Baso_1990 0 Posted December 15, 2016 nema pomaganja moras sist i naucit haha Quote Share this post Link to post Share on other sites
Drazen.OS 31 Posted December 15, 2016 Ako je tako, onda važi ona čovijek uči dok je živ.. a umre glup. Quote Share this post Link to post Share on other sites
Baso_1990 0 Posted December 15, 2016 bolje ispast iz aviona nego ispast glup Quote Share this post Link to post Share on other sites
Gologuzan 3 Posted July 2, 2017 (edited) Elem, Pazario sam grande punta, i sada mi se jako svidjaju stop svetla sa grande evo, E sada moje pitanje, da li je moguce zamenuti i staviti evo stop svetla? Normalno pored toga planiram jos malo sminke, pedikir sam delimicno odradio, stavio 17" dotz felne i nema problema. Mada sada se razmisljam da probam i 18". A onda malo i ispod haube malo da cacnem, 120hp nije lose, ali moze jos malo da se doradi, i onda je to jedan lep porodican auto. Razlog za dodatni hp, bolje da ih imam u rezervi, zlu ne trebalo, nego da mi zafale a da nemam. Edited July 2, 2017 by Ivan Prebaceno Quote Share this post Link to post Share on other sites
MS PK 7718 Posted July 2, 2017 Moze stop svetla Quote Share this post Link to post Share on other sites
Gologuzan 3 Posted July 2, 2017 Koliko sam ceprkao evo ima 3 verzije stop svetala. Da li je bitno koju nakacim, ima li nekih ogranicenja, ili nadjem sta mi se svidja i samo plug and play? Quote Share this post Link to post Share on other sites
Bingodalton 726 Posted July 2, 2017 Nisu isti kontakti na evo i obicnom. Tj dzekovi. Tako daaaa, nije svejedno. Quote Share this post Link to post Share on other sites
radomir.g 334 Posted July 2, 2017 U sustini stopovi imaju istu fukciju, tako da nije neki bauk premostiti zice. Zmigavac, pozicija, stop i 4 zica masa... nista strasno. Sto se felni tice SS model ima 18x7j sa 215/40 profilom. Ide bez problema samo obavezno neke opruge bar -30mm. Quote Share this post Link to post Share on other sites
DiscoVolante 294 Posted July 2, 2017 30mm je premalo ako će ići na 18" kotače. Sve više od toga povlači i druge amortizere, a na 16+" kotačima je Grande Punto u svskom slučaju dosta tvrd auto. Quote Share this post Link to post Share on other sites
Gologuzan 3 Posted July 2, 2017 17" sa 215/45 su trenutnona njemu. jeste malo grublji ali nista nisam menjao. sve je fabricki od oprugai amortizera. uh bre Bingodalton sada me beci u bedak, moracu da vidim sta moze da se modifikujehttp://www.fiatforum.com/grande-punto-guides/302998-grande-punto-rear-lights-conversion-evo-lights.html evo iskopao njega bili... znaci nisam prvi "expert" kome je ovo palo na pamet. Quote Share this post Link to post Share on other sites
Ivan 17434 Posted July 2, 2017 @Gologuzan Nisi , a vec imamo identicno temu o konverziji GP->Evo stopaljke na forumu. Tako da je tema spojena sa postojecom. Takodje, praksa na forumu je da ne pravimo svastare od tema - imamo odgovarajuce o dimenzijama tockova, cipovanju, itd. - slobodno se raspisi u njima za preostala pitanja . Quote Share this post Link to post Share on other sites
Milos123 0 Posted October 5, 2018 Pozdrav ljudi, kupio sam Stopove od Grande Punto Evo. Ne mogu nigde da nadjem džekove da bi ih povezao. Citao sam temu i one džekove od napajanja ne mogu nigde da nadjem. Treba mi dzek sa 5 pinova. Ima li neko ideju kako da sredim?? Quote Share this post Link to post Share on other sites
Nikola 1.6 257 Posted October 5, 2018 https://www.fiatforum.com/grande-punto-guides/302998-grande-punto-rear-lights-conversion-evo-lights.html Samo saltaj prvi post na desno i bice ti sve jasno 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Zvezdo 923 Posted October 5, 2018 On 10/5/2018 at 2:25 PM, Milos123 said: Nemogu nigde da nadjem džekove da bi ih povezao. Citao sam temu i one džekove od napajanja ne mogu nigde da nadjem. Treba mi dzek sa 5 pinova. Ima li neko ideju kako da sredim?? Odeš u bilo koji PC servis i traži pokvareno napajanje jer ih imaju toliko da ne znaju šta će sa njima! 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Milos123 0 Posted October 5, 2018 Hvala brate ziv bio !! Sutra cu da idem. Quote Share this post Link to post Share on other sites
Bule 69 Posted March 28, 2022 Nabavio sam štopaljke od eva ali malo slabije razumem sta se ovde radi, naročito gde ide otpornik, ako ima neko pojašnjenje ili još bolje slika Hvala Quote Share this post Link to post Share on other sites
