MS PK 7718 Posted January 15, 2015 Ovo zvuci original.kao aksijalni luft bregaste!Mislim na snimak kolege Zorza. Ovaj snimak ispod nema takvog zvuka ali se opet cuje da nesto "melje".Zorz, ja da sam na tvom mestu, zalio bih se. Quote Share this post Link to post Share on other sites
Zhorz 102 Posted January 15, 2015 23000km, Ja ako se budem zalio samo zamenu prihvatam, kakve popravke, otvaranja motora i slicno!!! Quote Share this post Link to post Share on other sites
darkosub 0 Posted January 15, 2015 (edited) Mene je FAS poslao u servis na dodatnu dijagnostiku i tom prilikom su otvorili motor bez da su me ista pitali.Kasnije su trazili da potpisem da sam saglasan sa tim -sto ja naravno nisam ucinio. Edited January 15, 2015 by darkosub Quote Share this post Link to post Share on other sites
MS PK 7718 Posted January 15, 2015 Kakvu zamenu? Quote Share this post Link to post Share on other sites
MilanStilo 2 Posted January 15, 2015 Verovatno zamenu auta Quote Share this post Link to post Share on other sites
Dovla83 1 Posted January 15, 2015 Evo kako radi moj puntic, znaci u pitanju je punto clasic 2010 1.2 8v Quote Share this post Link to post Share on other sites
Zhorz 102 Posted January 15, 2015 al se ne cuje onaj klaparajuci zvuk kao kod mene, youtube hoce da malo zvuk uoblici ali se ne cuje kod tebe. Quote Share this post Link to post Share on other sites
Dovla83 1 Posted January 15, 2015 Pa mislim da se necuje, ali definitivno si u pravu da youtube malo uoblici zvuk, uzivo mislim da je tisi i da ima lepsi rad Quote Share this post Link to post Share on other sites
darkosub 0 Posted January 15, 2015 (edited) evo kako radi jos jedan 500l 1.4 16v - koristi se kao probno vozilo kod ovlascenog dilera Edited January 15, 2015 by darkosub Quote Share this post Link to post Share on other sites
Zhorz 102 Posted January 15, 2015 I tu se cuje Quote Share this post Link to post Share on other sites
darkosub 0 Posted January 15, 2015 (edited) Sreo sam jos jedan 500l koji ima isti zvuk kao nas. Vlasnik auta kaze da mu je tako od pocetka. Auto sad ima 29000km.Verovatno ima jos dosta 500l sa takim zvukom motora. Edited January 15, 2015 by darkosub Quote Share this post Link to post Share on other sites
Jaric T Zivadin 0 Posted January 15, 2015 Ili je mozda ispravnije reci da su svi sa takvim zvukom Quote Share this post Link to post Share on other sites
drzarkod 3 Posted January 16, 2015 Dizel radi lepše.... Quote Share this post Link to post Share on other sites
darkosub 0 Posted January 16, 2015 (edited) bilo bi dobro kad bi jos neko okacio snimak rada motora - radi poredjenja Edited January 16, 2015 by darkosub Quote Share this post Link to post Share on other sites
Zhorz 102 Posted January 16, 2015 (edited) bilo bi dobro kad bi jos neko okacio snimak rada motora - radi poredjenjaimas 4 zvuka motora 500L, sad jedino da zamolimo onoga kod koga se to ne cuje da okaci snimak? sad cu da pustim sms onima koje znam i da imaju 500L benzin pa ako mogu postavice Edited January 16, 2015 by Zhorz Quote Share this post Link to post Share on other sites
tratra 0 Posted January 16, 2015 Perhaps we should organize some 500L meeting to compare all of our sounds, noises, clangs, bangs, squeaks... so we could find out which of them are normal sounds (if there is any) and which are not. Quote Share this post Link to post Share on other sites
Jaric T Zivadin 0 Posted January 16, 2015 Mislis da bi to trebalo uraditi na globalnom nivou, negde u inostranstvu? Quote Share this post Link to post Share on other sites
MS PK 7718 Posted January 16, 2015 Najbolje u Torinu Quote Share this post Link to post Share on other sites
debelizmaj 414 Posted January 16, 2015 Koliko se secam kod mene se ne cuje. Idem da snimim pa da okacim... Auto je na uzbrdici, hladan Quote Share this post Link to post Share on other sites
debelizmaj 414 Posted January 16, 2015 Snimio sam, telefon nema bas najbolji mikrofon. 4Uglavnom, zvuk lici na onaj iz puntica. Na 28 sekundi motor sam smanjuje obrtaje, cuje se neko kratko vreme metalni zvuk. U glavnom, motor radi kao i svaki benzinac, bez dizel prizvuka. Ako bude bilo potrebno, snimicu zvuk motora sa malo vece distance da ne bi bilo ove rezonance, sada je bolno za slusanje Evo videa Da zaokruzim, u realnosti se motor cuje tise i kulturnije. Bas kao malolitarski benzinac. Quote Share this post Link to post Share on other sites
darkosub 0 Posted January 16, 2015 Svaka cast na trudu.Mozda je malo los snimak... u svakom slucaju nema ono klaparanje. Quote Share this post Link to post Share on other sites
debelizmaj 414 Posted January 16, 2015 Zao mi je sto je tako ispalo :-( ukoliko bude bilo potrebno, probacu da snimim bolji... Quote Share this post Link to post Share on other sites
totti 13151 Posted January 16, 2015 U jednom trenutku pomislih da je cirkular u pitanju Quote Share this post Link to post Share on other sites
Jaric T Zivadin 0 Posted January 16, 2015 Pomislih na pocetku da ti pao helikopter u avliju Quote Share this post Link to post Share on other sites
debelizmaj 414 Posted January 16, 2015 :D:DTo otvaram haubu. Bas je lose snimio zvuk... Quote Share this post Link to post Share on other sites
