silenci 2337 Posted September 20, 2019 sutra ide na dijagnostiku verovatno,a i na pranje,sav je prljav,vozio sam reli kod Srebrnog jezera,kad smo isli u njive da kupimo paprike,to je bilo kilometar prasine iza mene Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted September 20, 2019 Paprike se kupuju na jugu... Sent from my Redmi Note 3 using Tapatalk Quote Share this post Link to post Share on other sites
silenci 2337 Posted September 21, 2019 haa jeste,al tamo kod Srebrnog jezera covek zakupio skoro 300 hektara,posadio paprike,jagode,višnje,pa cak i maline i sve na veliko radi i prodaje Quote Share this post Link to post Share on other sites
silenci 2337 Posted November 17, 2019 (edited) musava u firungu Nakotilo se musavih po gradu i tu su i two towers Edited November 17, 2019 by silenci 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
silenci 2337 Posted December 7, 2019 u petak ujutru da podjem na posao,kad ne lipši magarce do zelene trave,otisao aku ,zavrsio karijeru,nisam mogao nikako da upalim. Danas kupio u BeoCar Exide,taj neki pojacan od 53Ah,al ima udarnu snagu kao da ima 60Ah ,platio 7400,a prodao stari Topla za 720 dinara.Skoro 6 godina me sluzio Topla TOP akumulator 1 Axic reacted to this Quote Share this post Link to post Share on other sites
srdjos 1599 Posted December 8, 2019 TOPLA su slovenacki akumulatori, svi ih hvale 1 silenci reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted December 9, 2019 Topla preporuka za Topla akumulator 3 2 Ivan, Axic, silenci and 2 others reacted to this Quote Share this post Link to post Share on other sites
silenci 2337 Posted December 9, 2019 Topla su vrhunski akumulatori,al ja u blizini nigde nisam nasao gde prodaju Topla akumulatore,a ja nisam mogao nikako da upalim auto,pa sam zvao drugara da me odveze do beocara da kupum aku,a nije imao puno vremena,a i meni trebao auto u subotu bas. Al i ovaj Exide je odlican 40 meseci garancije,a imao sam u puntu exide,skoro 5 godina izdrzao. Quote Share this post Link to post Share on other sites
silenci 2337 Posted February 18, 2020 danas slikao kad sam se vracao sa posla,a neki dan sam kupio ulje castrol i filtere ulja i goriva,pa sad jedan dan da ide na mali servis i da se pregleda ceo auto Quote Share this post Link to post Share on other sites
horvat 6456 Posted February 19, 2020 On 12/9/2019 at 7:06 PM, silenci said: Topla su vrhunski akumulatori,al ja u blizini nigde nisam nasao gde prodaju Topla akumulatore. Subotica, Warner Quote Share this post Link to post Share on other sites
silenci 2337 Posted March 1, 2020 konacno zamenjenu ulje,kao i filteri ulja i goriva i pregledom auta,utvrdjeno da se španer pk kaisa skroz raspao,pa je to zamenjeno,ostalo sve kako treba.E danas kad sam pruzeo auto i kad motor radi,svetli laampica da ima vode u filteru za gorivo,a to mi se nikad nije javljalo pre. Quote Share this post Link to post Share on other sites
silenci 2337 Posted March 11, 2020 juce registrovao musavu po 7mi put,sve zajedno 17900,400 dinara vise no prosle godine,al zadovoljan sam a danas mi stigla čestitka od komunalne milicije Quote Share this post Link to post Share on other sites
silenci 2337 Posted April 2, 2020 danas malo protegao noge i tockove,da barem malo izadjemo u prirodu sutra il za vikend kad bude total zabrana kretanja,menjamo gume,stavljamo letnje. a ova lampica da ima kao vode u filteru goriva još sija,ne znam sta da radim,bode mi oči vise Quote Share this post Link to post Share on other sites
Ivan 17639 Posted April 2, 2020 (edited) Je li kod tebe filter kao npr. na vecem 1.9? Ako jeste, je li ti vezan dzek za senzor indikacije vode u nafti, sa donje strane filtera (da tu nesto ne brljavi). Ako to deluje OK, mozes da raskacis dzek i probas da ispustis malo goriva iz separatora filtera? Mozda stvarno indikuje prisustvo vode? Edited April 2, 2020 by Ivan Quote Share this post Link to post Share on other sites
silenci 2337 Posted April 2, 2020 e pa da sa donje leve strane je dzek,al ja ga nisam mogao skinuti nikako,a i ispustao sam naftu iz filtera,ima beli plasticni šraf pa sam šravcigerom odvrcao,iscurelo je malo nafte.Jedino jos jednom da pokusam,al me brine taj dzek sto ga necu moc skinuti ,a i ne znam kako se skida. Quote Share this post Link to post Share on other sites
Ivan 17639 Posted April 2, 2020 Aha, kod tebe pretpostavljam onda nije metalni filter goriva? Nego ono plasticno kuciste, sa uloskom? Quote Share this post Link to post Share on other sites
silenci 2337 Posted April 2, 2020 da da,plasticno kuciste i unutra ulozak Quote Share this post Link to post Share on other sites
MS PK 7731 Posted April 2, 2020 Otkaci i probaj bez dzekaПослато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
silenci 2337 Posted April 2, 2020 ima na vrhu dzek veliki,njega bez problema skinem,al sa leve strane ima taj dtek ,valjda je to taj jebeni senzor i njega nisam mogao skinuti,tj taj dzek Quote Share this post Link to post Share on other sites
Axic 20015 Posted April 2, 2020 Uložak filtera goriva ti je 500 dinara, sam ga zameni, možda taj koji si stavio nije dobar. Quote Share this post Link to post Share on other sites
silenci 2337 Posted April 3, 2020 pa nemam pojma,mogu to da odradim,znaci da ima veze i do samog uloška filtera,jee da ga nije navlazila zenska sto ga je pravila Quote Share this post Link to post Share on other sites
Axic 20015 Posted April 3, 2020 Muller, UFI, Knecht ako nađeš uzmi od tih proizvođača, (Knecht pogotovo) samo da znaš da ima 2 vrste filtera za 1.3 mjet pa da se ne zajebeš i uzmeš onaj što ti ne treba. Quote Share this post Link to post Share on other sites
silenci 2337 Posted April 3, 2020 aha dobro,hvala kolega,pa cu to sigurno odraditi,malo kad prodje ova ludnica,iovako neradim i nevozim puno musavu da da ima dve vrste tih filtera,znam Quote Share this post Link to post Share on other sites
silenci 2337 Posted June 11, 2020 e pa konacno posle 11 dana u servisu danas uzeo musu i konacno,trebalo bi ,rešem problem,što nije ima snagu i ulazio u safe mod svaki put kad dodam malo jaci gas.EGR ventil bio skroz zapusen,skinut je detaljno očišćen i opran.Sad nema ni jednu grešku pa ce da vidim kako ce se ponasati,cena čišćenja je 5000 dinara Quote Share this post Link to post Share on other sites
Axic 20015 Posted June 11, 2020 Slabo ti to izduvas preko 3.000 obrtaja čim se zapusio. Quote Share this post Link to post Share on other sites
