swifty_kg 1 Posted June 29, 2015 Na tom uredjaju sa navigacijom postoji poseban prikljucak za GPS antenu. Ne moze da radi bez antene. Quote Share this post Link to post Share on other sites
urkelele 4 Posted June 29, 2015 Pa to je ono sto sam pitao, da li je GPS uredjaj (da kazem chip) integrisan u uconnect-u ili je on sa antenom. Ako je integrisan, lako cemo za antenu Quote Share this post Link to post Share on other sites
swifty_kg 1 Posted June 29, 2015 (edited) Ono sto mogu da ti kazem jeste da Navigacija funkcionise i bez antene ali normalno ne moze da se poveze sa satelitom i samim ti da odradi pozicioniranje. Sve ostale funkcije rade bez problema (kretanje krozmeni i podesavanja). Sad, da li je mogu ce upariti sa kompjuterom od 500l-a, verovatno da jeste ali kako, to ne znam. Edited June 29, 2015 by sale Quote Share this post Link to post Share on other sites
Zhorz 102 Posted June 29, 2015 Urk, pa jel imas ti navigaciju u meniju?! Quote Share this post Link to post Share on other sites
urkelele 4 Posted June 29, 2015 Nemam, nego sam nasao na oglase da neko prodaje uconnect sa navigacijom, zato sam i pitao. Elem, kod mene se nista ne desava kada pritisnem "radio" i "browse". Probao sam i u isto vreme i prvo jedno pa drugo i drzao duze od 5 sec i nece Kada udjem u Meni od uconnecta imam sledece opcije:display, voice command, clock&date, lights (odnosi se samo na corners), doors&locks, audio, phone&blootooth, radio setup i reset settings. Na "more" imam clock, trip i ecoDrive. Quote Share this post Link to post Share on other sites
Zhorz 102 Posted June 29, 2015 Drzi dugo,dugo Quote Share this post Link to post Share on other sites
swifty_kg 1 Posted June 29, 2015 (edited) Koliko dugo? Da li se drzi dok je radio ukljucen ili dok je iskljucen? Edited June 29, 2015 by sale Quote Share this post Link to post Share on other sites
Zhorz 102 Posted June 29, 2015 ukljucen, jbga tapatalk mi okrenuo sliku :-( Quote Share this post Link to post Share on other sites
urkelele 4 Posted June 29, 2015 Nece. Probao sam i druge kombinacije i nista. Ko ga j... Informaticar sam ja, provalicu Quote Share this post Link to post Share on other sites
debelizmaj 414 Posted June 29, 2015 Verovatno imas stariju verziju, u njoj je kombinacija tastera bila drugacija. Ne secam se koja je :-( Quote Share this post Link to post Share on other sites
urkelele 4 Posted June 29, 2015 (edited) pa mater mu, trebalo bi da imam najnoviju! Meni je auto iz juna 2015. godine. Edited June 29, 2015 by Urkelele Quote Share this post Link to post Share on other sites
debelizmaj 414 Posted June 29, 2015 Hm. Na ranijim verzijama je bilo settings i desni tockic pa su izmenili na radio + desni tockic Quote Share this post Link to post Share on other sites
Zhorz 102 Posted June 29, 2015 mozda imas nov hardwer ali softer ti je stariji od nasih jel smo mi updejtovali Quote Share this post Link to post Share on other sites
BobanFett 0 Posted July 5, 2015 Aj da ne otvaram novu temu, a generalno cenim da ima veze sa Uconnect, pa nije potpuni off...USB koji se nalazi dole pored AUX port-a iznad menjača, mi ne prepoznaje Corsair VoyagerGT USB 2.0 stik. Znači nije Kineski krš, nego jbg Corsair... Mator doduše ko biblija, 4gb ali i dalje radi bez problema na računaru.Isti USB port, nije mrtav, radi, jer kad ubodem WP na njega, regularno mogu da pustim muziku na telefonu i da je naravno čujem u kolima, a i pali mi se "charging" na telefonu, tako da je port živ.Btw, USB formatiran kao FAT32 tako da nije do fajl sistema. Nemam u ovom trenutku drugi da proverim (odnosno mrzi me da silazim ponovo do kola), pa rekoh da pitam jel imao neko sličan problem (ne bi me čudilo da je neki dreš od USB-a...) Probaću sutra sa Patriotom USB 3.0 od 32 giga, ali mi se on ne vucara baš po kolima jer ga koristim često... Quote Share this post Link to post Share on other sites
debelizmaj 414 Posted July 5, 2015 Ja sam imao problem sa nekim matorim kingstonima problem. Na pc ga cita bez problema, uconnect nece. Quote Share this post Link to post Share on other sites
BobanFett 0 Posted July 5, 2015 (edited) Mater mu njegovu, a taman sam mislio da ovaj "penzionišem" za mjuzu u kolima... Ništa, hvala na odgovoru Edited July 5, 2015 by BobanFett Quote Share this post Link to post Share on other sites
Zhorz 102 Posted July 6, 2015 jel samo mp3 imas na tom fleshu? meni bio jedan video fajl i poludeo mi player, kada sam izbrisao video fajl sve normalno radi Quote Share this post Link to post Share on other sites
BobanFett 0 Posted July 6, 2015 Da, samo MP3, sveeže formatiran baš za tu priliku... Ništa osim mp3... probaću danas sa nekim drugim stikom... Čak mi ni ne pali kontrolnu lampicu na stiku... Quote Share this post Link to post Share on other sites
swifty_kg 1 Posted July 6, 2015 Da li se nekome desavalo da mu ne rade zadnji zvucnici? Provereno su ispravni ali nema zvuka. U opcijama ima samo balance, nema fader? Quote Share this post Link to post Share on other sites
urkelele 4 Posted July 6, 2015 (edited) Nije fader, drugacije se zove opcija. Ja sam danas to cackao, ali me ubi ne mogu da se setim kako pise... Ja jos uvek nisam nasao nacin kako da ocitam koji je firmware u uconnect-u @BobanFett ako ti je stari stick najverovvatnije se pojeli konektori na istom. E sad, pitas se kako radi u racunaru... e pa radi Na mnnogo fleski sam naisao koje na nekim racunarima rade a na nekim ne. Edited July 6, 2015 by Urkelele Quote Share this post Link to post Share on other sites
pavaobg 0 Posted July 6, 2015 Čini mi se da je u balance-u i fader, odnosno ima grafički prikaz pa se tapka gde da bude centar zvuka. Ako se prebaci napred onda se utišavaju zadnji zvučnici. To koristim kad dete zaspi pozadi pa njoj utišam, a sebi ostavim. Quote Share this post Link to post Share on other sites
Marko Topola 50 Posted July 6, 2015 Trebalo bi na Balance da se balansira strana, da li ce biti glasnija leva strana ili desna... A na fader prednja i zadnja. Quote Share this post Link to post Share on other sites
pavaobg 0 Posted July 7, 2015 Settings -> audio -> balance/fade i tapneš gde ti odgovara Quote Share this post Link to post Share on other sites
swifty_kg 1 Posted July 9, 2015 Kao sto napisah, nema fader opcije. Zato sam i pitao. Quote Share this post Link to post Share on other sites
Zhorz 102 Posted July 9, 2015 ? Imas sve u jednoj opciji, pomeras strelicom, ne razumem sta hoces? Quote Share this post Link to post Share on other sites
