Fiat Uno 70 SX 0 Posted January 17, 2014 Zamolio bi ako neko moze da mi pomogne?Problem je sledeci: Posedujem Fiat Uno 70 SX i imam problem da na istom broju obrtaja (oko 2000 rpm) dal pri voznji ili pri kretanju auto neprijatno trzne i nastavi dalje normalno da radi!?Da napomenem da sam izmenjao sve zivo da bi probao da ustanovim u cemu je problem: Monopoint,digipleks,kapu,ruku,kablove,svecice... Quote Share this post Link to post Share on other sites
ViktorBG 84 Posted January 17, 2014 Pumpa za goriovo? Quote Share this post Link to post Share on other sites
Fiat Uno 70 SX 0 Posted January 17, 2014 Menjana. Quote Share this post Link to post Share on other sites
YUgisa 2513 Posted January 18, 2014 Pretpostavljam da ima senzor otvorenosti leptira, jel si proverio njega? Quote Share this post Link to post Share on other sites
Fiat Uno 70 SX 0 Posted January 18, 2014 Menjao sam celu karburaciju,jedino ako je i na drugoj neispravan!? Quote Share this post Link to post Share on other sites
YUgisa 2513 Posted January 18, 2014 (edited) Proveri zicu po zicu da li ima prekida sa unimerom Edited January 18, 2014 by YUgisa Quote Share this post Link to post Share on other sites
Fiat Uno 70 SX 0 Posted January 18, 2014 Bice to uzbudljivo iskustvo! Quote Share this post Link to post Share on other sites
ALBooM 0 Posted January 18, 2014 hmm po meni ovo ima veze sa stepenom paljenje smese probaj da stavis da malko ranije pali smesu u cilindrima Quote Share this post Link to post Share on other sites
Flavio 0 Posted January 19, 2014 Mislim da je neki prekid negde i mislim da je isključivo problem do struje.Ako možeš proveri da li je "masa" dobro fiksirana mada Mislim da to nije problem. Znam da nisam nešto pomogao ali ... Quote Share this post Link to post Share on other sites
ALBooM 0 Posted January 20, 2014 kasno ti panjenje pomeri na ranije Quote Share this post Link to post Share on other sites
Fiat Uno 70 SX 0 Posted January 20, 2014 Mislim da je neki prekid negde i mislim da je isključivo problem do struje.Ako možeš proveri da li je "masa" dobro fiksirana mada Mislim da to nije problem. Znam da nisam nešto pomogao ali ... Hvala u svakom slucaju! kasno ti panjenje pomeri na ranije aj probacu i to da uradim pa da vidim sta ce da bude. Quote Share this post Link to post Share on other sites
boleabarth 0 Posted January 22, 2014 Mislim da je bane dok je imao una slican problem,koliko se secam resio ga je zamenom sonde,tako se ispoljava kod njih taj problem Quote Share this post Link to post Share on other sites
Fiat Uno 70 SX 0 Posted January 23, 2014 Koje sonde, jel lambda? Quote Share this post Link to post Share on other sites
Flavio 0 Posted January 24, 2014 Moze biti Lambda mada ona cuca stalno na malom gasu, nije da samo 1x secne na 2k rpm ...Jel Uno ima plin? Ako ima, jel se isto desava na oba goriva ili?Jel na njemu bash Single Point ubrizgavanje ili karburator? Da nije prljava dizna ako je SPI? Quote Share this post Link to post Share on other sites
Fiat Uno 70 SX 0 Posted February 16, 2014 Nema plin.Bas je singlepoint.E cistio sam ultrazvucno diznu i opet nista! Quote Share this post Link to post Share on other sites
Fiat Uno 70 SX 0 Posted February 24, 2014 hmm po meni ovo ima veze sa stepenom paljenje smese probaj da stavis da malko ranije pali smesu u cilindrimaKako???Pumpa za goriovo?Koliko si siguran da je do pumpe,da li je moguce da mi nova pumpa pravi problem? Quote Share this post Link to post Share on other sites
dobri nikola 15 Posted January 19, 2015 Ako si u mogucnosi sa osciloskopom treba proveriti senzor polozaja leptira. Mislim da pod odredjenim uglom koji daje 2000 O/min., imas takozvanu crnu rupu. Odnosno, nemas kontakt, moglo bi se sa tropinskim kablom i plavim KKL interfejzom odraditi dijagnostika. Quote Share this post Link to post Share on other sites
