu Edited November 27, 2017 by Memphis Quote Share this post Link to post Share on other sites
Memphis 15 Posted November 27, 2017 Nema ima bosch pumpu Quote Share this post Link to post Share on other sites
sanja.obradovich 8 Posted November 27, 2017 1 minute ago, Memphis said: Nema ima bosch pumpu Ima Lukas pumpu. A pored lukas pumpe meni je očitalo da mi regulator pritiska nije u redu. Quote Share this post Link to post Share on other sites
silenci 2333 Posted November 27, 2017 da lucas pumpa,cuvena,a ovaj motor nema taj regulator,vec ima senzor pritiska goriva na samoj pumpi,a moze da se zameni Quote Share this post Link to post Share on other sites
