Djuk85 2981 Posted August 4, 2018 Ja sam tako skidao tablu na jednom mom autu... Oni ce meni kao 70 evra za to... Skinuo je za 3 sata...sklapao 4 dana Zivce nisam uracunao hehe A tebi svaka čast na trudu 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Sedla 2542 Posted August 4, 2018 Bogami, ja planiram da ovo sastavim sutra... 'Ebe me samo sto imam jos nekih obaveza, ne znam da li cu moci ceo dan da se posvetim samo ovome. Ali dobar deo posla ce biti odradjen, sigurno. @Djuk85, kakvih 70€, pa neko da mi da i 150,pa da razmislim da radim ovo ponovo! 1 Djuk85 reacted to this Quote Share this post Link to post Share on other sites
Martin 796 Posted August 5, 2018 Gledao sam slike na telefonu pa nisam baš mogao lepo da uočim šta je u pitanju (ne videh da je ustvari izolacija pomalo načeta). Elem, super kad nema korozije (a viđao sam i Libre sa trulim sajtnama i ostalim glupostima). Izvini, fobija iz mladosti. A za tablu - samo polako, sklopićeš ti to....već nekako. Quote Share this post Link to post Share on other sites
totti 13151 Posted August 5, 2018 On 8/4/2018 at 9:27 PM, Sedla said: Ajde, ajde, ne kukaj... 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Sedla 2542 Posted August 5, 2018 Danas nisam stigao mnogo stvari da odradim. Ubacio novi tepih sa kvalitetnim izolacijama, i nesto plasticnih delova... Imao jos sto drugih obaveza, i prolete dan. Ali ne mogu da zurim, ovakav posao mora natenane, ako mislim da ga odradim kako treba... 6 Martin, Djuk85, Axic and 3 others reacted to this Quote Share this post Link to post Share on other sites
Sedla 2542 Posted August 6, 2018 4 Ivan BG, knezevic76, neshaoct and 1 other reacted to this Quote Share this post Link to post Share on other sites
Axic 19729 Posted August 6, 2018 Svi čekaju vraćanje table na mesto i kako vidim uspešno si to uradio. 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
MS PK 7718 Posted August 7, 2018 Bravo Sedlicu 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
knezevic76 6885 Posted August 7, 2018 Bravo za entuzijazam 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Djuk85 2981 Posted August 7, 2018 Celicni zivci 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Sedla 2542 Posted August 7, 2018 Zavrsio sam Ljubimicu danas. Sve sklopio i sastavio. Nemam slika, zavrsio po mraku, ali sam napravio snimak prvog paljenja, koji ne znam sada kako da uploadujem ovde. Naravno, ono cega sam se i bojao, ostala je da sija na tabli lampica, prijavljuje gresku za Air-bag. Po prvi put od kako vozim ovaj auto. Pretpostavljam da je problem u dzeku ispod sedista, sutra idem na dijagnostiku pa cu saznati sta je. Nece ona meni bogami ostati da sija!!! @Axic, @MS PK, @knezevic76, @Djuk85hvala, drugari! Sutra cu detaljno slikati kako je sve ispalo... Quote Share this post Link to post Share on other sites
Martin 796 Posted August 7, 2018 Bitno da nigde nema korozije. Svaka čast na trudu. 1 Djuk85 reacted to this Quote Share this post Link to post Share on other sites
Sedla 2542 Posted August 7, 2018 Hvala, Martine. Za divno cudo, nigde ni trunke. Jedan dobar drugar, koji inace i rastura Lybre, i koji mi je i obezbedio delove za celu ovu igranku, mi je rekao da je moja Lybra fenomen kada je korozija u pitanju. Nigde ni tackice nema. Cak iza prednjih tockova, gde su zavrsetci krila, vremenom se boja oljustila od kamencica i svega ostalog sa puta, a stoji beli lim ispod boje, ne pokazuje nikakve promene... Desno krilo sam zakacio, ogrebao jos pre nekoliko godina, spala boja i zagrebano onako lepo, tu se uhvatilo malo one crvenkaste povrsinske rdje, i to je to. Niti se menja, niti se siri. 1 Martin reacted to this Quote Share this post Link to post Share on other sites
danijel55 694 Posted August 7, 2018 Odmakni oba sedista napred do kraja i vrati nazad.To ponovi 3 puta i nema greske Quote Share this post Link to post Share on other sites
Sedla 2542 Posted August 7, 2018 Ipak ne bih tako da eksperimentisem. Odradicu ja to kako valja. ;-) Ili, sto bi rekli "kako je Bog rekao"! Quote Share this post Link to post Share on other sites
knezevic76 6885 Posted August 7, 2018 Ma korozija je zlo, sve može da se popravi sem tog zla. Tako da imaš sreće, sad je kao nova. Quote Share this post Link to post Share on other sites
bane000 108 Posted August 8, 2018 Svaka čast Mislim da nije problem u airbag-u ispod sedišta, nego u airbag-u na volanu.Skinuo si volan i airbag, a nisi raskacio kleme i zbog toga je prijavilo gresku, pretpostavljam.Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Sedla 2542 Posted August 8, 2018 @bane000 prvo sto sam uradio pre nego sto sam prvi sraf odvio, to je da sam raskacio kleme sa akumulatora. I nisam ih vratio dok nisam sve sastavio, i dvaput proverio. Znam za taj jadac, ali ipak nije to u pitanju. A sa druge strane, kada sam menjao volan, raskacinjao sam jastuk sa volana, a nisam skidao kleme sa akumulatora. Bitno je samo da se ne da kontakt, da sistem ne primeti da nesto fali. 1 bane000 reacted to this Quote Share this post Link to post Share on other sites
Sedla 2542 Posted August 8, 2018 Bio veceras na dijagnostici, prijavljuje problem u vozacevom pojasu. Nisam se setio da slikam tacno kako pise, ali nesto "... Bla-bla predzatezac vozaca bla-bla preveliki napon" ili tako nesto... Dosao sam kuci, skinuo klemu sa akumulatora, zamenio pojas, vratio moj stari, vratio klemu, kontakt... I dalje stoji greska. Morace da radi Examiner, kako stoje stvari. I to cu ovih dana, ako ne vec sutra, da odem negde i da sredim. Nece meni sijati ni jedna greska na tabli, aaa jok!!! 1 bane000 reacted to this Quote Share this post Link to post Share on other sites
danijel55 694 Posted August 8, 2018 I dalje mislim da su kontakti ispod sedista. Quote Share this post Link to post Share on other sites
Sedla 2542 Posted August 9, 2018 Brate, dijagnostika ne prijavljuje problem u sedistu vozaca, nego u pojasu. A ta dva dela nemaju nikakve veze jedan sa drugim, tako da nikako ne moze da bude dzek ispod sedista. Quote Share this post Link to post Share on other sites
darkman14 5792 Posted August 9, 2018 I ja imam istu gresku na Marei. Problem je u zatezacu pojasa. E sad, mozda treba vremena da bord skonta sve, svakako prvo probaj da ocistis kontakte, obrises gresku... Quote Share this post Link to post Share on other sites
danijel55 694 Posted August 9, 2018 Rešićes ti to brzo,a svakako zna da ide na zivce ta greska.ne znam kakvo je stanje kod tebe u Ar,al u Cacku pored auto garanta,ima jedan elektricar koji moze da ocita libru na dijagnostiku.P.S bio sam juce do Ar sa librom,al do duse vukao prikolicu pa reko da se ne zavlacim po gradu. Quote Share this post Link to post Share on other sites
Sedla 2542 Posted August 9, 2018 @andreja.micovic probao da obrisem gresku, doduse pre vracanja mog starog pojasa, i nije htela da se izbrise. Vrati se bukvalno istog trenutka. Nema veze, otici cu na Examiner, on je svakako precizniji i detaljniji od obicne dijagnostike, pa cu videti sta je i kako. Uglavnom, resicu to. @danijel55 trebao si da se javis, ne bi se zavlacio po gradu sigurno. Ja sam tu, maltene na tranzitu... Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted August 13, 2018 Eto, sad kome god treba nešto oko skidanja table na Lybri... - Sedla ima znanje i praksu. 1 1 Sedla and Siki97 reacted to this Quote Share this post Link to post Share on other sites
