neshaoct 9592 Posted May 25, 2018 Sedla 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted May 25, 2018 @neshaoct 1 Axic reacted to this Quote Share this post Link to post Share on other sites
cika_kole 825 Posted May 30, 2018 On 1/7/2018 at 1:13 AM, Sedla said: MF volan cu morati da vratim, na zalost... Dobio sam volan sa starijeg modela Lybre, kojoj fabricki ne svetle komande na volanu. Kod mene treba da ide volan na kojem svetle komande, i ne poklapaju se dzekovi... Evo kakav je dzek na mom volanu: poslao sam ti pp. mislim da se dzek sa onog mog volana poklapa...i sjajni su dugmici... Quote Share this post Link to post Share on other sites
Sedla 2576 Posted June 24, 2018 Mali update: stigla nova (polovna) obuca za Ljubimicu... Felne sa Embleme, jaaako retke za naci. Nisu u nekom sjajnom stanju, treba da se srede i ofarbaju, boja im je skroz izbledela o oljustila se. Ali su generalno dobre felne, nisu skoro nigde udarene, izubijane itd... 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted June 24, 2018 Bravo 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted June 24, 2018 Hvala, Mico, hvala... Quote Share this post Link to post Share on other sites
Sedla 2576 Posted June 24, 2018 Naslo se i jos nekih sitnica za prebacivanje na krem enterijer... Quote Share this post Link to post Share on other sites
Martin 799 Posted June 24, 2018 Uf kako bih ja to sa merakom ofarbao. Quote Share this post Link to post Share on other sites
Sedla 2576 Posted June 24, 2018 Pa i bice ofarbane... Vrlo uskoro! Iskreno ja jedva cekam da ih vidim na kolima.... Quote Share this post Link to post Share on other sites
Sedla 2576 Posted August 3, 2018 Posto je potraga za krem enterijerom bezuspesna, bar do sada... Nigde nema krem koznih sedista da se nadju... A izleteo mi odlican sivi stof enterijer, isti kao sto je vec kod mene u kolima, nisam uopste razmisljao, odmah sam ga uzeo... Sedista vrhunska, izvadjena iz Lybre koja je presla oko 140,000... Nego nemam sad ni jednu sliku tih sedista sto sam uzeo, izgleda da sam izbrisao. Elem, uzeo sam svih 5 sedista, tepih, i izolacije ispod tepiha. Sve u vrhunskom stanju! I danas se dadoh u rasklapanje... Dosao do instrument-table... I sad ne znam sta cu dalje. Da li da se upustam u zajebanciju oko skidanja iste, da bih zamenio motorice klime, koje sam odavno kupio, i sad stoje i skupljaju prasinu, ili da probam da ih zamenim ovako, bez skidanja table, nemam pojma... Nisam pametan. Razmotricu to sutra i prekosutra, videcu sta cu... Uglavnom, posle 4 godine u taksiju, i generalno posle 5ipo godina druzenja i eksploatacije, sve je u katastrofa stanju. Tepih jaaako strokav, i pocepan kod nogu vozaca, i pozadi, iza suvozaca, tamo gde se najvise sedelo u taxiju... Izolacija ispod tepiha takodje katastrofa, kruni se i raspada Za danas toliko uradjeno. Nastavak sledi... Quote Share this post Link to post Share on other sites
MS PK 7732 Posted August 3, 2018 Hmmm..od svega napisanog...slazem se samo sa ovim da nisi pametan Trebao si da trazis jos krem enterijer. Kad si vec uzeo taj sivi ( za koji ne mislim da je ruzan nikako) operi ga i stavi. Kad si vec povadio promeni te motorice ako ne rade jer nikad ti barem pristupacnije nece biti nego sad Quote Share this post Link to post Share on other sites
Martin 799 Posted August 3, 2018 Pda, kad je već kupus. Ona korozija po površini, jel može da se ošmirgla? Quote Share this post Link to post Share on other sites
danijel55 700 Posted August 3, 2018 Hoce li i bose biti sredjen sada? Quote Share this post Link to post Share on other sites
MS PK 7732 Posted August 4, 2018 Martin svuda samo korozije vidi Quote Share this post Link to post Share on other sites
cika_kole 825 Posted August 4, 2018 @MS PK kao da radi na tehnickom Quote Share this post Link to post Share on other sites
Sedla 2576 Posted August 4, 2018 @Martin gde ti vidis koroziju na mom autu, covece??? Nema je cak ni spolja, gde bi trebalo da ima... Boja se oljustila, ali se lim beli jos uvek... @danijel55 Bose nece biti resen uopste, kako stoje stvari. Prevelika je zajebancija i ogroman posao da napravim onako kako sam ja to zamislio, a to je da bude razvucen i povezan kao iz fabrike. A da ja razvlacim nove zice kojekude, da nastavljam i krpacim, to nema sanse. Verovatno cu prodati komplet Bose, sa sve instalacijom, nekome ko hoce da se bakce. Ja ne mogu. @MS PK hvala na komplimentu, druze... Nema krem koznog enterijera vec duze vreme... Generalno, u celoj Srbiji trenutno ima jako malo enterijera u ponudi za Lybre, a dobrih i odlicnih nema uopste. I ovo ne bih nasao da mi Strahinja nije dobar drugar i javio mi odmah za enterijer cim mu je stigla Lybra za rasturanje... Quote Share this post Link to post Share on other sites
danijel55 700 Posted August 4, 2018 Ma to ovi vozaci fiata o koroziji pricaju Ja kad sam farbao lajsne na kolima,komantar farbara cudi me da ni po rubovima nema ni tacka rdje. Quote Share this post Link to post Share on other sites
Sedla 2576 Posted August 4, 2018 @MS PK 'Ebo sam joj majku! Uspeo sam da skinem tablu danas... Zamenio 4 motorica klime, peti nema sanse da pridjem da zamenim. Onaj za usmeravanje na soferku. Nema teorije. Jedino kada bi sve bilo izvadjeno napolje, pa da se rastavi ventilator od ostatka konzole, mislim da bi tek onda mogao da se zameni taj motoric. Sutra krece sklapanje... 2 Siki97 and cika_kole reacted to this Quote Share this post Link to post Share on other sites
cika_kole 825 Posted August 4, 2018 @Sedla imas brate muda do kolena, svaka tebi cast... 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted August 4, 2018 Hahah... @cika_kole kazi mi to kad je budem sastavio... Lako je rastaviti, ides redom i odvijas srafove... 1 cika_kole reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted August 4, 2018 I jaoo, i jaoo, i jaooo .. Quote Share this post Link to post Share on other sites
Sedla 2576 Posted August 4, 2018 Ajde, ajde, ne kukaj... Cestitaces mi sutra kad budem izbacio slike sastavljenog auta. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted August 4, 2018 Hocu, od srca 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted August 4, 2018 @danijel55 e nek' si im rekao! Kakva korozija kod Lancije?!? Quote Share this post Link to post Share on other sites
