milos_84 1 Posted November 26, 2013 (edited) Da li neko zna kako da skinem ovu traku koja ide preko akumulatora kako bih ga izvadio napolje? Edited January 7, 2020 by neshaoct prebacio sliku na FLCS server Quote Share this post Link to post Share on other sites
Multijet forever 0 Posted November 26, 2013 Trebalo bi da sa ove donje strane (ka braniku imas sraf sestougaoni njega odrsrafis i skines) ili je sa te ili sa one druge strane, sa neke jeste Quote Share this post Link to post Share on other sites
totti 13160 Posted November 26, 2013 T ključ 13 Quote Share this post Link to post Share on other sites
milos_84 1 Posted November 26, 2013 Ima sraf ali ja nemam gedoru pa ne mogu da mu pridjem Quote Share this post Link to post Share on other sites
Multijet forever 0 Posted November 26, 2013 Eeee to je vec problem druge prirode Quote Share this post Link to post Share on other sites
milos_84 1 Posted November 26, 2013 Nasao alat .Hvala puno ljudi Quote Share this post Link to post Share on other sites
Ivan 17587 Posted November 27, 2013 Ima sraf ali ja nemam gedoru pa ne mogu da mu pridjemKoja tema . Quote Share this post Link to post Share on other sites
zokizd 4 Posted January 7, 2020 (edited) Srećan Božić! Imam problem sa akumulatorom. Hteo bih da ga skinem i dopunim da se dokotljam do prodavnice ali mi nije jasno da li mora da se skida vezni lim koji ide preko akumulatora? Bravo 1.6 MJet Pozdrav Edited January 7, 2020 by neshaoct formatiranje / spojeno 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9590 Posted January 7, 2020 @zokizd Pogledaj sada, nakon spajanja, sve ranije napisano u temi na kojoj smo. Videćeš da treba da se skida... Quote Share this post Link to post Share on other sites
zokizd 4 Posted January 8, 2020 (edited) Da za gurtnu znam ali ima sipka preko akumulatora koja spaja krilo i prednji vezni lim,da li i nju moram skinuti ili postoji neki trik? Na slici mi izgleda kao da je skinuta? Pozdrav Edited January 8, 2020 by zokizd 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted January 8, 2020 (edited) Moras skidati tu sipku. Treba ti 15 i 17 za odvrtanje. Dva gornja srafa su 17 a ostali 15 o ovome pricamo...cisto slikovito da se prikaze Edited January 8, 2020 by Milutinac 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
zokizd 4 Posted January 8, 2020 Da li bi morao negde da obelezim zbog vracanja ili su rupe tacno na srafu,ako sam se dobro izrazio!Hvala Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted January 8, 2020 Ne komplikuj sebi zivot. Duze si sad to pisao nego sto bi ti trebalo da odvrnes i zavrnes. 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Ivan 17587 Posted January 8, 2020 @Milutinac Treba li procedura zamene, da vadimo iz eLearn ? Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted January 8, 2020 OBAVEZNO! Redosled odvrtanja/zavrtanja svakog srafa pojedinacno, na koliko NM da se steze i mozda i najvaznije kojim tutkalom da se podmaze to sve lepo. 3 alfini0507, kreator and totti reacted to this Quote Share this post Link to post Share on other sites
Ivan 17587 Posted January 8, 2020 (edited) 37 minutes ago, Milutinac said: OBAVEZNO! Redosled odvrtanja/zavrtanja svakog srafa pojedinacno, na koliko NM da se steze E'o buraz. Stavio sam i moment stezanja, fabrika kaze 2-2.4 daNm . A ti dodaj ovo za tutkalo : Edited January 8, 2020 by Ivan 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
ivan73 336 Posted January 8, 2020 (edited) Al ne treba oba gornja, samo donja dva i jedan gornji. Pazi na onu navrtku (Poz. 2b sa druge slike) što sa trakom pričvršćuje akumulator...da ne ispadne! Edited January 8, 2020 by ivan73 Quote Share this post Link to post Share on other sites
zokizd 4 Posted January 8, 2020 (edited) Skinuo! Kod mene su 3 srafa 13, gornji 15 koji nisam skinuo i donji 10 koji drzi akumulator! Hvala Fiatovci! Posle samo da kupim tutkalo!!!!!! Edited January 8, 2020 by zokizd 1 Ivan reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted January 9, 2020 (edited) 17 hours ago, ivan73 said: Al ne treba oba gornja, samo donja dva i jedan gornji. Slazem se. Ali tako krivis sipku mislim ajd ispravi se ona kada zavrnes sve posle, ali se slabi svakako... Edited January 9, 2020 by Milutinac Quote Share this post Link to post Share on other sites
S.V.E.T.A. 125 Posted January 9, 2020 Ja bas ovo hteo da pitam ali za Deltu, ta sipka je malo drugacija ali je izgleda isti princim tj. mora da se skida radi zamene akumulatora... Quote Share this post Link to post Share on other sites
Ivan 17587 Posted January 9, 2020 Naravno, sve isto, samo je koliko se secam poprecna sipka drugog oblika i gore ima 4 srafa. Iznad je bila zafrkancija, pa da ne vadimo i to iz eLearn . Quote Share this post Link to post Share on other sites
S.V.E.T.A. 125 Posted January 9, 2020 Naravno, nema potrebe. A kada dodje vreme, svakako cu to u servisu da odradim... Quote Share this post Link to post Share on other sites
