VladaG9 147 Posted November 26, 2017 @Bibi Jedan forumas je postavio vec taj video pre nekih mesec dana. Ja se taman ponadao da je izasao jos jedan update Quote Share this post Link to post Share on other sites
Bibi 0 Posted November 26, 2017 On 11/26/2017 at 7:36 PM, VladaG9 said: [mention=7628]Bibi[/mention] Jedan forumas je postavio vec taj video pre nekih mesec dana. Ja se taman ponadao da je izasao jos jedan update Ups, moja greška. U svakom slučaju uradio update, sve radi kako treba. Quote Share this post Link to post Share on other sites
Dejanco 2 Posted November 26, 2017 I ja pomislio novi update. Quote Share this post Link to post Share on other sites
Bibi 0 Posted November 30, 2017 Da li neko zna kako se ulazi u inženjerski mod na novoj verziji 12.00.24.01? Quote Share this post Link to post Share on other sites
VladaG9 147 Posted November 30, 2017 @Bibi pritisnes istovremeno Radio + media + browse/enter i drzis par sekundi. Quote Share this post Link to post Share on other sites
Bibi 0 Posted November 30, 2017 Neće, probao sam sve kombinacije! Quote Share this post Link to post Share on other sites
VladaG9 147 Posted December 1, 2017 Ja probao veceras ,i otvorilo mi bez problema. Cudno,ista je verzija. Quote Share this post Link to post Share on other sites
biker972 0 Posted December 4, 2017 Neće ni kod mene Quote Share this post Link to post Share on other sites
Bibi 0 Posted December 6, 2017 Probaj u isto vreme sva tri dugmeta, radio+media+enter. Quote Share this post Link to post Share on other sites
m.deki 1 Posted January 25, 2018 Pozdrav svima, sto se tice prekida u radu zvucnika vozacevih vrata nije problem u softveru vec nesto drugo. Moj kolega ima verziju bez fabricke multimedije i njemu prekidaju svi zvucnici. U pocetku je bio samo zvucnik vozacevih vrata, a sad svi. Kada se malo pomeri-zaokrene konektor izmedju vrata i vozila zvuk dodje i radi par dana, pa opet problem. Treba utvrditi da li je u pitanju sam konektor ili zica Quote Share this post Link to post Share on other sites
Dejanco 2 Posted January 26, 2018 Jel ima novosti u vezii instaliranja navigacije i kamere za rikverc? Hvala. Quote Share this post Link to post Share on other sites
banderash 2 Posted February 16, 2018 Nadam se da mi možete pomoći. Kupio sam fabričku navigaciju za 500L (Fiat 330 VP2 ECE DAB NAV, SW-Version:04.01.38.00; HW-Version: F.EU.D2.V22) iz 2013.godine. Pošto sam imao fabrički bez navigacije za 500L (Fiat 330 VP2 ECE wo RVC; SW-Version: 12.00.08.02; HW-Version: F.EU.DB.V2B) iz 2016.godine zamenio sam ga ovim sa navigacijom. Sada mi radio radi, navigacija radi, ali traži signal (nema GPS antenu), USB sa kog slušam muziku ne vidi, ne funkcionišu komande na volanu, bluetooth povezuje sa telefonom normalno i prebacuje imenik kao što treba, a na instrument tabli trepće ukupna kilometraža. Možete li to da rešite da uređaj koji sam ugradio funkcioniše normalno i da bude ažurirana verzija sa ažuriranim mapama? Quote Share this post Link to post Share on other sites
banderash 2 Posted February 17, 2018 On 4/27/2016 at 1:43 PM, Buca_Tipo said: Ubacen uconnect sa NAVigacijom. Ima vec mape u sebi. Nikakav CODE mi nije trazio i Uconnect saavim normalno radi. E sad jos da nadjem neku GPS antenu da moze da pronadje satelite i to je to. I treba proxy da se odradi posto treperi kilometraza na satu i ne radi MF komande na volanu. Ali da je dobar dobar je. Tako da klasicni Uconnect je na prodaju ako nekog interesuje kojim slucajem. I zabice su metalne i dobre sto je za pohvalu. Malo teze ide skidanje jer prvi put to radim ali nista tesko. I ja sam ubacio uconnect sa navigacijom. Slično se ponaša kao što si ovde napisao za Tvoj još ne može da čita muziku sa fleša. Jesi li u medjuvremenu rešio da prorade komande na volanu i da ne blinka kilometraža? Jesi li radio ažuriranje verzije i mapa (moj uređaj je iz 2013.)? Ne razumem se u to, kakvu GPS antenu da uzmem i gde se ona stavlja? Pozdrav! Quote Share this post Link to post Share on other sites
Ivan 17667 Posted February 18, 2018 Blinkanje kilometraze i komande na volanu ce se resiti povezivanjem uredjaja na Canbus mrezu vozila, tj. kada se poveze na Body Comp. Treba proveriti koji tip GPS antene ide (na ranijim modelima su bile npr. GT5) i pozeljno je postaviti tako da ima opticku vidljivost sa satelitima (kao i za bilo koji drugi GPS reciever). Quote Share this post Link to post Share on other sites
zecabg 8 Posted February 24, 2018 (edited) Pozdrav svima Resili smo sledece probleme za FIAT 500L ukoliko zelite da nadogradite sa UCONECT 330 vp2 NAV uredjajem : 1. Aktiviranje USB a za audio fajlove 2. Aktivacija FIAT loga ako se ne pojavljuje prilikom startovanja navigacije 3. Blinkanje kilometraze 4. Komande na volanu 5. Aktiviranje sva cetiri zvucnika 6. Problem sa pronalazenjem satelita Zeca Edited February 24, 2018 by zecabg 1 Kosta Smosta reacted to this Quote Share this post Link to post Share on other sites
Dejanco 2 Posted February 24, 2018 @zecabg Da li moze na postojeci uredjaj da se instalira rikverc i navigacija. Uredjaj je kao i auto iz 1013. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted February 26, 2018 @zecabg Koja je cena, gde treba ljudi da dođu, neki kontakt? Quote Share this post Link to post Share on other sites
Dejanco 2 Posted March 2, 2018 Ok. Moja je cena. Ako ne mozes ovde posalji PP. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted March 2, 2018 @Dejanco Pre neki dan sam pričao sa @zecabg oko otvaranja komercijalne teme na Forumu za uslugu koju može da pruži oko multimedije na 500L. Samo još malo strpljenja kako bi ljudi sa foruma/članovi Kluba imali povoljniju cenu. Quote Share this post Link to post Share on other sites
Dejanco 2 Posted March 10, 2018 Javi kad bude komercijalna tema.. Quote Share this post Link to post Share on other sites
banderash 2 Posted March 23, 2018 (edited) Zecabg mi ubacio navigaciju 5" juče. Antenu smo stavili u kasetu kod suvozačevih nogu i hvata satelite odlično. Rade komande na volanu, čita muziku sa USB, bluetooth radi dobro (čak kad pričaš s nekim na bluetooth i u isto vreme govori ona ženska iz navigacije na jedan zvučnik priča komandu gde skrenuti, a na drugom pušta sagovornika na telefonu ). Jedino što nismo mogli rešiti je blinkanje kilometraže, pokušao je da odradi proxy na kompjuteru vozila i još 100 fora, ali blinka i dalje, valjda će provaliti. Ovi u ovlašćenom servisu sigurno imaju softver koji to može da konfiguriše, ali ne znam da li hoće. Zvao sam i kažu da moraju da zovu Fiat da im da dozvolu da izvrše rekonfiguraciju (bzvz). Sad čekam da vidim šta će zecabg provaliti. Ako neko ima ideju kako da to otklonimo neka javi. Čovek je super, baš se iscimao dok je provalio sve fore koje su fabrički ubacili da te spreče da ugradiš naknadno uređaj. Edited March 23, 2018 by banderash Quote Share this post Link to post Share on other sites
biker972 0 Posted March 23, 2018 Da li je problem ako nam kazes koja je cena? Hvala Quote Share this post Link to post Share on other sites
banderash 2 Posted March 23, 2018 On 27.4.2016. at 1:43 PM, Buca_Tipo said: Ubacen uconnect sa NAVigacijom. Ima vec mape u sebi. Nikakav CODE mi nije trazio i Uconnect saavim normalno radi. E sad jos da nadjem neku GPS antenu da moze da pronadje satelite i to je to. I treba proxy da se odradi posto treperi kilometraza na satu i ne radi MF komande na volanu. Ali da je dobar dobar je. Tako da klasicni Uconnect je na prodaju ako nekog interesuje kojim slucajem. I zabice su metalne i dobre sto je za pohvalu. Malo teze ide skidanje jer prvi put to radim ali nista tesko. Jesi li rešio blinkanje kilometraže? i meni se događa isto, ne znam kako da rešim. Quote Share this post Link to post Share on other sites
VladaG9 147 Posted March 23, 2018 Koji je to uredjaj ?gde si ga kupio i koja je bila cena ? Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted March 23, 2018 (edited) 7 minutes ago, banderash said: Jesi li rešio blinkanje kilometraže? i meni se događa isto, ne znam kako da rešim. Rečeno mi da je i to rešeno. Info mi je dao @zecabg Biće tokom vikenda, najkasnije početkom sledeće nedelje komercijalna tema o tome na Forumu, pa ća tu pisati sve. Koliko košta, koliko vremena treba da se uradi i ko to radi. EDIT: Sad tek vidim tvoj drugi post da ste već pokušali to. Edited March 23, 2018 by neshaoct dopuna Quote Share this post Link to post Share on other sites
