Kuvalja 406 Posted October 10, 2014 A kakav ti je filter vazduha, da nije puno prljav, pa nema dovoljno vazduha? Quote Share this post Link to post Share on other sites
totti 13165 Posted October 10, 2014 Ne dobija vazduh... Moguće da je filter zapušen, a moguće i interkuler. Proveri i njega, može biti da je pun ulja. Ima šanse i da je on u maleru. Quote Share this post Link to post Share on other sites
deki87 7 Posted October 11, 2014 Pre ce da bude filter vazduha nego interkuler.... Quote Share this post Link to post Share on other sites
totti 13165 Posted October 11, 2014 Uvek treba krenuti od najbezazlenijeg... Ali hoće tako da se manifestuje i kad pomeša vodu i ulje. Quote Share this post Link to post Share on other sites
marijoxyz 0 Posted October 11, 2014 A kakav ti je filter vazduha, da nije puno prljav, pa nema dovoljno vazduha?nov,a i stari nije bio previse zaprljanfilter za vazduh je nov,stari nije bio pretjerano prljav,znaci da provjerim interkuler. Quote Share this post Link to post Share on other sites
marijoxyz 0 Posted October 11, 2014 a danas mi je trebao i start sprej!!! Quote Share this post Link to post Share on other sites
deki87 7 Posted October 11, 2014 Teraj ti to kod majstora,nesto tebe zeza motor,nije li prezubio...? Quote Share this post Link to post Share on other sites
marijoxyz 0 Posted October 11, 2014 od 50 puta jednom ne upali inace radi odlicno.bio sam kod majistora i jos nista niko nije skontao Quote Share this post Link to post Share on other sites
marijoxyz 0 Posted October 14, 2014 danas oprt ista prica.ali sam samo skinuo dzek sa protokomjera i upali.e sad,da li je slucajnost ili nije.ja ne mogu kupovati senzore i ventile onako bez veze.jedan majistor kaze ovo je,drugi ono je,treci nije ni ovo ni ono i tako. Quote Share this post Link to post Share on other sites
deki87 7 Posted October 14, 2014 Pa skini dzek sa protokomera pa vozi tako par dana da vidis da lice da se ponavlja. Quote Share this post Link to post Share on other sites
marijoxyz 0 Posted October 14, 2014 pa jel se moze tako voziti?zasto onda uopste i postoji i koja mu je funkcija. Quote Share this post Link to post Share on other sites
deki87 7 Posted October 14, 2014 Moze da se vozi,auto ce uci u safe mod i ici ce slabije ako je dobar,ako ne onda je los.Probaj pa vidi. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted October 14, 2014 Ne mora uopste da udje u safe mod, kada se skine dzek, ecu uzima default vrednosti i tako ide, od nuspojava moze biti vise dima i veca potrosnja ali i ne mora jer ako je los protokomer, bolje je bez njega nego sa njim, vozi slobodno neko vreme pa ako sve radi, ti vrati dzek da vidis oce ponovo zezati pa onda znas da li je do njega Quote Share this post Link to post Share on other sites
deki87 7 Posted October 14, 2014 Pa dodje mu isto da lije safe ili default,meri srednje vrednosti koje je zapamtio ecu i na osnovu toga pravi smesu....probaj koji danan pa javi. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted October 14, 2014 Ja koliko sam upucen, auto kad upadne u safe mode vuce se kao puz, nema snage..... a kada uzme default vrednosti mozes i da se potrkas ako zelis, ima dosta ljudi koji voze godinama bez protokomera, evo bas Vule sa bravom koja je cipovana vozi tako dugo vremena i ode na miseluk da se poteze, ne znam da li je sada u medjuvremenu zamenio protokomer ali bas dug vremenski period ga nije imao. Quote Share this post Link to post Share on other sites
Sedla 2576 Posted October 15, 2014 Auto kad udje u safe mod radi konstantno na 1100rpm i ne mozes da mu das gas,zato se i vuce tako. A kad ECU koristi neke default vrednosti onda mozes i na trke,sto kaze Kuvalja,samo sto se tada ponasa drugacije nego sa zakacenim,ispravnim protokomerom. I mislim da uvek vise trosi sa raskacenim protokomerom. Quote Share this post Link to post Share on other sites
marijoxyz 0 Posted October 16, 2014 danas nije pomoglo ni skidanje crijeva od vazduha ni skidanje dzeka od protokomjera a nisam htjeo spricati start sprej nego sam cekao majistora.dosao je nakon 3 sata a ja u medjuvremenu nisam ni pokusavao upaliti.kad je dosao upali normalno i nije pokazao nikakvu gresku!!!!???? Quote Share this post Link to post Share on other sites
deki87 7 Posted October 17, 2014 A sa egr-om sta bi jeli zatvoren....? Quote Share this post Link to post Share on other sites
MS PK 7732 Posted October 17, 2014 Da nije senzor radilice ili nesto tako slicno? Quote Share this post Link to post Share on other sites
marijoxyz 0 Posted October 17, 2014 Da nije senzor radilice ili nesto tako slicno?juce kad je majistor dosao upali kao da nista nije bilo i danas citav dan pali normalno.sutra stavljam drugi senzor radilice pa da vidim. A sa egr-om sta bi jeli zatvoren....?a kako da znam kad je zatvoren a kafd otvoren? Quote Share this post Link to post Share on other sites
deki87 7 Posted October 17, 2014 To moze samo preko dijagnostike da se vidi...mislio sam da lisi ga zatvorio fizicki...? Quote Share this post Link to post Share on other sites
MS PK 7732 Posted October 18, 2014 Pregledaj i dovod nafte, filter, gumice i creva, da slucajno negde ne navuce vazduh. Nas je sprinter zezao ovih dana tako. Samo tek odjednom nece da upali. Sacekas malo i upali. Ispostavilo se da je bila losa gumica na filteru za naftu Quote Share this post Link to post Share on other sites
dejica 21 Posted October 18, 2014 to je 100 % senzor radilice ili bregaste ali moguce i da je da negde povlaci vazduh u dovodu goriva mada vise sumnjam na senzore videcemo sta je do kraja . a da zaboravio sam da pitam da liti se cuje pumpa u rezervoaru kad das kontakt hoce i to kad je pumpa pred otkaz cas radi cas neradi i tad nema nista od paljenja vratis nekoliko puta kontakt ona proradi i auto upali ali to dok nacisto neode pumpa i onda nema vise paljenja . ? Quote Share this post Link to post Share on other sites
marijoxyz 0 Posted October 19, 2014 to je 100 % senzor radilice ili bregaste ali moguce i da je da negde povlaci vazduh u dovodu goriva mada vise sumnjam na senzore videcemo sta je do kraja . a da zaboravio sam da pitam da liti se cuje pumpa u rezervoaru kad das kontakt hoce i to kad je pumpa pred otkaz cas radi cas neradi i tad nema nista od paljenja vratis nekoliko puta kontakt ona proradi i auto upali ali to dok nacisto neode pumpa i onda nema vise paljenja . ?cuje se pumpa.zamjenio sam juce senzor radilice pa cemo vidjeti sta je.mislim da nigdje ne vuce vazduh zato sto nema pravila da li mi auto stoji 2 sata ili 2 minute pa nece da upali.To moze samo preko dijagnostike da se vidi...mislio sam da lisi ga zatvorio fizicki...?e to na znam kako mogu da ga fizicki zatvorim. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted October 19, 2014 Pogledaj temu na forumu, stavi se samo plocica. Prostije ne moze da bude Quote Share this post Link to post Share on other sites
