nemke 92 Posted February 25, 2016 http://setkvacila.rs/. Kod njih za 9100din i ruke 5000din plus ulje u menjacu 2100din kad sam kupio auto menjao sam mu kvacilo i stavio sam mu valeo i zadovoljan sam.. Quote Share this post Link to post Share on other sites
joshibeast 74 Posted February 25, 2016 Koliko km ti je izdržao taj prvi Valeo što si ugradio sa čipovanim autom? Quote Share this post Link to post Share on other sites
nemke 92 Posted February 25, 2016 (edited) Ima u temi kad sam ga uzeo. Od tad pa do danas malo jace od 70000km ali racunaj da sam sa chipom presao jace od 35000km. stigao set Edited February 25, 2016 by nemke Quote Share this post Link to post Share on other sites
joshibeast 74 Posted February 25, 2016 70k je dosta za zamenski Valeo na čipovanom autu Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted February 25, 2016 Jesi uzeo semering na menjacu? Quote Share this post Link to post Share on other sites
nemke 92 Posted February 25, 2016 Nisam nista uzeo osim ulja i kvacila.. Stefan mi kaze da curi ulje iz menjaca.. I da ce da vidi sta je jos kad skine menjac.. Quote Share this post Link to post Share on other sites
jtds 0 Posted February 25, 2016 (edited) Saks je najbolji ,koliko li je on mora da izdrzi mnogo vise nego Valeo sa cipom Edited February 25, 2016 by jtds Quote Share this post Link to post Share on other sites
nemke 92 Posted February 25, 2016 Sigurno je bolji... Ali kad skupis lovu za limariju... Pa u medjuvremenu ode kvacilo... Quote Share this post Link to post Share on other sites
Axic 19724 Posted February 25, 2016 (edited) 1 hour ago, jtds said: Saks je najbolji ,koliko li je on mora da izdrzi mnogo vise nego Valeo sa cipom Ne mora da znaci, skoro je u temi o kvacilima pisao kolega da je novi SACHS set izdrzao jedva 9.000 km a placen prilicno za razliku od Valeo seta. Vodjen mislju da je najskuplje najbolje ipak se pokazalo kao netacno. Edited February 25, 2016 by Axic Quote Share this post Link to post Share on other sites
nemke 92 Posted February 25, 2016 E ljudi koga briga da li je luk ili sax ili valeo?? Sto se mene tice samo valeo!! Ovako sad me je zvao majstor. Set kvacila 9100 ruke za menjanje kvacila 5000din remont menjaca i skidanje menjaca 5000din zadnji semering 1500din to je za sad a bice jos delova za menjanje kad skine menjac.. Sve moj do mojega sa puntom mrtvim!!!! Quote Share this post Link to post Share on other sites
gorank82 173 Posted February 25, 2016 Ćuti tamo ajde baci pogled koliko kosta set kvacila i sve to za neki drugi auto, samo set bi te tolko izasao ako ne i vise... Quote Share this post Link to post Share on other sites
nemke 92 Posted February 25, 2016 I to sto kazes.. Set je 13 a ja sam ga platio 9 Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted February 26, 2016 Jel si kod njih uzeo i prethodni set,mislim sa onog sajta? Quote Share this post Link to post Share on other sites
nemke 92 Posted February 26, 2016 Nisam. Predhodni mi je majstor nasao tad ja mislim sa nekim popustom za 11000din. inace auto ce danas biti gotov... Koliko sam skapirao majstora. U menjacu je otisla vodjica druk lagera sa semeringom i lezaj spojnicke osovine.. Sto znaci jos 50e i zadnji semering 1500din. Ja se nadam da je to to Quote Share this post Link to post Share on other sites
nemke 92 Posted February 26, 2016 Radovi u toku... Zamajac je odlican.. Ali zato korpa,lamela i druk lezaj istroseni do kraja... Quote Share this post Link to post Share on other sites
ivansd 13 Posted February 26, 2016 mozda ti lamela ni bi jos stradala da to ulje nije curelo Quote Share this post Link to post Share on other sites
nemke 92 Posted February 26, 2016 To jeste.. Tako mi je i majstor rekao.. Quote Share this post Link to post Share on other sites
nemke 92 Posted March 21, 2016 Odradjen mali servis i zamenjen donji nosac motora. Stavljen sportingov kacket Opran motor. Lagano se skupljaju pare za limariju. Ipak cu najverovatnije da menjam polustranicu... Kad budem farbao stranicu. Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted March 21, 2016 Kakav ti je bre ovo zenski filter Ti i u dug i u kratka imas xenone? Koje si stavio u duga? Klasicne ili neke "brze"? Quote Share this post Link to post Share on other sites
joshibeast 74 Posted March 21, 2016 Da vidiš kako Nemke na Interu čisti filter vazduha - metodom tras u beton Quote Share this post Link to post Share on other sites
nemke 92 Posted March 21, 2016 Fensi filter i kratka i duga su na kratkim farovima.. Quote Share this post Link to post Share on other sites
nstyner 168 Posted March 21, 2016 Bogme sija ispod haube Quote Share this post Link to post Share on other sites
nemke 92 Posted March 26, 2016 Igranka bez prestanka... Ispucala creva sto idu od malog hladnjaka do termostata. Quote Share this post Link to post Share on other sites
gorank82 173 Posted March 26, 2016 Ma to jeftino, samo nek drze vodu Quote Share this post Link to post Share on other sites
nemke 92 Posted March 26, 2016 Pocelo vec zadnja dva dana da mi curi po menjacu.. A taman sto sam ga uradio. Nije skupo Akronova creva 2100 i zamena 1000din. Nego imam problem sa menjacem? Kad ubacim u rikverc pocinje da krci to jest kao da lomi nesto. Pustim kvacilo opet pritisnem opet tek treci put ako imam srece lepo udje u rikverc. A radjen je remont menjaca i nov je set kvacila. Quote Share this post Link to post Share on other sites
