markosdbg 0 Posted May 11, 2014 Ok druze,hvala ti. Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted May 11, 2014 Ja se vec duze spremam da sebi odradim farove.Ja cu ici na sledecu kombinaciju,u ogledalo od dugog svetla idu migavci,na mesto migavaca idu SMD LED paneli koji ce se koristiti kao dnevno svetlo,naravno morimoto bixenon i maglenke pored i to je to Послато са GT-I9300 уз помоћ Тапатока Quote Share this post Link to post Share on other sites
markosdbg 0 Posted May 14, 2014 Ajde kad zavrsis,postavi slike da vidimo kako izgleda. Quote Share this post Link to post Share on other sites
markosdbg 0 Posted May 29, 2014 Stigli projektori,pre par dana. Za vikend planiram da namestim,pa ce biti i neka slika. Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted May 29, 2014 Ako treba pomoc neka vici Quote Share this post Link to post Share on other sites
markosdbg 0 Posted May 29, 2014 Ej hvala bato. Juce sam se zezao na starom faru i uspeo sam da provalim kako moze da se namesti. Tako da se nadam da nece biti problema. Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted May 29, 2014 Ako treba zovi,ja sam slododan za vikend poslepodne Quote Share this post Link to post Share on other sites
markosdbg 0 Posted May 29, 2014 Ako se ne snadjem,zovem te sigurno. Moram prvo ujutru do Bubanj Potoka,da kupim h1 sijalice,pa cu se baciti na posao. Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted May 29, 2014 Onda se vidimo tamo,videces stand magneti marelli Quote Share this post Link to post Share on other sites
markosdbg 0 Posted May 29, 2014 Jel u prvom delu,ili preko mosta? Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted May 29, 2014 Bice odma kod ulaza negde Quote Share this post Link to post Share on other sites
markosdbg 0 Posted May 29, 2014 Ja cu da trazim ZEMUNCA1993 Quote Share this post Link to post Share on other sites
markosdbg 0 Posted June 1, 2014 Posto su projektori stigli pre nedelju dana,za vikend sam bio malo vredan,pa sam ih postavio u farovu.Nemam potrebe da postepeno da objasnjavam,posto je vec sve to radjeno u ovoj temi,samo cu postaviti slike. konacan ishod U duga svetla sam postavio led lampice,koje sam u ranijem postu postavljao slike i dobra stvar je sto nikoga ne zaslepljuje,jer ne svetle preterano jako,taman koliko treba za dnevna svetla.Stedim projektore,sto je najbitnije. Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted June 1, 2014 Tri stvari.Pod jedan jesu li to originalni Valeo farovi? (izgleda mi kao da si ga nekako mnogo lako otvorio i ne izgleda previse razvaljeno sto je odlicno!!!).Pod dva,jesi li stavio solenoid sa zavesicom za dugo jer na jednoj slici se vidi fabricki lim a na kraju vidim ipak i dugo xenon?I trece,jedna zamerka,nije ti ravna linija koji bacaju projektori,trebao bi to da ispravis.Sve u svemu odlican posao Quote Share this post Link to post Share on other sites
markosdbg 0 Posted June 1, 2014 (edited) Pod 1: Nisu originalni farovi,nego made in P.R.C. Dosta sam lako otvorio,zato sto su Kinezi stavili kao neku vrstu gume,koju kad grejes lako se otopi,a posle nekog vremena se stvrdne.Jako dobra fora.Pod 2: Pogledaj sliku br.8.Pod 3: I meni se cini da sam zeznuo levu stranu Hvala za to,ispravicu,i hvala za pohvalu,naravno Edited June 1, 2014 by markosdbg Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted June 1, 2014 Jes vala vidi se kablic ali ne vidim el magnet i ostalo,zato sam pitao Koliko kelvina su sijalice? Quote Share this post Link to post Share on other sites
markosdbg 0 Posted June 1, 2014 Hahah..Pa slikao na brzinu,da bih zavrsio sve pre mraka.Xenoni su 4300k ac.Barem bi tako trebalo,ako nisu zeznuli ortaka,mada lepo svetli.Sve u svemu,jako sam zadovoljan. Quote Share this post Link to post Share on other sites
Vule 795 Posted June 1, 2014 Definitivno obe strane treba zarotirati jednu od druge, da se upegla linija lepo Quote Share this post Link to post Share on other sites
markosdbg 0 Posted June 1, 2014 Definitivno obe strane treba zarotirati jednu od druge, da se upegla linija lepo Kako to mislis da izvedem? Quote Share this post Link to post Share on other sites
Vule 795 Posted June 1, 2014 Paaa, to si prvo trebao uraditi pre nego što si zatvorio farove, montirati ih na auto i lepo testirati, uštelovati i izrotirati. Jedino da se otvaraju ponovo pa da se levi projektor zarotira malo na levu stranu, desni na desnu, ovako idu u X, ukrštaju se Quote Share this post Link to post Share on other sites
markosdbg 0 Posted June 1, 2014 Pa ja sam ih linijski ravno postavio. Mozda su projektori takvi,nemam pojma. Uglavnom,lepo izgleda,mnooooogo bolje nego fabricki farovi,ako me razumes Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted June 1, 2014 Ti si ih ravnao prema onom limenom nosacu ali on stoji nekako u V nije savrseno horizontalan kad se montira na auto.To je mozda milimetar-dva u pitanju ali kad se razvuce na ovoliku sirinu cutoff izgleda ovako nakrivo Quote Share this post Link to post Share on other sites
markosdbg 0 Posted June 1, 2014 Ej nemojte da me ubijate u pojam,ne mogu ponovo da ih otvaram. Nemam zivaca uopste. Quote Share this post Link to post Share on other sites
markosdbg 0 Posted June 1, 2014 Sad bio da prestelujem farove,ponovo. Ne moze da se dovede tacno u liniju,ili ja mozda ne znam. Izgleda da sam zeznuo stvar u centriranju,ali jbg. Sad je gotovo u svakom slucaju. Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted June 1, 2014 Nisi trebao da zatvaras far pre probe Quote Share this post Link to post Share on other sites
