Gagy.GM 59 Posted February 18, 2014 Odlicna sedista nema sta Quote Share this post Link to post Share on other sites
DinoG 7 Posted February 18, 2014 Hvala ljudi Mogao sam uzeti naslon, ali nama obojici to samo smeta pa ga nismo ni uzeli Quote Share this post Link to post Share on other sites
sportingM 0 Posted February 18, 2014 Odlican, sedista i osvetljenje table su najjaci !!! Quote Share this post Link to post Share on other sites
MiroslavL 0 Posted February 19, 2014 Komšija ovo je leglo samo tako ! Quote Share this post Link to post Share on other sites
Bogisha 9 Posted February 19, 2014 Buu, i pre sedišta je bio odličan, a sad i sa njima.... Quote Share this post Link to post Share on other sites
DinoG 7 Posted February 19, 2014 Hvala vam, drago mi je da vam se svidja Biti ce jos bolji kada za vikend.namontiramo zadnju klupu, a taman bi do vikenda i felge trebale doci s bojanja, ako ne bude nekih problema Quote Share this post Link to post Share on other sites
Axic 19996 Posted February 19, 2014 Upravo to i cekam, postavljenu zadnju klupu pa da kompletiramo sliku enterijera mada i sad sa ovim prednjim sedistima deluje a kamoli kad se postave i zadnja. Quote Share this post Link to post Share on other sites
Stilisa 313 Posted February 19, 2014 Zadnjih nekoliko strana pratim i vidim pominju se dve osobe da voze, al' reko verovatno braca, pa se vratim na pocetak, iscitam celu temu i vidim da su ipak otac i sin u pitanju. Stvarno sam se prijatno iznenadio, retko gde to ima. Svaka cast, komsije. Puntic je prva liga, ukusno se sredjuje, bas kako se meni dopada. Samo napred. Quote Share this post Link to post Share on other sites
DinoG 7 Posted February 20, 2014 Hvala na ljepim komentarima Danas smo uhvatili malo vremena i upasali donju klupu sto je relativno laksi dio posla, za vikend ide naslon Quote Share this post Link to post Share on other sites
Sedla 2576 Posted February 20, 2014 Ajde,ajde,ja jos nisam nista pisao na ovoj temi ali pratim sta se desava,i jedva cekam da vidim kako ce da ispadne na kraju! Punto je stvarno... Quote Share this post Link to post Share on other sites
igor0511 2877 Posted February 20, 2014 Sedišta bolesno izgledaju. Biće bombona kada se kompletira. Inače, čiji je skejt? Quote Share this post Link to post Share on other sites
Drazen.OS 31 Posted February 20, 2014 Skejt je Dinin, evo dokaz. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted February 20, 2014 O Dražene mali vraže.... cepas i ti skate nego ne smes da priznas Quote Share this post Link to post Share on other sites
Zemunac1993 1 Posted February 20, 2014 Sedista su mu legla kao dupe na nosu Gledam slike i dolazim u iskusenje da moja kozna sedista iz 147 zamenim takvim... Quote Share this post Link to post Share on other sites
SikterBre 31 Posted February 21, 2014 Teško se nalaze, ali vrede svaki dinar... Dobar kick-flip Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 22, 2014 Sta se tesko nalazi, pisao covek da ih u sapcu ima i za izvoz Quote Share this post Link to post Share on other sites
SikterBre 31 Posted February 22, 2014 Pa pazi, i mi smo malo prosti, po ceo dan zevamo u ekran misleći da ćemo da nađemo nešto, a to što tražimo u narodu ima, pa čak i prilično jeftinije... Quote Share this post Link to post Share on other sites
DinoG 7 Posted February 23, 2014 (edited) Što se tiče mjesta za noge pozadi, prednje sjedalo je namješteno po meni (1.82m visine) i ima 15-ak cm za noge, a sjedala su dovoljno debela da se ne osjete koljena u leđima kao što je bio slučaj sa starima E sad što se tiče montažeSjedalo je relativno lakši dio posla i nije toliko kompliciran koliko naslon. Prebačene su orginalne puntove šarke samo su zašarafljene kroz udaljeniju rupu, a u sredini smo sami napravili nove šarkeŠarke su zanitane u lim, jer je ispod rezervar i ima jedno cca 1cm između njega i lima pa nismo mogli zašarafitiNa kraju smo samo prosjekli tepison i zagurali ga iza da sakrije šarke Naslon je bio teži dio posla. Po dimenzijama stane taman, ali je zbog nosača malo preširokPrvo smo upasivali bočne nosače, ostavili smo nosače od Alfe, ali smo koristili postojeće rupe. Plastike od tapacirunga su se morale malo urezati jer vijak od nosača se naslanja na njih, a već je sve na knap. Čak i kada smo urezali falio je cca 1 cm možda malo manje. Onda smo odlučili skinuti tapacirung sa sjedala da vidimo kako su učvrščeni nosači za sjedala. Srećom bili su zašrafljeni tako da su nosači skinuti i rupe proširene kako bi se nosači mogli povući prema sredini sjedala da bi dobili na prostoruSrednje nosače smo zadržali Alfine zbog sistema zaključavanja, ali dio koji ide prema rezervnom točku je odsjećen jer u našem slučaju se nema gdje zašarafiti i strši u zraku i smeta. Donji dio smo ušarafili u pod. Probušili smo 2 rupe, vijke gurnuli odolje i stavili cca 2 cm odstojnik da bi sjedala bila ravna. Važna stvar je da prije fiksiranja srednjih nosača je ta da sjedala moraju biti zaključana kako bi nosači bili u pravilnom položaju odnosno zaključani. Nama najvažnije je da to funkcionira kako treba i to smo uspjeli postići Edited February 23, 2014 by kolega.jankovic Molim te slike.....znas vec kako treba. Quote Share this post Link to post Share on other sites
diskusija 9 Posted February 23, 2014 baaaaas lepo Quote Share this post Link to post Share on other sites
Sedla 2576 Posted February 23, 2014 :clap: Svaka cast,decaci,lepp ste ovo odradili! Sad preostaje samo uzuvanje u Puntovim kozanim sedistima! Quote Share this post Link to post Share on other sites
Axic 19996 Posted February 23, 2014 Auuu kako izgleda zadnja klupa ... Quote Share this post Link to post Share on other sites
DinoG 7 Posted February 23, 2014 Hvala Sad se više nitko ne žali ako mora sjediti izaOprosti Jankoviću za slike, krivi link sam kopirao Quote Share this post Link to post Share on other sites
Axic 19996 Posted February 23, 2014 Jedino što će vozač ili suvozač morati da se klanjaju da bi taj koji iza sedi izašao ili ušao. Samo sam zbog toga prešao na auto sa petoro vrata ali priznajem da je svaki auto sa troje vrata lepši. Quote Share this post Link to post Share on other sites
DinoG 7 Posted February 23, 2014 Ja ne mrdam kad sjednem, a uglavnom svi koji se vozimo idemo na isto mjesto pa nije problem Nama dvojici koji smo u 90% vremena sami u autu bas i nije imalo razlike troje ili petoro vrata, tako da je presudio sa troje jer nam je obojici ljepsi, a i nismo bas imali izbora jer je bilo mozda 2 1.3 mjeta u oglasu, ali imas pravo da je sa petoro vrata puno prakticniji Quote Share this post Link to post Share on other sites
Bogisha 9 Posted February 23, 2014 Nije to sad bitno, dal je 5v ili 3v... Bitno je da su ova sedišta prelepa kada se postave, i da bih ja svoja iz Alfe menjao za ovakva TI sa crvenim koncem... Svaka čast, sjajan ti je Puntić. Quote Share this post Link to post Share on other sites
