Naki202 0 Posted March 6, 2018 nikakvu gresku ne prijavljuje,upali se normalno i mirno odradi cak i 5-6 sekunde i posle toga se ugasi.... Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted March 6, 2018 4 hours ago, Naki202 said: a kvar je poceo kad je bilo hladno vreme..... Jesi li imao i malo goriva tada? Kada pogledaš sada, nakon spajanja tema, sve ranije napisano u temi na kojoj smo, videćeš da linija goriva može da bude problem, od pumpe do dizni... Quote Share this post Link to post Share on other sites
miloraddjurnic 0 Posted December 14, 2018 (edited) pozdrav imam problem fiat stilo 1.9 jtd 2002 85kwn,motor mi se ugarsi u voznji pise engen problem i nizak pritisak ulja,zaustavim se oduzmem kontakt pise isto engen problem upalim makne se greska i sve normalno,sta to moze biti majstor je misio senzor pritiska ulja ali nije hvala pozdrav.... Edited December 14, 2018 by Ivan Spojeno Quote Share this post Link to post Share on other sites
Ivan 17670 Posted December 14, 2018 @miloraddjurnic Nepotrebno otvoren topic je spojen sa postojecim, sa istom tematikom. Mozes da procitas iskustva ljudi na prethodne 3 strane. Slicnom problematikom se bavi i ova tema: Quote Share this post Link to post Share on other sites
NovakStiloJTDPower 4 Posted November 6, 2019 (edited) Momci, hitno mi je potrebna pomoc, fiat stilo 1.9 jtd, jutros normalno sve radio, odvezao klinca u vrtic, zenu na posao i kada sam se vratio, ugasim auto, odem do frizera na pola sata, auto upalim i on se ugasi, svaki put, znaci auto pali ali odmah se ugasi, pomoć bilo koja sto pre, hvala unapred. Edited November 6, 2019 by Ivan Spojeno Quote Share this post Link to post Share on other sites
Mijailović P. 3449 Posted November 6, 2019 Da nije pumpa goriva. Zuji li kad se okrene ključ na kontakt? Quote Share this post Link to post Share on other sites
PremieRacing 5317 Posted November 6, 2019 Majstor druže, ko će šta preko tastature da ti pomogne? 10 hours ago, Mijailović P. said: Da nije pumpa goriva. Zuji li kad se okrene ključ na kontakt? Velika verovatnoća, ali šta i da jeste? Da zna da zameni ili premosti pumpu, znao bi i sam da predpostavi da je ona u faulu... A može da bude i 16 drugih razloga... Quote Share this post Link to post Share on other sites
NovakStiloJTDPower 4 Posted November 6, 2019 (edited) Ma znam ja da treba da idem kod majstora, mozda je neko imao slican problem, ne znam da li da slepam kod mehanicara, auto elektricara, nije pumpa za gorivo, toliko bar znam, kaze majstor da moze da bude milion stvari, dizna, regulator pritiska, mozda je i do elektronike jer je pala kisa. Edited November 6, 2019 by Ivan Ne citiraj prethodni post ;) Quote Share this post Link to post Share on other sites
Mijailović P. 3449 Posted November 6, 2019 Jbg, valjda nije majstor daleko od frizera. 2 Ivan and neshaoct reacted to this Quote Share this post Link to post Share on other sites
NovakStiloJTDPower 4 Posted November 6, 2019 (edited) Nasmeja me u ovom teskom trenutku, hvala u svakom slucaju. Edited November 6, 2019 by Ivan Ne citiraj prethodni post ;) 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Ivan 17670 Posted November 6, 2019 (edited) Posto je JTD u pitanju, meni recimo prvo na pamet pada regulator pritiska ili senzor Raila, npr. Ima li oscilacije u leru, izbacuje li neke greske na tabli, sta je ocitano dijagnostikom...? Malo su drugaciji najcesci simptomi za RPM senzor(najcesce nece da upali kada je vruc), ali moguce i da je do njega. Par puta su ljudi imali probleme i sa nepovratnim ventilom na kucistu filtera goriva. Sto postovane kolege vec rekose - moze da bude svasta, bez dijagnostike ovde samo mozemo da caskamo. Edited November 6, 2019 by Ivan 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
NovakStiloJTDPower 4 Posted November 6, 2019 (edited) Hvala! Edited November 6, 2019 by Ivan Ne citiraj prethodni post ;) Quote Share this post Link to post Share on other sites
Ivan 17670 Posted November 6, 2019 @NovakStiloJTDPower Evo, spojio sam temu sa postojecom, pa mozes da procitas i dosadasnja iskustva i cene resavanja problema. Imas i ovu slicnu temu: https://www.fiat-lancia.org.rs/forum/index.php?/topic/65385-fiat-stilo-19-jtd-gasi-se-u-vožnji-pri-preticanju/ Dopisi i svoje iskustvo kada resis problem, znacice ljudima . Quote Share this post Link to post Share on other sites
NovakStiloJTDPower 4 Posted November 6, 2019 (edited) Hvala puno! Edited November 6, 2019 by Ivan Ne citiraj prethodni post ;) Quote Share this post Link to post Share on other sites
NovakStiloJTDPower 4 Posted November 6, 2019 (edited) Cisto da javim da je auto upalio, teram kod majstora, verovatno je senz radilice. Uglavnom javljam kada zavrsim. Edited November 6, 2019 by Ivan Ne citiraj prethodni post ;) 1 1 Ivan and neshaoct reacted to this Quote Share this post Link to post Share on other sites
NovakStiloJTDPower 4 Posted November 6, 2019 Ljudi ja dosao od majstora, auto pali, radi, dijagnostika nista nije izbacila, majstor mi je rekao da je ili regulator pritiska, ili dizna, ali ne moze da zna dok auto ne stane skroz, pa ja sada vas pitam jel to normalno? Quote Share this post Link to post Share on other sites
Mijailović P. 3449 Posted November 6, 2019 A ti se poplašio. sa TT Quote Share this post Link to post Share on other sites
NovakStiloJTDPower 4 Posted November 6, 2019 (edited) Pa iskreno i jesam, jer mi je svasta palo na pamet, uglavnom, cini mi se da je regulator pritiska, jer variraju obrtaji u leru, i to cu uraditi cisto da ne berem brigu. Edited November 7, 2019 by Ivan Ne citiraj prethodni post ;) 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted November 6, 2019 Ako variraju verovatno je do njegaПослато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
Ivan 17670 Posted November 7, 2019 On 06/11/2019 at 10:17 AM, Ivan said: Posto je JTD u pitanju, meni recimo prvo na pamet pada regulator pritiska Na JTD regulator vrlo cesto zna da bude uzrok opisanih problema (posto u prvom postu nisi napisao, zato te i pitah ima li oscilacije na leru). I nemas sta da se brines, em je motor sazvakan do u detalje, em su delovi bagatela (polovni pogotovo). Quote Share this post Link to post Share on other sites
