Dragi0123 2 Posted April 29, 2022 (edited) Pozdrav, imam problem tokom paljenja auta ujutru, upali check in lampicu, prvi put zavergla, drugi put upali motor, ali radi 2, 3 sekunde i ugasi sam, obicno iz treceg ili cetvrtog puta upali, iz nekog razloga ponekad pali i ventilator za hladjenje. Na dijagnostici prijavljuje gresku (p0105) , mehanicar kaze "bacač temperature" . Deo zamenjen, ali opet pokazuje istu gresku na dijagnostici i isti problem. Slabije pali, i vise mi trosi nego sto bi trebalo, svaka pomoc dobrodosla, ako je neko imao slican problem, neka odgovori kako je resio. Edited April 29, 2022 by neshaoct spojeno Quote Share this post Link to post Share on other sites
jevta 251 Posted April 29, 2022 (edited) @Dragi0123 Probaj otkačiti MAP senzor za probu moguće da on ne valja Edited April 29, 2022 by neshaoct dodao tag 1 1 neshaoct and Dragi0123 reacted to this Quote Share this post Link to post Share on other sites
Dragi0123 2 Posted April 29, 2022 (edited) Probao, prskao konakt sprej, mislim da je majstor zamenio map senzor ali opet pokazuje isto na kompijuteru (check engine) u voznji radi normalno ne dize temperaturu, trosi malo vise, samo ujutru ima problem na prvo to paljenje kada se vozi posle radi normalno cak i iskljuci check engine lampicu Edited April 29, 2022 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
jevta 251 Posted April 29, 2022 (edited) @Dragi0123 Probaj da upališ sa isključenim MAP Edited April 29, 2022 by neshaoct dodao tag Quote Share this post Link to post Share on other sites
Dragi0123 2 Posted April 29, 2022 8 minutes ago, jevta said: @Dragi0123 Probaj da upališ sa isključenim MAP Hvala na odgovoru,ajde sutra cu reci majstoru da proba, on tipuje da je ecu ima neku gresku, ali ja mislim da bi mnogo vise brljao, na dijagnostici samo pokazuje p0105 gresku Quote Share this post Link to post Share on other sites
Dragi0123 2 Posted June 12, 2022 On 4/29/2022 at 9:15 PM, Dragi0123 said: Hvala na odgovoru,ajde sutra cu reci majstoru da proba, on tipuje da je ecu ima neku gresku, ali ja mislim da bi mnogo vise brljao, na dijagnostici samo pokazuje p0105 gresku Probao sam, kada sam raskacio map senzor, pali iz prve bez problema Quote Share this post Link to post Share on other sites
dexy090 0 Posted February 26 Pozz već par dana ujutru kad krenem na posao, prvo paljenje, treba mu par sekundi duže da upali, evo danas je trebalo malo duze na prvi ključ ibugasio se, znači samo to prvo paljenje, posle u toku dana pali normalno?na sta bi mogao da sumnjam Quote Share this post Link to post Share on other sites
ostoja 509 Posted February 26 Probaj da mu das kontakt 15ak sekundi (nemoj da verglas), iskljuci kontakt pa opet daj kontakt 15ak sekundi i zaverglaj. Jel situacija ista drugacija? Quote Share this post Link to post Share on other sites
nemanja84bg 1283 Posted February 26 (edited) Takodje probaj kontakt onaj kad krene pumpa da zuji, kad odradi svoje stisni papucicu gasa do kraja, nemoras brzo nego onako da pohvata parametre lagano .... nastavi na sledecu pozicijui kljuca da zavregla i onda pali bez papucice ako nece prvi kr onda stisni pedalu i vidi hoce li .... to odradi u tom prvom cugu Edited February 26 by nemanja84bg Quote Share this post Link to post Share on other sites
